Old Oct 10, 2012, 01:25 PM
carl3 is offline
Find More Posts by carl3
Leonard Mi
Joined May 2010
supertigre .10?
ST.10 is 10 grams heavier than the Microdan 1300kv and comes in at 1290 kv
anybody try one on the 42 inch Fancyfoam planes ..I'm shoppin for new motors
or gonna have to rewind some TP 2409-12t's
never mind..Jerry already answered that for me earlier..looks like I'm gettin some Supertigre's
carl3 is offline Find More Posts by carl3
Old Nov 07, 2012, 05:37 PM
gregory.da is offline
Find More Posts by gregory.da
ProBro, 3D
gregory.da's Avatar
United States, FL, The Villages
Joined Jul 2008
Anyone tried using Kylon Short cuts rattle can paint? I used the Fl. Orange on my Freestyle and after it dried it kind of like comes off like dust if you rub against it with your hand (found out during the assembly of the foam). I also used just some no name black and fl. yellow I had lying around and those seem fine so far. I'll take a photo of it and post it later tonight. I copied the WMPF paint scheme for the top, and the 3dhs AJ Slick blocks for the bottom I added some addiitonal cf bracing from the fuse to the wings, and extended the wing spar about 2 more inches, and added an epp tail skid to protect the rudder. I'll have it ready to go next week, waiting on the motor to arrive. I can't wait to see it in the air and put it though it's paces. My previous FancyFoam Edge was fun, but it was getting too heavy from glue repairs, and brittle from using Welders, so I retired it. I used Beacon Foam Tac for this build. I like it better than Welders, it stays clear (no yellowing in the sun), and stays flexible .
My setup:
1-9g Htx servo on the ailerons
2- 6g Power HD DSM44's for the tail (they are digital mg, and super fast).
Motrofly 2205-1750kv on 2s in calm winds and 3s for windy days and crazy power. Everything I've read is that's the motor to go with, same weight as the Turnigy, but much more power.
12A ESC
AR6110e Rx
2 and 3s GensAce 450mAh Lipos
GMS 8x4.3SF and 8x4dd props
gregory.da is offline Find More Posts by gregory.da
Old Nov 07, 2012, 06:31 PM
motorhead is online now
Find More Posts by motorhead
motorhead's Avatar
Kansas, USA
Joined Sep 1999
Pictures?
motorhead is online now Find More Posts by motorhead
Old Nov 07, 2012, 07:14 PM
ProBro, 3D
gregory.da's Avatar
Joined Jul 2008
Here you go: Pics are up.
Old Nov 10, 2012, 06:04 AM
funflyr is offline
Find More Posts by funflyr
funflyr's Avatar
Gardner Kansas (S. Kansas City)
Joined Dec 2005
Originally Posted by gregory.da View Post
Anyone tried using Kylon Short Shot rattle can paint? I used the Fl. Orange on my Freestyle and after it dried it kind of like comes off like dust if you rub against it with your hand (found out during the assembly of the foam). I also used just some no name black and fl. yellow I had lying around and those seem fine so far. I'll take a photo of it and post it later tonight. I copied the WMPF paint scheme for the top, and the 3dhs AJ Slick blocks for the bottom I added some addiitonal cf bracing from the fuse to the wings, and extended the wing spar about 2 more inches, and added an epp tail skid to protect the rudder. I'll have it ready to go next week, waiting on the motor to arrive. I can't wait to see it in the air and put it though it's paces. My previous FancyFoam Edge was fun, but it was getting too heavy from glue repairs, and brittle from using Welders, so I retired it. I used Beacon Foam Tac for this build. I like it better than Welders, it stays clear (no yellowing in the sun), and stays flexible .
My setup:
12A ESC
AR6110e Rx
I had the exact same thing happen with the orange. I have been using the shortcuts for years and this is the only time I have had a problem.
