Old Dec 01, 2011, 06:51 AM
Thint1's Avatar
Austria / Vienna
Joined Feb 2007
Originally Posted by imagebuff View Post
Is the guardian affected by nearby magnets? I am finishing up a build and the hatch which will house the electronics is secured by magnets. I hope I didn't goof here.
hi,
i had my wings secured with magnets, the guardian was app. 2cm away from them. never seen any issues.
cheers Thomas
Thint1 is offline Find More Posts by Thint1
Old Dec 01, 2011, 06:57 AM
Thint1's Avatar
Austria / Vienna
Joined Feb 2007
Originally Posted by smarm View Post
I want to put the guardian I have here on a quad. Can I have all stabilisation features off and just use it for the artificial horizon?
hi,
yes, you can operate the osd + logger + guardian without the use of stabilisation and rth.
cheers Thomas
Old Dec 01, 2011, 07:35 AM
Joined Nov 2011
Yes I did
chc2111 is offline Find More Posts by chc2111
Old Dec 01, 2011, 01:02 PM
Blu-Core is my friend
Gundy's Avatar
La Crosse, WI
Joined Apr 2006
Ok,
moving my OSD PRO + logger v3 + Guardian to my new Zephyr ZII
From another wing.
anyone have a good "setup file" for a Zephyr??
Later,
Gundy
Gundy is offline Find More Posts by Gundy
Old Dec 01, 2011, 06:07 PM
CaliDave's Avatar
Bay Area
Joined Dec 2010
Stuttering Guardian movement
Solved - Reinstalled newest software and Guardian is no longer stuttering.
CaliDave is offline Find More Posts by CaliDave
Old Dec 02, 2011, 06:33 PM
Joined Nov 2011
Internal Error 0306BE
My issue is still not solved. Installed newest software again.
This is what I found so far:
1. I'm running the servo wizard and hold the sticks until the count is zero. After I turned on the Guardian, the servo movements are extrem limited - almost no movement, regardless how much overall gain. With full gain I can see the servos moving a bit, if i shake the plane.
2. If I switch the Wing typ to elevon same behave (this is was I need)
3. If I switch on the option Center stick stabilisation only I'm getting this error.
4. The AHL is working just fine
Help is highly appreciated, opened a ticket already - no response so far.
Old Dec 03, 2011, 01:51 AM
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Just a shot in the dark...
Are your limits decreased in your transmitter?
-Mike
m_beeson is offline Find More Posts by m_beeson
Old Dec 03, 2011, 09:47 PM
Joined Nov 2011
-Mike
Mike thanks,
!!!!!! Solved it !!!!!
To make a long story short I mixed the Elevator and the Aileron from the Rx to the OSD.
Old Dec 04, 2011, 12:38 AM
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Mike thanks,
glad you got it.
Old Dec 04, 2011, 05:52 AM
joel0407's Avatar
Canberra, Australia
Joined Oct 2010
Buyer be warned. This thing works awesome. Too awesome in fact.
Saturday was my second attempt at FPV. After my first attempt was with a Helli I thought I needed a plane to start.
My Bixler/Sky Surfer weighed in at about 1.2kgs but the Guardian made it fly soooo smooth and level, I couldn't believe how good it flew. The build took me about 6 months to put together, just doing a bit here and there and waiting for stock of some things.
Finally a mate set a date and said you need to be ready for this weekend. As I was thinking this project has stretched out too long any way I went with it. I should have tested and setup things better but away I (the bixler) went.
After 5 minutes my Bloggie turned off and I lost video. I engaged the Return to Home which I hadn't setup. The plane flew beautifully, so level, keeping altitude. It was too far away at this time to see orientation but I thought it was coming toward me. Apparently not.
I suspect my 900mhz Vtx had interfered with my GPS.
My plane just flew away.
Should have properly tested the Bloggie at home on the Bench until the battery went flat.
Should have setup the OSD with more info like GPS sats.
Should have properly tested RTH with the Simulator.
No point crying over spilt milk.
Good thing is. The location I chose to fly is a mates property in Country Australia, there is only 4 neighbours within the flight range. They all know about my lost plane and I have no doubt that if it is found whilst they are checking sheep or stripping crops, it will get returned. I believe there is a good chance it will be found but I don't know how long away that will be.
joel0407 is offline Find More Posts by joel0407
Old Dec 04, 2011, 06:11 AM
www.shop.trisembly.co.za
rcimports's Avatar
South Africa
Joined Oct 2005
Bad news man!
I'd be very interested to hear how far it went though! If it kept level and there's no trees/mountains then chances are it's in one piece, holding thumbs!
Dion
rcimports is offline Find More Posts by rcimports
Old Dec 04, 2011, 06:16 AM
Joined Mar 2009
joel0407, I hope you'll find it soon.
Next time try flying with a spotter for the first few times
HagayB is offline Find More Posts by HagayB
Old Dec 04, 2011, 09:04 PM
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
first couple of times I tried RTH, the plane wouldn't turn.
Then I got that fixed, and it wouldn't pull out of a decent.
It is important to test and calibrate before you need it...
Old Dec 05, 2011, 12:41 AM
joel0407's Avatar
Canberra, Australia
Joined Oct 2010
How did you fix it turning?
I'm currently holding off ordering a new plane and gear until I give it a couple of months to see if it turns up.
Old Dec 05, 2011, 09:13 AM
Norway
Joined Dec 2007
Hi..You can loan one of mine planes..i have nine. 4 with Eagletree OSD.
Twinstar II,Cloadsfly,Bixler,EPP-FPV,2 Skywalker,Raptor,Hobbyking Quad,Voyager...
FPV-maniac...hehe.
I Hope you get it back soon
Deltadeville is offline Find More Posts by Deltadeville
Mini-HowTo Please post your OSD Pro wiring diagrams here! billpa Eagle Tree Systems 236 Jun 14, 2013 05:17 AM
Discussion Eagle Tree OSD PRO Return to Home Config (Post your setup here). felipesalomao Video Piloting (FPV/RPV) 149 Feb 10, 2013 06:28 PM
Question OSD Pro, eLogger V3, GPS V4 problems updating firmware in OSD Pro jbfoamy Eagle Tree Systems 23 Jun 02, 2012 02:59 PM
Discussion 9CH 2,4 Ghz transsmiter and receiver $54.99 tom112233 Hot Online Deals 7 Oct 01, 2010 05:52 PM
Discussion FMP04 GPS module W/ Eagletree OSD Pro vertcnc Video Piloting (FPV/RPV) 2 Aug 08, 2010 07:26 AM
