Old Aug 05, 2003, 11:49 PM
Heli Slime is offline
Find More Posts by Heli Slime
Formerly Black96Z
Heli Slime's Avatar
Mckinney, TX
Joined Apr 2002
Motor setup for a Mini graphite
What motor setups are MG fliers using? I am running numbers on motocalc and nothing seems to be producing good numbers to try out.
David
Heli Slime is offline Find More Posts by Heli Slime
Old Aug 06, 2003, 01:22 AM
soholingo is offline
Find More Posts by soholingo
BANNED!!!
soholingo's Avatar
Laurel, MD
Joined May 2001
Try a hacker 6L w/ a 6.7:1 gearbox 10 cells hrsc2600 16x13 prop by the way where did you get your minigraphite?
Jay
soholingo is offline Find More Posts by soholingo
Old Aug 06, 2003, 06:50 AM
Formerly Black96Z
Heli Slime's Avatar
Mckinney, TX
Joined Apr 2002
I"m getting it strait from Barry Kennedy. I have a few friends that are good friends with him, and I have met him a few times. I just called him up. He said he had 2. Also, there is a new item that he got with them. Its some custom Vladimir made wing bags that are designed for the plane. I'm going to get one of hose too. I'm going to pick it up saturday from his house I think.
David
Old Aug 06, 2003, 08:04 AM
davidleitch is offline
Find More Posts by davidleitch
Tragic case
davidleitch's Avatar
Sydney Australia
Joined Feb 2002
David
Jay's setup will produce hotliner climb rates and dive speeds, but that is not the only way to fly the MG. The 6L with 7xcp1700 or faup 1950 would also climb the plane vertically, or close to it, and the sink rate will be far slower. if you are trying to thermal there will be far more chance of actually recognising a thermal on a lower loading. Your call.
davidleitch is offline Find More Posts by davidleitch
Old Aug 06, 2003, 08:50 PM
Formerly Black96Z
Heli Slime's Avatar
Mckinney, TX
Joined Apr 2002
When you say the 6L thats the F5F motor right? Could, with diffrent packs, it be a multi purpose plane?
David
Old Aug 06, 2003, 09:38 PM
BANNED!!!
soholingo's Avatar
Laurel, MD
Joined May 2001
David
I am assuming that you mean will you be able to thermal with this plane? The answer is yes. With 10 cells the plane should still be light enough to thermal, yet have enough weight to keep it's energy.
Old Aug 06, 2003, 10:24 PM
Formerly Black96Z
Heli Slime's Avatar
Mckinney, TX
Joined Apr 2002
Cool. I will post some pictures this weekend when I pick it up, also pics of the wing bags.
David
Old Aug 08, 2003, 07:32 AM
Joni Piililä is offline
Find More Posts by Joni Piililä
Joni Piililä's Avatar
Finland
Joined Sep 2001
It will thermal even when heavy. My setup is 2.4 Kg (about 86 oz not sure about my conversion of Kg to oz.)
Regards
Joni
Joni Piililä is offline Find More Posts by Joni Piililä
Old Aug 08, 2003, 07:33 AM
Formerly Black96Z
Heli Slime's Avatar
Mckinney, TX
Joined Apr 2002
what is your setup?
David
Old Aug 08, 2003, 07:57 AM
Finland
Joined Sep 2001
Hi David,
Motor is Torcman 350/28 14 wind with extension shaft. (No gearbox). Hacker Master 77 controller. Cells are 18 zapped&matched CP1600 (same cell known as CP1700 too). RFM 14.5x14 prop. With this setup this MG accelerates even when vertical. Volz servos in wings and tail. With Aeronaut 15x10 prop static thrust is better but lower high speed.
Only one thing worries me is the two piece wing, I just don´t want to pull too many G as I´m alfraid that it could break.
Joni
best motor setup for mini funtana nappyroots2182 3D Flying 40 Feb 16, 2005 12:50 AM
motor setup for 1/2 size mini ifo opualuan Scratchbuilt Indoor and Micro Models 18 Jan 11, 2003 02:20 PM
Motor Upgrade for Mini Tornado HavingFun2002 Foamies (Kits) 1 Apr 22, 2002 07:38 AM
CNC setup for mini mill from harbor freight stealthy Life, The Universe, and Politics 0 Jan 21, 2002 03:32 AM
Best motor setup for Aspire glider Steve H. Electric Sailplanes 13 May 01, 2001 09:56 AM
