Old Feb 28, 2011, 09:55 PM
JoelRSails is offline
Find More Posts by JoelRSails
JoelRSails
JoelRSails's Avatar
Houston, TX
Joined Jul 2004
Best EPP flying wing as a powered glider
Which of the EPP wings (with what motor/battery combo) would you list as the best powered glider? (i.e. climb with motor power, and then ability to soar for a long time)
JoelRSails is offline Find More Posts by JoelRSails
Old Feb 28, 2011, 10:36 PM
Outback Joe is offline
Find More Posts by Outback Joe
September 2010
Outback Joe's Avatar
United States, OR, Lakeview
Joined Oct 2009
Old wing but with a light motor and lipo the Slinger does great in moderate lift. I am using a Turnigy 2826-1650 with a 7x6 prop 1300 mAh lipo and can get into thermals for over a half hour.
Outback Joe is offline Find More Posts by Outback Joe
Old Feb 28, 2011, 10:53 PM
PaulVi is offline
Find More Posts by PaulVi
resU deretsigeR
PaulVi's Avatar
Dublin Ca
Joined Aug 2004
im partial to my updraft 60.... but it your looking for thermal duration most wings are not going to be it...
PaulVi is offline Find More Posts by PaulVi
Old Mar 03, 2011, 10:18 AM
Camelboy is offline
Find More Posts by Camelboy
Prog Rocker
Down South
Joined Jul 2009
I have a Swift 2, with just a cheap GWS motor, and have managed to get 20+ minutes of flight with it, with a 3cell 910 battery.
Camelboy is offline Find More Posts by Camelboy
Old Mar 03, 2011, 08:28 PM
cgoffa is offline
Find More Posts by cgoffa
cgoffa's Avatar
Joined Dec 2009
maxi lift from the maxi swift
I think the maxi swift is a better sailplane as it has a thicker airfoil and will fly very slowly if built light, I poly-glassed mine with 3/4 oz glass and use it to fly a small camera. its definitly the floaty-est wing i have
cgoffa is offline Find More Posts by cgoffa
Old Mar 06, 2011, 12:07 PM
Up&Away is offline
Find More Posts by Up&Away
The original Flying Pigs Sqd.
Up&Away's Avatar
Netanya, Israel
Joined Aug 2002
The Unicorn. At it's original 48" she's a great soarer.
Up&Away is offline Find More Posts by Up&Away
Old Mar 06, 2011, 02:42 PM
gazza2003au is offline
Find More Posts by gazza2003au
gazza2003au's Avatar
Sydney, Australia
Joined Jul 2003
windrider elebee glides forever on landing
gazza2003au is offline Find More Posts by gazza2003au
Old Mar 07, 2011, 11:29 AM
Daddy-O is offline
Find More Posts by Daddy-O
John 3:16
Daddy-O's Avatar
Dom. Rep.
Joined May 2003
I second the Unicorn. The best gliding wing I have seen.
Daddy-O is offline Find More Posts by Daddy-O
Old Mar 24, 2011, 11:25 AM
rotagen is offline
Find More Posts by rotagen
Scratch building addict
rotagen's Avatar
United States, CA, Felton
Joined Jan 2005
You must check out the MWC Starfire. I just ordered one. The vids I have seen on youtube are brilliant. The price is amazing. And its shape is perfect. Compound sweep very efficient and there is a coool build forum on RCgroups .
I will most likely make mine with a pusher folding prop if I can figure how to make the fold prop work as a pusher.
http://www.mwcores.com/servlet/Detail?no=183
rotagen is offline Find More Posts by rotagen
Old Mar 27, 2011, 02:12 AM
foufly is offline
Find More Posts by foufly
Joined May 2010
best soaring wind
Hi, take a look at my blog - the photos beneath - the one I call Skua is the best all rounder, very flat glide, any turn without height loss, and acrobatic. Good luck.
foufly is offline Find More Posts by foufly
Old Mar 28, 2011, 08:03 AM
e_lm_70 is offline
Find More Posts by e_lm_70
Austria
Joined Jan 2004
Got over 30min of fly - glides (without slope or thermal help) , on my ele-bee with 2S Lipo 4800mAh ...
Yes ... landing is slow and nice ... and still ... with a good motor can be very fast too
Tchuss
e_lm_70
+ What is nice, it is that take standard servo size (not the mini), lot of space for the electronic and battery
- Stock motor mount is not perfect ... but still is ok for hot glue Brushless inrun motors ... 2000/3000 RPM is on 3S Lipo is the motor needed for this wing
e_lm_70 is offline Find More Posts by e_lm_70
Build Log Build Thread - Pixie 20" Symmetrical Electric Flying EPP Wing Blue Note Flying Wings 28 Nov 10, 2011 09:32 PM
Discussion Flying Wing from Kid's Foam Glider JohnStarnes Foamies (Scratchbuilt) 3 Oct 08, 2010 08:35 PM
Discussion Flying Wing from Kid's Foam Glider JohnStarnes 3D Foamies 1 Oct 08, 2010 09:31 AM
Check this out!! GWS powered epp flying wing!! slowflyer Parkflyers 4 Jul 23, 2001 09:29 AM
