Old Jan 02, 2013, 04:10 PM
Jaryd107 is offline
Find More Posts by Jaryd107
Joined Apr 2010
Has anybody upgraded the motors yet? Mine feels like it has lost power and my props seem to wiggle forward and back a little. Maybe its my batteries?
Jaryd107 is offline Find More Posts by Jaryd107
Old Jan 03, 2013, 12:34 AM
airpower is offline
Find More Posts by airpower
Have fun
airpower's Avatar
United States, CA, Mission Viejo
Joined May 2007
Replace the motors, they wear out in an average of 50-150 flights. Usually shorter on the mossie because the two should be balanced.
airpower is offline Find More Posts by airpower
Old Jan 03, 2013, 02:13 PM
CorvetteC5 is online now
Find More Posts by CorvetteC5
CorvetteC5's Avatar
Kokomo, Indiana
Joined Jun 2008
Are you flying with colder batteries then before? Do you have a fresh battery to test before surgery of motor replacement? The motors I have replaced were all after obvious failures including loosing an armature pole, brush screeching then nothing, increased turning resistance of armature after a flight do to wire heating and rubbing.
Forward and aft movement from the prop shaft is normal. I like to see about 1/16" of play to allow for temperature movement.
CorvetteC5 is online now Find More Posts by CorvetteC5
Old Jan 15, 2013, 05:37 PM
Black_Beard is offline
Find More Posts by Black_Beard
Black_Beard
Black_Beard's Avatar
USA, FL, St Petersburg
Joined Jan 2010
Just got one
I just got a NIB Mossy from a trade I did with another user. The plane looks great in the box but I was never a fan of dual motor bombers. I was thinking of maybe trading this guy for the UM Spitfire. If you guys know anyone that would like to do such a trade let me know!
Black_Beard is offline Find More Posts by Black_Beard
Old Jan 31, 2013, 06:02 PM
turboparker is offline
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
BL conversion for the Mossie
Gents,
I think we may have the long-awaited practical bl conversion for the Mossie! The BL mCPX tail motor fits the UM gearbox & only needs a pinion to work. And, it puts out more thrust on 1s than the stock motor. Add a pair of bl ESCs & you're done! Switch to the AS3X brick from the Beast & install a pair of 2030LO AS3X aileron servos with built-in differential & you'd have the best UM video platform around!
http://www.rcgroups.com/forums/showthread.php?t=1820881
Joel
turboparker is offline Find More Posts by turboparker
Old Feb 04, 2013, 09:35 PM
pegasus.pony is offline
Find More Posts by pegasus.pony
pegasus.pony's Avatar
United States, TN, Knox
Joined Sep 2011
My Mossie gets a crew!
Originally posted in the Mosquito thread, post #3757.
But I'll post here too since this IS the Mod thread.
Attached are pics of the fresh crew added to my UM Parkzone Mosquito.
At "ATTENTION" for F.O. Lt. Ronin and F. Sgt. Wallace.
Shaped from pink foam and after some trimming in the crew compartment, installed with canopy glue.
Pics attached.
Cheers!
pegasus.pony is offline Find More Posts by pegasus.pony
Old Feb 04, 2013, 10:32 PM
Joined Jul 2009
Sorry, but the brushless motor was a false alarm. Turns out that the motor won't work with the factory gearing & the UM-sized props.
Joel
Old Feb 05, 2013, 07:12 AM
Joined Sep 2011
Joel
Bummer, dewd...
Thanks for trying, though.
Cheers!
Old Feb 12, 2013, 07:55 AM
GoatRider is offline
Find More Posts by GoatRider
United States, MN, Maple Grove
Joined May 1999
What kind of tape should I look for for reassembly?
GoatRider is offline Find More Posts by GoatRider
Old Feb 12, 2013, 08:50 AM
Pouncer is offline
Find More Posts by Pouncer
Wanton construction
Pouncer's Avatar
Stockholm Sweden
Joined Sep 2006
My flap mod, very rough-and-ready, from last june, forgot to post it..
http://www.rcgroups.com/forums/showt...0#post24111394
Didn't want to have flaps only inboard of motor nacelles so came up with this simple solution: make them as wide as ailerons allowed and removed part of the nacelles.
The flaps are very effective but really draggy so don't throttle back too much!
Pouncer is offline Find More Posts by Pouncer
Old Feb 12, 2013, 12:59 PM
Joined Jul 2009
Great flap mod! I bet they're very effective. I've often thought about adding flaps to mine. This has perked my interest again!
Joel
Old Feb 12, 2013, 02:33 PM
Joined Sep 2011
GR,
The best I've found is "scotch" type tape from Walgreens. It is a little more narrow than standard office type clear tape, and it is thinner and maybe a little stretchier.
Cheap, too!
Best attribute is the "thinner" part.
Hope this helps.
Cheers!
Old Feb 12, 2013, 03:19 PM
Joined May 1999
Originally Posted by pegasus.pony View Post
GR,
The best I've found is "scotch" type tape from Walgeens.
Hope this helps.
Cheers!
Yes, that does help. Wish I would have known that before I went to walgreens earlier today!
Regular scotch tape isn't stretchy at all, and is kinda milky. That doesn't seem appropriate.
Old Mar 25, 2013, 02:44 PM
jwoocrew is offline
Find More Posts by jwoocrew
Fox Four,..Guns, Guns, Guns!
jwoocrew's Avatar
United States, CA, El Dorado Hills
Joined Jun 2011
Adding Panel Lines
First off, I checked everything prior to adding the panel lines just to make sure I didn't do all the work and then have an issue to where I couldn't return the plane.
Did the maiden over the weekend and she flies with stock configurations as stated from this thread. I upgraded to 1S 600MAh with an adapter from JST to micro connector. The added weight gets my COG in the right spot so no need for further adjustments.
Here are some photos of the top side. Bottom side to follow.
jwoocrew is offline Find More Posts by jwoocrew
Last edited by jwoocrew; Mar 25, 2013 at 02:54 PM. Reason: referenced wrong Battery MAH
Old Mar 25, 2013, 03:47 PM
Joined Jul 2009
Jwoocrew,
That's one sharp-looking Mossie! Excellent work!
Joel
Discussion *Official* Parkzone Ember mod thread. HPIAdam Scratchbuilt Indoor and Micro Models 373 Apr 08, 2013 05:53 AM
New Product Parkzone UM Corsair and Mosquito 3D4life Scratchbuilt Indoor and Micro Models 67 May 05, 2011 10:14 PM
Cool **OFFICIAL** Parkzone Micro T-28 Mod Thread RCSwitz18 Micro Ready-to-Fly 3 Jan 02, 2011 04:30 PM
Mini-HowTo Parkzone UM P-51 Flap Mod!!!!!! i believe im the first to think of an actual diagram RM_Sparks Micro Ready-to-Fly 0 Jul 11, 2010 05:19 AM
Discussion Micro Mosquito Mod Thread? sakko Coaxial Helicopters 2 Oct 24, 2006 03:31 PM
