Old Dec 07, 2011, 04:58 PM
zkilzz is offline
Find More Posts by zkilzz
Joined Sep 2011
When i set elevon on Choose model wing type my servos suddenly tries to go to 120% movment and it gets no reaction from the radio. Anyone knows what causing that problem?
zkilzz is offline Find More Posts by zkilzz
Old Dec 07, 2011, 10:07 PM
billpa is offline
Find More Posts by billpa
billpa's Avatar
Joined Nov 2003
captward, thanks so much for the kind words, and for taking the time to provide that feedback - really good points. We're kicking some ideas around here on how we can make this happen, but nothing in stone at this writing.
AeroM'ck'y, to make sure I understand, is the AHI correctly tracking the horizon when RTH is activated, or is there in accuracy?
joel0407, sorry to hear about that! I hope someone finds it and returns it to you!
aaron, could you post your Guardian settings? I'd like to see those. If you have a clip of the flight showing the settings on the screen, and also the AHI behavior during bank, that would be ideal. It may be something that can be tuned. Also, are you using a knob to adjust overall gain in the air? That can be very beneficial to tuning.
zkilzz, after selecting elevon mode, have you run the servo analysis wizard, either on a PC or with the stick menus? And, have you turned off mixing in your radio? Finally, have you restarted the OSD after setting up?
billpa is offline Find More Posts by billpa
Site Sponsor
Old Dec 07, 2011, 10:18 PM
m_beeson is offline
Find More Posts by m_beeson
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Bill,
You just answered my question in that message that I sent you earlier.
I should have run the servo analysis wizzard.
"duh"...
m_beeson is offline Find More Posts by m_beeson
Old Dec 08, 2011, 03:28 AM
Blackrat is offline
Find More Posts by Blackrat
Registered Loon
Blackrat's Avatar
South Africa, WC, Knysna
Joined May 2006
just a quick question ...
before i take off my elevons arnt level , is this 'normal' ? before i installed the guardian i would have maybe a millimeter of reflex , but now i have one side at three or four millimeters and the other at nothing ?
Blackrat is offline Find More Posts by Blackrat
Old Dec 08, 2011, 04:59 AM
zkilzz is offline
Joined Sep 2011
I made i video. Its easier than explaining I have tried the wizard on pc and stick menus.
Ee problem (3 min 19 sec)
Old Dec 08, 2011, 05:30 AM
garris2 is online now
Find More Posts by garris2
Australia, VIC, Glen Waverley
Hi zkilzz,
You must HOLD the elevator and Aileron sticks each to their extremes in turn when asked until the counter counts down to zero and release the stick when the wizards asks you to do the next step.
Your control surfaces are not moving because the OSD has correctly detected no travel when you ran the servo analysis wizard.
Also don't forget to mount your Guardian firmly to the fuselage with double sided tape or hot glue before flying.
cheers
Geoff
garris2 is online now Find More Posts by garris2
Old Dec 08, 2011, 05:32 AM
zkilzz is offline
Joined Sep 2011
Originally Posted by garris2 View Post
Hi zkilzz,
cheers
Geoff
That helped. But i ran into a new problem
8. desember 2011 12.26 (0 min 19 sec)
Old Dec 08, 2011, 09:58 AM
joel0407 is offline
Find More Posts by joel0407
joel0407's Avatar
Australia, NT, Lyons
Joined Oct 2010
Thanks Bill.
I think you'll have another order coming your way soon.
joel0407 is offline Find More Posts by joel0407
Old Dec 08, 2011, 04:53 PM
ashdec87 is offline
Find More Posts by ashdec87
ashdec87's Avatar
United States, MI, Detroit
Joined Feb 2004
Bill- I've got a couple flights in with the Guardian now. I have it set with center stick and HH off. Straight and level it does a great job, but when I turn I've noticed that the sensor seems to get confused with the G forces during the turn so when i release the stick, it doesn't go to straight and level, but a turn. The sharper I make the turn the more severe the effect. With the Stab off, I see the same effect in the AHI. Any thoughts here?? I'll post a video of what I'm talking about.
ashdec87 is offline Find More Posts by ashdec87
Old Dec 08, 2011, 08:03 PM
rsowder is offline
Find More Posts by rsowder
rsowder's Avatar
San Francisco
Joined May 2009
http://www.youtube.com/watch?v=bP2w2TAutT0
Try disabling stabilization then run the servo wizard, then reactivate it and see if that helps.
rsowder is offline Find More Posts by rsowder
Old Dec 08, 2011, 08:04 PM
chc2111 is offline
Find More Posts by chc2111
Joined Nov 2011
Finaly I got it!!!
This guardian is GREAT!!!
Still flying in visual distance.
Check this out:
F1 Hydro 150 scaled up flying FPV (6 min 3 sec)
Jump over the first 40 sec ...
It was pretty windy!! I let the stcks go and ... wow ...
Next step is to set up RTH!
BTW this one is a scaled up F1 Hydro, it lunches beautiful from the water.
chc2111 is offline Find More Posts by chc2111
Old Dec 08, 2011, 11:51 PM
rcimports is offline
Find More Posts by rcimports
South Africa
Joined Oct 2005
Haha, that's cool! FPV on a hydro, very nice!
Got some pics of the setup?
rcimports is offline Find More Posts by rcimports
Old Dec 09, 2011, 11:13 AM
zkilzz is offline
Joined Sep 2011
Once i put on stabilization it doesnt work. No reaction. If i do wizard with guardian on i get some micro movement.
I use T 9X with Dragonlink.
Please help Billpa
Old Dec 09, 2011, 02:42 PM
fordarrick is offline
Find More Posts by fordarrick
United States, CA, Redlands
Joined Dec 2009
M_beeson,
Are you running the rudder or the ailerons thru the osd with the guardian?
Darrick
fordarrick is offline Find More Posts by fordarrick
Old Dec 09, 2011, 03:42 PM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Originally Posted by fordarrick View Post
M_beeson,
Darrick
I'm running ailerons.
I just converted the skywalker to the fpv168 wings and stalled it on takeoff, so I'll likely be going to a delta wing configuration next (flapperons).
-Mike
Mini-HowTo Please post your OSD Pro wiring diagrams here! billpa Eagle Tree Systems 310 Mar 23, 2016 10:12 AM
Discussion Eagle Tree OSD PRO Return to Home Config (Post your setup here). felipesalomao FPV Equipment 158 May 13, 2015 09:44 AM
Question OSD Pro, eLogger V3, GPS V4 problems updating firmware in OSD Pro jbfoamy Eagle Tree Systems 23 Jun 02, 2012 02:59 PM
Discussion 9CH 2,4 Ghz transsmiter and receiver $54.99 tom112233 Hot Online Deals 7 Oct 01, 2010 05:52 PM
Discussion FMP04 GPS module W/ Eagletree OSD Pro vertcnc FPV Talk 2 Aug 08, 2010 07:26 AM
