Old Jan 31, 2013, 09:31 PM
Jeffem62 is offline
Find More Posts by Jeffem62
Jeffem62's Avatar
United States, TX, El Paso
Joined Apr 2012
I have the following situation.
Gaurdian Expander is flashing yellow very fast and im not getting Artificial Horizon on my OSD display. The manual says the following:
Issue: Guardian does not seem to be working correctly and the Guardian’s status LED IS flashing rapidly.
Solution: Make sure you have updated the OSD Pro, eLogger and Guardian firmware as described above.
When I go to Firmware Control I see that I have the correct Firmware Control for the Gaurdian Expander.
I have update all firmware
if I do the following here is what I get.
I have tried connecting the Gaurdian Expander into the OSD and the V4 Elogger. I can still see it in the Firmware Control, but I get the fast yellow blinking led on the Gaurdian and NO Artificial Horizon.
Solutions are update firmware and check connection ( all seem right )
Please any suggestions would be great.
Jeffem62 is offline Find More Posts by Jeffem62
Old Jan 31, 2013, 10:59 PM
m_beeson is offline
Find More Posts by m_beeson
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Hi Jeff,
I would suggest that you open a support ticket here.
I have a suspicion that you will have to send it back for repair,
but they can further assist you in the matter.
-Mike
m_beeson is offline Find More Posts by m_beeson
Old Feb 18, 2013, 04:21 PM
secretspy711 is online now
Find More Posts by secretspy711
Assault the sky
secretspy711's Avatar
United States, CO, Denver
Joined Aug 2004
hi Billpa, I posted a thread in the EagleTree section over at FPVlab about this. The stand-alone 2D/3D Stabilizer has a function that allows for stabilization WITHOUT return to level (this is "3D mode"). The Guardian EXPANDER for the OSD-Pro does not appear to have this feature. Can you please add it? I want my flying-wing to stay in whatever pitch/roll orientation it was in when I let go of the sticks, instead of returning to level flight.
Here is the link to the thread there:
http://fpvlab.com/forums/showthread....o-level-flight
secretspy711 is online now Find More Posts by secretspy711
Old Apr 07, 2013, 08:46 PM
captward is offline
Find More Posts by captward
Joined Oct 2011
Flight Data Recorder and Guardian
Originally Posted by billpa View Post
captward, thanks so much for the kind words, and for taking the time to provide that feedback - really good points. We're kicking some ideas around here on how we can make this happen, but nothing in stone at this writing.
AeroM'ck'y, to make sure I understand, is the AHI correctly tracking the horizon when RTH is activated, or is there in accuracy?
joel0407, sorry to hear about that! I hope someone finds it and returns it to you!
aaron, could you post your Guardian settings? I'd like to see those. If you have a clip of the flight showing the settings on the screen, and also the AHI behavior during bank, that would be ideal. It may be something that can be tuned. Also, are you using a knob to adjust overall gain in the air? That can be very beneficial to tuning.
zkilzz, after selecting elevon mode, have you run the servo analysis wizard, either on a PC or with the stick menus? And, have you turned off mixing in your radio? Finally, have you restarted the OSD after setting up?
Hi Bill:
Its been quite a while since I have been up on here. During the last couple of months I finally got all of my Eagle Tree components connected and they appear to be working correctly, with the exception of my antenna tracking which I believe I did not calibrated correctly (a whole new subject matter). Anyways, the reason for this post is to find out whether there are any plans of working on getting the Guardian Expander to work with the Flight Data Recorder. I have a new build on the horizon and could great really use the same setup I have with my large Cessna if Guardian Stabilization can be incorporated or made to work with the Flight Data Recorder.
captward is offline Find More Posts by captward
Old May 08, 2013, 10:10 AM
FriFlyers is offline
Find More Posts by FriFlyers
Joined Mar 2013
Hi everyone
I need a bet of helpher i have installed the gardian S. on the Osd side, and i learned that from youtube video and it seemed to work for him and that is why i just copied what he was doing, But when i read the Pdf. File of Gardian it says that it should be installed, to the ldc/osd or lcd/tx of the elogger port.
but it seems that it works. What are benefit or mines doing that?
and is there anyone whou would be kind enough to send a picture of your setup, and the other thing that i want to ask you good people is that my Microphone makes alot of unwanted noise!!? What shall i do with all that noise?
Thank you very much for your help.
FriFlyers is offline Find More Posts by FriFlyers
Old May 26, 2013, 02:38 AM
shadowless is offline
Find More Posts by shadowless
Joined Mar 2004
Hi,
Is there a reason why the guardian expander is not compatible with the recorder?
shadowless is offline Find More Posts by shadowless
Old May 27, 2013, 10:38 PM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Originally Posted by shadowless View Post
Hi,
I don't recall ever seeing that message.