Troy
funflyr is offline Find More Posts by funflyr
Old Nov 12, 2012, 05:37 PM
ProBro, 3D
gregory.da's Avatar
Joined Jul 2008
Thread seems to have died, I thought there would be more interest in these since Winter is around the corner and folks will be moving to indoor flying. I just finished up shooting a thin coat of Lustercote clear that I had on hand over the fl. orange paint. I hope that helps keep it from turning into powder, we shall see when it dries .
Old Nov 13, 2012, 06:41 AM
motorhead's Avatar
Kansas, USA
Joined Sep 1999
Yea, we are just starting to get in to indoor mode here. It is finally getting cold. Working on a new paint scheme for the kits. Need to get it done.
Old Dec 31, 2013, 11:26 PM
Lobe_DethFaurt is offline
Find More Posts by Lobe_DethFaurt
Lover of fine cheeses
United States, IN, Mauckport
Joined Jan 2012
Hey all...I plan on buying the 42" freestyle soon, but I have a few questions first.
1) 1.5lb or 1.9lb epp?
2) I plan on using a 72g omega and 3s 1300mah...what size prop should I use?
I think that's all for now...thanks in advance!
Lobe_DethFaurt is offline Find More Posts by Lobe_DethFaurt
Old Jan 01, 2014, 08:29 AM
Rickn816 is offline
Find More Posts by Rickn816
RCHN #150
Rickn816's Avatar
Lawrenceville, GA
Joined Nov 2007
1) Where are you going to fly it? If outdoors, I recommend the 1.9 and landing gear.
2) Can't help. Don't know that motor - kV, watts, etc.
Rick
Rickn816 is offline Find More Posts by Rickn816
Old Jan 01, 2014, 12:20 PM
Joined Jan 2012
Thanks for the response, Rick! I was worried that I was poking at a dead thread...
Omega 72g motor specs:
Peak amps-40
Peak watts-425
Weigt-72 grams
Kv-1100
Also, yes I plan on flying outside. Further info: I have a twisted hobbys 45a esc (sbec) and 4x twisted hobbys mg65 servos, all of which shall go into this airplane. The batteries, aero-model 3s 1300mah 30c, weigh 104g or 3.667 ounces each.
All equipment is from an ill-fated 3dhs 40" EPP Edge...
Old Jan 01, 2014, 06:54 PM
motorhead's Avatar
Kansas, USA
Joined Sep 1999
You will be fine with the 1.9lb. It is a little stiffer airframe. I would only recommend the 1.5 if someone is trying to build a light one with a 50g motor.
Old Jan 01, 2014, 07:20 PM
Joined Jan 2012
Awesome, thanks!
Another quick question: what is the wing area on this plane (42 inch)?
Old Jan 02, 2014, 06:54 AM
Rickn816 is offline
RCHN #150
Rickn816's Avatar
Lawrenceville, GA
Joined Nov 2007
Peak amps-40
Peak watts-425
Weigt-72 grams
Kv-1100
You are going to do a little trial and error. The prop will be somewhere between 9 and 11 inches. Slow flying, so don't use a prop with lots of pitch. 3 - 4 should be OK.
Start with the smaller and increase the size until the motor gets warm.
Rick
Old Jan 02, 2014, 07:06 AM
Joined Jan 2012
Rick
Ok, thanks!
One more question: How much does the airframe of the 1.9lb epp version weigh by itself?
Old Jan 02, 2014, 07:16 AM
Rickn816 is offline
RCHN #150
Rickn816's Avatar
Lawrenceville, GA
Joined Nov 2007
Ok, thanks!
Shipping weight is 1.5 pounds. Don't know if that includes the carton.
Rick
Yippee! e-foamy sbach 342 maiden larsy87 3D Foamies 26 Nov 01, 2010 10:25 PM
Sold Blade SR Belt drive tail kit by Freestyle-Hobby minirips2 Aircraft - Electric - Helis (FS/W) 2 Oct 06, 2010 02:02 PM
Yippee! Edge 540 From E-Foamy.com Finished bakon Foamies (Kits) 0 Oct 04, 2010 10:29 PM
Video 3D-Freestyle to Music by BPLR Jurgen Heilig Electric Plane Talk 6 Oct 11, 2006 03:41 PM
