Old Aug 06, 2003, 07:10 AM
batman is offline
Find More Posts by batman
Baptised Heathen
batman's Avatar
Bundaberg, Qld, Australia
Joined Jun 2002
Converting weedeater engine
Can anyone tell me how difficult it is to convert a Weedeater Featherlite 18cc engine to aircraft use? What I am looking for is a conversion kit if such exists. If not, has anyone done the conversion on one of these? Any help would be appreciated.
batman is offline Find More Posts by batman
Old Aug 11, 2003, 02:37 PM
John Boren is offline
Find More Posts by John Boren
John Boren's Avatar
Colorado
Joined May 2003
Take a look at this website. They show how they convert a Ryobi engine to airplane use. Maybe you will get an idea of what needs to be done.
http://www.jagengines.com/
John Boren
John Boren is offline Find More Posts by John Boren
Old Aug 27, 2003, 08:14 PM
nateberry is offline
Find More Posts by nateberry
Joined Aug 2003
I am in the process of converting a McCoullch weed whacker into an aircraft engine. should have it done in a couple of weeks.
you will need access to a machine shop for the milling of the flywheel, other components can be machined or purchased.
Lots of information at www.carrprecision.com I believe that is the correct address. they will sell you the parts or convert your engine. Good Luck
Nate
nateberry is offline Find More Posts by nateberry
Old Sep 22, 2003, 09:36 AM
echo is offline
Find More Posts by echo
Eagle Lake, Mn. 56024
Joined Sep 2003
I can send you a picture of a converted weedie which has a lot of detail and will also give you some tips but I will only do this at your request. Echo
echo is offline Find More Posts by echo
Old Sep 20, 2007, 04:19 AM
sprocket1 is offline
Find More Posts by sprocket1
sprocket1's Avatar
Griffith , N.S.W
Joined Sep 2007
Hi , I converted a still whipper snipper engine . Cut off all the unwanted weight , flywheel and all , made a hub to slip on the taper with a keyway and bought desert aircraft ignition so I could get it to run the correct way for a std. prop.end result for the 18cc engine was 6000 rpm running a 13/6 wooden prop...........
very easy conversion p.s. the engine is for sale if your interested
cheers Ian
sprocket1 is offline Find More Posts by sprocket1
Old Sep 20, 2007, 10:06 AM
ivanc is offline
Find More Posts by ivanc
S.A.D. member
ivanc's Avatar
United States, TX, Round Rock
Joined Dec 2004
cheers Ian
Hmmm, not much power for an 18cc (1.10cu.in.) engine. My 70 4-strokes spin the same size prop over 10,000rpm.
What is the weight of the engine with the ignition and battery for it?
Ivan
ivanc is offline Find More Posts by ivanc
Old Jan 07, 2013, 07:13 PM
irun4fundotca is online now
Find More Posts by irun4fundotca
Flying Wood For Fun
irun4fundotca's Avatar
Canada, ON, Harrowsmith
Joined Jan 2012
i know its an old thread but heres is some various diy kits
http://www.carrprecision.com/Pages/prod02.htm
irun4fundotca is online now Find More Posts by irun4fundotca
Old Jan 08, 2013, 06:48 AM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
We also have a thread going on about it here too http://www.rcgroups.com/forums/showthread.php?t=1762575
It might give you some ideas too.
earlwb is offline Find More Posts by earlwb
For Sale ofna dominator and deluxe conversion with a 30cc weedeater engine, both rtr spydee Cars - Cars and Parts (FS/W) 0 Oct 02, 2006 11:53 AM
Discussion Preparing weedeater engine for boat enya.19 Racing Boats - Internal Combustion 2 Jul 21, 2006 01:16 PM
Discussion 18cc weedeater engine enya.19 Racing Boats - Internal Combustion 1 Jul 15, 2006 04:16 PM
Discussion Converting a Pusher Engine into a Puller Starguard Fuel Plane Talk 7 Apr 20, 2006 08:45 AM