Old May 27, 2013, 11:12 PM
Joined Mar 2004
go check. it is on the web
Old May 27, 2013, 11:54 PM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Ok,
I see what you are talking about.
The recorder is not configured to handle the capabilities that the elogger can handle.
That is the simple answer.
For using the guardian, you need the elogger and osd. and I would recommend the GSP module as well, so you can have a fully functional RTH.
Old May 27, 2013, 11:55 PM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
However,
If you just want stabilization, and you insist on using the recorder, then there is the option of using the guardian 2d/3d. It is a first class "stand alone stabilizer".
Old Jul 17, 2013, 08:44 AM
Thermal Hobby is offline
Find More Posts by Thermal Hobby
Joined Dec 2010
-deleted
Thermal Hobby is offline Find More Posts by Thermal Hobby
Old Jul 17, 2013, 09:07 AM
MasterFuba is offline
Find More Posts by MasterFuba
Austria, Vienna
Joined Feb 2013
Guardian Stabilization Module for OSD Pro -> only for AHI?
Hi,
i have ordered eagletree OSD (its on my way from china) but i now realize that AHI is only possible with guardian expander.
I have a hexacopter with Naza so i don't need any level or RTH features, Naza works great out of the box. The only thing i wanna have additional is artificial horizon indicator. Don't know if it worth € 48,- for AHI only but it would be very nice to have :-)
so my question is, can in only use the AHI from guardian?
My idea is just don't use the plugs for servo (throttle, aileron,...) with guardian, i keep them connected to naza as it is now. I just connect guardian to OSD Pro to have AHI visible -> would this work this way?
My MX-16 has no channel free, so i definitly don't want to disable level orientation or so from remote. I want to have it disabled complete or not working cause nothing is connected to it. Would this work, or do i end up in strange "error no servo connected" messages or so?
Just want to be on save side....
Thanks for info
Kr
Daniel
MasterFuba is offline Find More Posts by MasterFuba
Old Jul 17, 2013, 10:46 AM
Thint1 is offline
Find More Posts by Thint1
Thint1's Avatar
Austria / Vienna
Joined Feb 2007
Originally Posted by MasterFuba View Post
Hi,
Thanks for info
Kr
Daniel
Hi D.
you can use the osd for On Screen Display
without using stabilisation or rth ....
for startup the osd "needs" a servo-signal on "AUX1"... you can cheat the osd if you connect a servo-tester if you have no channels free on your tx. or you use a receiver for more channels and connect one of the unsupported channels to the osd. in your case a 12-channel graupner receiver connected to a mx16 gives "neutral -impulse" on the upper 4 channels.
cu Thomas
Thint1 is offline Find More Posts by Thint1
Old Jul 17, 2013, 11:32 AM
Austria, Vienna
Joined Feb 2013
Hi Thomas,
thanks for info - if i understand you right then this is indeed needed for OSD Pro itself, neverless i use guardian or not. Then i have to make my thoughts how to get voltage into OSD. I think i will use a servo splitter without datalead just to give OSD Pro what it wants - additional voltage via RX.
Then i am seeing forowrd for my OSD - i just ordered guardian to have my wanted AHI.
Kind regards
Daniel
Old Jul 17, 2013, 01:47 PM
Thint1 is offline
Thint1's Avatar
Austria / Vienna
Joined Feb 2007
Hi Thomas,
Kind regards
Daniel
Hi Daniel,
just to be sure ... you need the e-logger also.
without the elogger´s usb it´s impossible to configurate the osd from the pc and the osd doesn´t boot without the logger .... i tested this some minutes ago on my plane.
cu Thomas
Mini-HowTo Please post your OSD Pro wiring diagrams here! billpa Eagle Tree Systems 310 Mar 23, 2016 10:12 AM
Discussion Eagle Tree OSD PRO Return to Home Config (Post your setup here). felipesalomao FPV Equipment 158 May 13, 2015 09:44 AM
Question OSD Pro, eLogger V3, GPS V4 problems updating firmware in OSD Pro jbfoamy Eagle Tree Systems 23 Jun 02, 2012 02:59 PM
Discussion 9CH 2,4 Ghz transsmiter and receiver $54.99 tom112233 Hot Online Deals 7 Oct 01, 2010 05:52 PM
Discussion FMP04 GPS module W/ Eagletree OSD Pro vertcnc FPV Talk 2 Aug 08, 2010 07:26 AM
