Old Mar 06, 2011, 03:16 AM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
That's kind of the whole point of this converter. Since MikroKopter (and some others) use I2C to control ESCs, you either use I2C ESC or a converter to use with cheap ESC.
Of course you can rewrite firmware of whatever flight control board to output for standard ESCs, but usually there's not enough free pins or CPU or hardware resources available to do it.
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old Mar 06, 2011, 03:25 AM
Stacky is offline
Find More Posts by Stacky
Pants first, then shoes
Joined Jan 2011
forgive me Im a complete newbie. I asked with respect to the t580 Lotus quad more than the MK system. Just wondering about the possibility to give one of those bigger motors
Stacky is offline Find More Posts by Stacky
Old Mar 06, 2011, 03:34 AM
timecop is offline
Joined Dec 2010
T580 uses standard ESC, so you don't need to do anything special to upgrade it. Just get one with higher Amp rating + better motors + bigger battery etc.
Old Mar 06, 2011, 03:36 AM
Stacky is offline
Joined Jan 2011
are you sure on the standard esc? Ive been told they use i2c by the British distributor?
Old Mar 06, 2011, 03:39 AM
timecop is offline
Joined Dec 2010
Well, that's interesting. No, I'm not sure but I was assuming they would go for standard controller. I don't have one and I've never seen close-up pics of their flight or motor controllers, so I don't know. Maybe that "british distributor" can post in here and clear it up
Old Mar 06, 2011, 03:42 AM
Quad_Addict is offline
Find More Posts by Quad_Addict
United States, IL, Chicago
Joined Dec 2006
Originally Posted by timecop View Post
Well, that's interesting. No, I'm not sure but I was assuming they would go for standard controller. I don't have one and I've never seen close-up pics of their flight controller or motor controllers, so I don't know. Maybe that "british distributor" can post in here and clear it up
yea its confirmed to i2c i guess, bummer really
Quad_Addict is offline Find More Posts by Quad_Addict
Old Mar 06, 2011, 03:45 AM
Stacky is offline
Joined Jan 2011
so if I was to replace the i2c in the t580 with timecops clever converter then bigger motors could be chucked on the T580 control system?
timecop is offline
Joined Dec 2010
Looks like you get to test it with my converter when your review copy gets there, heh.
Old Mar 06, 2011, 03:46 AM
Joined Dec 2006
man i tried to finish afro! i wish i didnt have to use i2c and all the soldering crap! i will get it going tomorrow for sure!
Old Mar 06, 2011, 03:47 AM
Joined Dec 2006
lol@copy
Old Mar 06, 2011, 03:48 AM
timecop is offline
Joined Dec 2010
If the protocol is same.. sure.
Otherwise, might need some changes in firmware if their I2C address is different or they transmit data differently etc.
Old Mar 06, 2011, 03:49 AM
Stacky is offline
Joined Jan 2011
timecop if I actually get one ( am on the tester list but not sure if it will actually happen) I will probably annoy you with some more of my dumb questions along those lines....
Old Mar 06, 2011, 03:51 AM
Joined Dec 2006
lol firstly you better realize the sarcasm! get past that and you will learn for sure!
ok off to bed!
Old Mar 06, 2011, 08:38 AM
Ab74 is offline
Find More Posts by Ab74
Philippines
Joined Dec 2010
waiting for the non-jitter version...=)
Ab74 is offline Find More Posts by Ab74
Old Mar 06, 2011, 10:07 AM
timecop is offline
Joined Dec 2010
PCBs for the "Tokyo drift-free" edition designed and submitted. Will start testing next week.
Board is same size (27x20mm), PWM connectors in same place, I2C connector moved to another side. Power either 5V from FC, 5V from BEC, or from Lipo (2-5S should be OK).
Firmware upgrade by serial bootloader (USB->FTDI->TXD/RXD/GND).
No promises on availability. "It's done when it's done". Hopefully the schedule is better than Duke Nukem Forever, though.
Discussion Arduino I2C to PWM converter 13brv3 DIY Electronics 17 Nov 01, 2011 08:23 PM
Discussion Converting NEW HK ESCīs from PWM to TWI/I2C control agressiva DIY Electronics 15 Jun 30, 2011 06:58 PM
Discussion New I2C to PWM converter for standard ESC obor Multirotor Talk 158 Feb 11, 2011 12:52 PM
Discussion I2C to PWM converter for use of standard ESCs in multicopters Arthur P. DIY Electronics 8 Feb 01, 2011 06:21 PM
Discussion TWI/I2C to 8x PWM converter for multikopters Arthur P. DIY Electronics 17 Nov 13, 2010 05:30 PM
