Old Mar 03, 2011, 10:04 PM
turboparker is offline
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
Originally Posted by Lead Wings View Post
The other thread has some talk about motor upgrades (think they are Nine Eagles heli motors?).
Can someone post a link to the jucy bits so idiots like me know what to get?
Lead Wings,
The Nine Eagles Solo Pro motor is a good replacement for the P-51 motor. Same power, but they seem to be more consistent - so far. The Nine Eagles Bravo SX motor is a major power upgrade from the PZ P-51 motor - but premium cells are mandatory. The cheap Chinese cells are completely useless in this app. RCBabbel's testing in a Sukhoi XP showed 60g of static thrust on a 5043 prop with a Hyp 180 cell. That is a 30% increase in thrust over the stock XP motor - which is the same as the P-51/4-Site/UMX Extra/T-28/F4U.
The catch is that you have to swap pinions & connectors. RCBabbel has been selling SP & SX motors already set up for the PZ 8.5mm gearbox. Shoot him a PM if you're interested. A pair of SX motors in the Mossie would make the old girl go ballistic. Would take a really stout battery to handle the current, though. Probably at least a 2p Hyp 160, 2p Hyp 180, or 1s Hyp 320.
Here's the thread: http://www.rcgroups.com/forums/showthread.php?t=1326158
Joel
turboparker is offline Find More Posts by turboparker
Old Mar 03, 2011, 10:39 PM
Joined Jul 2009
Originally Posted by omer921 View Post
I cans fly the trojan pretty well, landings are tricky, I give minimal power so the prop is not drag, but I will have to learn how to land it with power.
Omer,
The key is to fly her like a full-scale ship - manage airspeed with elevator, and altitude with throttle. Using the elevator to control sink-rate is the most common mistake made by RC pilots on approach. With lightly-loaded, overpowered planes, one can get away with it - to a point. However - with higher wing-loadings - and especially with scale ships, it will bite you.
Once you set up your approach, manage your sink-rate with throttle. Manage your airspeed with elevator. If she's sinking too fast, feed in a bit of power. If she's going to overshoot the runway, reduce power. If she's coming in a bit too hot, ease the elevator stick back a bit. If she's getting mushy on the sticks, drop the nose a bit. Keep some power on all the way down. When she's a few inches off the ground, pull the power back and ease the stick back to flare. She will settle in for a nice 3-point landing. If your runway is a bit longer, also try a two-wheel landing. Everything is the same up to the point when she's a few inches off the ground. Instead of pulling the power back & flaring - you just bring her in on the mains with a bit of power. Cut the power just after the mains meet the runway. As she slows, the tail will come down on its own.
Joel
Old Mar 03, 2011, 11:11 PM
fryfrog is offline
Find More Posts by fryfrog
United States, CA, Mountain View
Joined Sep 2010
Originally Posted by AggressorBLUE View Post
Hyperion 240mah 1 cell
Hyperion 180mah 1 cell (the Hyperion batteries are generally considered the best available for Ultra Micros.):
Available from-
All e RC
Are http://www.allerc.com/hyperion-g3-cx...or-p-5438.html the specific 240mah with micro connector you're talking about? Do these fit into the plane?
fryfrog is offline Find More Posts by fryfrog
Old Mar 03, 2011, 11:54 PM
Darth Vapor is offline
Find More Posts by Darth Vapor
USA, CA, Altadena
Joined Nov 2010
Three, she's a tail dragger, which means roll over is an issue to watch for (unlike the trojan)
One mod I'd like to see is a new nose cone that replicates the observation mondel of the moisse. I've already snapped the two inward dummy mgs,. the observation model would be less prone to damage in a nose over.
I may contact parkflyer plastics about this. seems like a mod a bunch of people could get behind.
Yeah, took it out today and did the "scrape all the machine guns off" mod. I never liked them anyway... (Ill just keep telling myself that)
Sweet photo btw
Darth Vapor is offline Find More Posts by Darth Vapor
Old Mar 04, 2011, 12:04 AM
AggressorBLUE is offline
Find More Posts by AggressorBLUE
Park Stormer
United States, NJ, Brooklawn
Joined Jul 2008
I posted this on the main thread, but to make sure the word gets out:
"Zippy Flightmax Single Cell batteries deliver full capacity & discharge as well as being the best value batteries in the hobby market today! Ideal for light weight applications, a JST connection has been pre-installed eliminating the hassle of making single cell packs.
Spec.
Capacity: 240mAh
Voltage: 1s / 3.7v
Discharge: 30C Constant / 40C Burst
Weight: 9.9g (including wire, plug & case)
Dimensions: 63x26x3mm
Discharge Plug: JST"
http://www.hobbyking.com/hobbyking/s...dProduct=11870
Note you'll need to swap out the plug.
AggressorBLUE is offline Find More Posts by AggressorBLUE
Old Mar 04, 2011, 12:17 AM
Lead Wings is offline
Find More Posts by Lead Wings
I enjoy the voices
Lead Wings's Avatar
Perth, Australia
Joined Apr 2007
Originally Posted by turboparker View Post
Lead Wings,
The Nine Eagles Solo Pro motor is a good replacement for the P-51 motor......
