Old Mar 04, 2011, 12:55 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
If you deflect the ailerons up for spoilerons, the main portion of the wing can be flown at a higher AOA without fear of tip stalling and the plane can be flown slower.
This is what I did on my Powerfly mosquito and it did work.
UNGN is offline Find More Posts by UNGN
Old Mar 04, 2011, 12:59 PM
Lberry.88 is offline
Find More Posts by Lberry.88
If in doubt, add accelerant
Lberry.88's Avatar
United Kingdom, England, Stansted Mountfitchet
Joined May 2007
Ah ok, I did flaperons with a UM P51, it just increased the tip stall tendency a bit.
Lberry.88 is offline Find More Posts by Lberry.88
Old Mar 04, 2011, 01:28 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Because they are full wing flaps and you were deflecting them down.
The Mosquito flaps are at the tips and the flap switch should only deflect them up.
Old Mar 04, 2011, 01:34 PM
jabsten is offline
Find More Posts by jabsten
Can't get enough
jabsten's Avatar
United States, WA, Puyallup
Joined May 2010
How would I go about setting that up? Would It just be set on one switch? Does it effect turning using the ail? I am a newb with this, so any advice appreciated. Also, any elev/ail mixing necessary?
jabsten is offline Find More Posts by jabsten
Old Mar 04, 2011, 02:43 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
First, you need to switch the Brick to separate Channels 2 and 6.
Bind Brick to a TX model with no mixes or reverse channels (or bind it to a RTF TX), then unplug the RX battery.
For a Mode 2 TX, Put the throttle at full, and move the Aileron/Elevator (right stick) to full southwest (full up elevator, full left rudder).
Plug in the RX Battery and wait a few seconds for it to flash 3 times.
To test it, only one Aileron will work, now.
Now Switch the Mosquito model in your TX to "dual ailerons" or "Flaperons" and bind it to the RX... Now both ailerons should work again.
Then adjust your flaps to give the desired throw you want.
Old Mar 04, 2011, 03:19 PM
jabsten is offline
Can't get enough
jabsten's Avatar
Joined May 2010
I had it switched to dual already, then I did the procedure. My question, is how do I go about messing with the the throws, and when to deploy full flaps etc.
Old Mar 04, 2011, 04:08 PM
merlinfan is offline
Find More Posts by merlinfan
Throttle Bender
merlinfan's Avatar
Joined Jun 2008
Its a NF II now.
merlinfan is offline Find More Posts by merlinfan
Old Mar 04, 2011, 04:17 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
It depends on what TX you have.
Just play with the flap settings until both ailerons deflect up at 20 degrees at full flap travel.
Mix it to an on/off switch so you can see the difference it makes at low speed.
Old Mar 04, 2011, 06:02 PM
aracer is offline
Find More Posts by aracer
UK, Hereford and Worcester, Worcester
Joined Feb 2009
Originally Posted by AggressorBLUE View Post
One mod I'd like to see is a new nose cone that replicates the observation mondel of the moisse. I've already snapped the two inward dummy mgs,. the observation model would be less prone to damage in a nose over.
I may contact parkflyer plastics about this. seems like a mod a bunch of people could get behind.
I'd be interested in that - would make it possible to get a bit closer to the prototype (which is how I still imagine a Mossie) - just need to work out how to repaint it! Don't suppose I'm up to shortening the nacelles for the full scale look of the original proto, but I guess what I saw did have the extended nacelles for testing of those, so what I could make wouldn't be too far off what I remember seeing many times when I was a kid (we lived just down the road from it).
aracer is offline Find More Posts by aracer
Old Mar 04, 2011, 06:22 PM
jabsten is offline
Can't get enough
jabsten's Avatar
Joined May 2010
I have the DX8.
Old Mar 04, 2011, 06:54 PM
omer921 is offline
Find More Posts by omer921
The trees are my hangar
omer921's Avatar
United States, NY, Queens County
Joined Dec 2010
Did anyone think about actually adding flaps (not flaperons) using one servo and music wire and using the inside of the wing as flaps ?
omer921 is offline Find More Posts by omer921
Old Mar 04, 2011, 06:59 PM
FieldofDreamsFlyer is online now
Find More Posts by FieldofDreamsFlyer
Field of Dreams Flyer
FieldofDreamsFlyer's Avatar
United States, CA, LA
Joined Sep 2004
Im using a eflite 1s 500mah battery in mine and fits perfect
FieldofDreamsFlyer is online now Find More Posts by FieldofDreamsFlyer
Old Mar 04, 2011, 08:45 PM
Redhood is offline
Find More Posts by Redhood
Redhood's Avatar
United States, MN, Odin
Joined Aug 2010
Looks great Merlinfan!
Redhood is offline Find More Posts by Redhood
Old Mar 05, 2011, 01:22 AM
Darth Vapor is offline
Find More Posts by Darth Vapor
USA, CA, Altadena
Joined Nov 2010
I'm planning on doing this mod. I want to get a few more flights in before I start cutting it up though. I haven't added flaps to a plane before. I have a plan already but if anyone can point me to a thread with relevant info it would be appreciated.
Darth Vapor is offline Find More Posts by Darth Vapor
Old Mar 05, 2011, 01:23 AM
USA, CA, Altadena
Joined Nov 2010
Originally Posted by merlinfan View Post
Its a NF II now.
Nice! what kind of paint and how much added weight?
Discussion *Official* Parkzone Ember mod thread. HPIAdam Scratchbuilt Indoor and Micro Models 373 Apr 08, 2013 05:53 AM
New Product Parkzone UM Corsair and Mosquito 3D4life Scratchbuilt Indoor and Micro Models 67 May 05, 2011 10:14 PM
Cool **OFFICIAL** Parkzone Micro T-28 Mod Thread RCSwitz18 Micro Ready-to-Fly 3 Jan 02, 2011 04:30 PM
Mini-HowTo Parkzone UM P-51 Flap Mod!!!!!! i believe im the first to think of an actual diagram RM_Sparks Micro Ready-to-Fly 0 Jul 11, 2010 05:19 AM
Discussion Micro Mosquito Mod Thread? sakko Coaxial Helicopters 2 Oct 24, 2006 03:31 PM
