Old Oct 12, 2012, 01:43 PM
4stripes is offline
Find More Posts by 4stripes
4stripes's Avatar
Canada, ON, Burlington
Joined Jan 2009
Very impressive video Henke!
The camera platform works so well. My questions relate to the Venom's flown. What smoke system is used? What lighting system, and are the EDF's the factory stock Freewing setup?
Lastly, they seem to handle grass very easily. Are they stock landing gears?
Thanks Eric
4stripes is offline Find More Posts by 4stripes
Old Oct 13, 2012, 05:06 AM
henke is offline
Find More Posts by henke
310mph Kolibri T25 Swist
henke's Avatar
Sverige, Kronobergs Lšn, Ljungby
Joined Jan 2001
Thanks Eric
Hello,
The venoms are powerd by Kolibri T25 turbines, useing the turbine convertion kits available via HAB or ready2fly. (a kit for P20 is under development too) The smokesystem is smokefluid(like the super dri) injected behind the engine through a 0.7mm injection needle.
Landing gear are stock, but don't last very long, the units are changed one after another every 20 flight or so.
henke is offline Find More Posts by henke
Old Oct 13, 2012, 07:19 AM
4stripes is offline
4stripes's Avatar
Joined Jan 2009
Thanks Henke!
One last question, did you reinforce the wing spars?
I have a venom and wonder if the stock spars are good enough.
Cheers
Old Oct 13, 2012, 08:33 AM
PRITZ is offline
Find More Posts by PRITZ
Burlington On
Joined Aug 2006
venom
Eric: No Venom yet-AND-no reply to my E-Mail!! Cheers Ted
PRITZ is offline Find More Posts by PRITZ
Old Oct 13, 2012, 09:31 AM
henke is offline
henke's Avatar
Joined Jan 2001
Thanks Henke!
Cheers
Wingspars are strong enough, but we glue the wings to the fuselage as landings on grass makes the tube sloppy. The wheels are attached to the wing side so that the wing joint takes the punishment. Else a very strong airframe.
Old Oct 22, 2012, 07:05 AM
kydawg1 is online now
Find More Posts by kydawg1
"Aircraftus Fragmentum"
kydawg1's Avatar
United States, MI, Detroit
Joined Mar 2007
I finally was able to maiden mine. Nice Bird.
A pilot at my field shot a video of my maiden.....
Freewing 90mm Vampire Flown By Kydawg (4 min 49 sec)
kydawg1 is online now Find More Posts by kydawg1
Old Oct 22, 2012, 07:31 AM
PRITZ is offline
Burlington On
Joined Aug 2006
venom
Nice flite--still waiting for my kit. It's been 5 weeks--still no joy!! Cheers
Old Oct 23, 2012, 09:03 AM
kydawg1's Avatar
Joined Mar 2007
You will like her I am sure.
Old Oct 23, 2012, 11:13 AM
Mark 2 is offline
Find More Posts by Mark 2
Joined Aug 2011
Congrats - nice flying. Your Wemotec rotor sounds good.
Mark 2 is offline Find More Posts by Mark 2
Old Oct 27, 2012, 05:27 AM
EvanderH is offline
Find More Posts by EvanderH
EvanderH's Avatar
Delfzijl, Groningen, The Netherlands
Joined Jun 2008
Did anyone succeed in constructing a decent nosegear doorginge? And be able to post a picture of it?
Mine broke and i'm figuring out how to make a reliable one myself.
Thanks in advance.
EvanderH is offline Find More Posts by EvanderH
Old Nov 11, 2012, 04:12 PM
4stripes is offline
4stripes's Avatar
Joined Jan 2009
Very gusty crosswind but we did the maiden flight today. The stock fan was replaced with a balanced changesun 12 blade fan with 1600kv outrunner. Very powerful setup for this light model. My 5500mah 6S battery fit the compartment with little modification and balanced at the 110mm mark. The plane flies very realistically at less than half throttle and my 4:30 flight took only 3100mah. At full throttle the plane has almost 1:1 thrust.
Full flaps caused a strong pitch up but 1/2 flap seemed fine. I won't comment on the stall characteristics until it can be flown in smoother air.
Very pleased so far!
Old Nov 11, 2012, 04:36 PM
4stripes is offline
4stripes's Avatar
Joined Jan 2009
Thanks in advance.
Which part broke? We strengthened the two plastic tabs with some aluminum glued with jb weld. They are fragile and could likely be replaced with some bicycle spokes bent to the same shape and glued to the door.
Old Nov 14, 2012, 06:48 PM
4stripes is offline
4stripes's Avatar
Joined Jan 2009
Thanks the beautiful weather today we were able to do another 9 flights today with ideal conditions. Tested stalls with both flaps up and down and unfortunately this plane like to drop a wing. Raised both ailerons considerably, checked the wing to wing balance, tried trimming rudder but can't eliminate the tip stall. Reduced the elevator throw which helps so I may reduce it further on the next outing.
In spite of the wing dropping tendencies I still like the plane as it looks and sounds great in the air.
Will post some photo's and even a video link later tonight.
Old Nov 14, 2012, 07:21 PM
4stripes is offline
4stripes's Avatar
Joined Jan 2009
Changesun 90mm 12 blade EDF powered Venom (6 min 6 sec)
Old Nov 14, 2012, 07:48 PM
merlinfan is offline
Find More Posts by merlinfan
Throttle Bender
merlinfan's Avatar
Joined Jun 2008
Now I want one again.
merlinfan is offline Find More Posts by merlinfan
Build Log De Havilland DH-53 Hummingbird 53" of course Paul Susbauer Scale Kit/Scratch Built 59 Dec 13, 2015 12:20 AM
Sold De havilland tiger moth $160 shipped kevin finn Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 7 Oct 02, 2010 06:54 AM
Discussion de Havilland D.H. 112 Venom foxsavage Scratchbuilt Indoor and Micro Models 5 Jul 05, 2008 01:13 AM
Build Log de Havilland Venom ukdalai Foamies (Scratchbuilt) 13 Jan 11, 2007 05:39 PM
de havilland venom ryan d. Electric Ducted Fan Jet Talk 67 Jan 21, 2003 04:40 AM