Joel
Thanks Joel, that is what I was after. I have a V1 Sukhoi that needs an upgrade and a Mosquito out there somewhere with my name on it - will get a couple of the motors for spares.
Lead Wings is offline Find More Posts by Lead Wings
Old Mar 04, 2011, 12:19 AM
Park Stormer
Joined Jul 2008
@fryfrog: Yes. Thanks for pointing that out, I've updated the main page to include the more specific link. As an aside, I flew my mossie on one of those today, and it did pretty well. I'll update after a few more flights.
@ Darth Vapor: Yea, first thing I thought when i saw that nose cone was "these things won't last one battery pack..."
as for the photo, I just typed something like "mosquito observation model" into google image search and she came up. It would make a great paint scheme though, the red tail and invasion stripes would be make for better orientation Think that may be my first mod in fact...
Old Mar 04, 2011, 01:42 AM
I enjoy the voices
Lead Wings's Avatar
Perth, Australia
Joined Apr 2007
Does anybody know if that is a historically legit paint scheme? I didn't realise the USAF were flying mozzies in WWII/D-day, and I also note what look like kill tags on the fuse below the cockpit hard for a recon plane to log up that many kills unless its missions?
Old Mar 04, 2011, 02:46 AM
micromantis is offline
Find More Posts by micromantis
No mods no glory!
micromantis's Avatar
United States, CA, Redwood City
Joined Nov 2010
Here's my Mosquito FB Mk VI of 21 Squadron RAF 1945.
Took some .05mm carbon rod for the antennas and a sharpie ultra fine point to her.
micromantis is offline Find More Posts by micromantis
Old Mar 04, 2011, 05:47 AM
Ensign Jimmy is offline
Find More Posts by Ensign Jimmy
The building never ends!
Tucson, AZ
Joined Oct 2008
Spec.
Capacity: 240mAh
Voltage: 1s / 3.7v
That's quite heavy (and long) for a 240 mAH cell. If you're going to get something that heavy from HK, a higher capacity cell would be better. It's 350 mAH 20C discharge. Sure, 20C isn't a whole lot these days, but it's not as long as the cell you've listed, and the Mosquito apparently won't draw more than 7C on a 350 mAH cell going full-out.
Ensign Jimmy is offline Find More Posts by Ensign Jimmy
Old Mar 04, 2011, 07:05 AM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
My friend Roland Bushner flew Mosquitos for the US Army Airforce for the 25th Bomb Group, 653rd Bomb squadron and flew high altitude Recon missions deep into Germany unarmed, without escort.
The tags were for recon missions.
UNGN is offline Find More Posts by UNGN
Old Mar 04, 2011, 07:13 AM
gentle ben is offline
Find More Posts by gentle ben
semper mitis
gentle ben's Avatar
Paducah, Kentucky
Joined Nov 2004
Here are a few 8th AAF, I believe.
gentle ben is offline Find More Posts by gentle ben
Old Mar 04, 2011, 10:42 AM
represent is online now
Find More Posts by represent
Please excuse me..
represent's Avatar
United States, TX, Dallas
Joined Feb 2011
Wow that looks amazing!! Really well done man great job!
represent is online now Find More Posts by represent
Old Mar 04, 2011, 12:33 PM
jabsten is offline
Find More Posts by jabsten
Can't get enough
jabsten's Avatar
United States, WA, Puyallup
Joined May 2010
Originally Posted by jabsten View Post
I received my mosquito yesterday, and am pretty excited despite the weather and not being able to fly it. Can someone who has activated the dual ail feature let me know how it went? I might set it up tonight, and wondering the benefits besides spoilerons/flaperons, which I don't know about that much. I know I can trim each one independently, which is a good plus for flight. Will activating dual ail increase throw at all? Thanks!
Since this is the MOD thread,,,,anyone? I am curious why this hasen't been discussed further. I have set up dual ail, but that is how far I have gone.
jabsten is offline Find More Posts by jabsten
Old Mar 04, 2011, 12:49 PM
Lberry.88 is offline
Find More Posts by Lberry.88
If in doubt, add accelerant
Lberry.88's Avatar
United Kingdom, England, Stansted Mountfitchet
Joined May 2007
The worry with having full length flaperons to the wing-tip is that it will increase the tip-stall tendency of the plane. Though experimentation is needed.
Lberry.88 is offline Find More Posts by Lberry.88
Discussion *Official* Parkzone Ember mod thread. HPIAdam Scratchbuilt Indoor and Micro Models 373 Apr 08, 2013 05:53 AM
New Product Parkzone UM Corsair and Mosquito 3D4life Scratchbuilt Indoor and Micro Models 67 May 05, 2011 10:14 PM
Cool **OFFICIAL** Parkzone Micro T-28 Mod Thread RCSwitz18 Micro Ready-to-Fly 3 Jan 02, 2011 04:30 PM
Mini-HowTo Parkzone UM P-51 Flap Mod!!!!!! i believe im the first to think of an actual diagram RM_Sparks Micro Ready-to-Fly 0 Jul 11, 2010 05:19 AM
Discussion Micro Mosquito Mod Thread? sakko Coaxial Helicopters 2 Oct 24, 2006 03:31 PM
