Old Feb 27, 2011, 12:16 PM
Mauricio2346 is offline
Find More Posts by Mauricio2346
Mauricio2346's Avatar
Medellín, Colombia
Joined Jan 2010
Realflight with Turnigy 9X
Hi folks. last friday i got a Turnigy 9X. it has 8 channel with 2.4Ghz module.
after some problems i could get it work fine with my realflight 4.
how can i get realfight to recognize more than 4 channels?
its very frustrating to use a 8 channel radio and fly with 4 channel on PC
Thanks!
Mauricio2346 is offline Find More Posts by Mauricio2346
Old Feb 27, 2011, 06:53 PM
Duckie62 is offline
Find More Posts by Duckie62
HELP!!! I'VE BEEN CAUGHT !
Duckie62's Avatar
United States, WA, Lacey
Joined Oct 2005
4 Channels
I am by far probably the last person you should take advise from. My advise normally gets me in trouble with the wife,when she listens to what I have to say. (HA HA!!!) What makes you think you are only using 4 CH. ?
Are you and have you configured your NEW transmitter.
Start RealFlight,connect the transmitter in series-per directions,then Click on CONTROLLER,--CHANNEL MAPPING, Then try the bells and whistles on the NEW controller. You should see the blue bar's change with each switch or knob that you move.
I found this a few questions down:
Setting up Turnigy 9x tx for simulators - 10 days old
ferdous7466
Duckie62 is offline Find More Posts by Duckie62
Old Feb 27, 2011, 07:11 PM
Medellín, Colombia
Joined Jan 2010
ferdous7466
in fact, i made everything you said. just only 4 channels (yaw, pitch, throttle and roll) moves with sticks. no movements on blue bars of real flight by moving knobs and switches of the radio.
so, at this point im using just 4 channels from my radio. channel 5 from the radio is attached to gear switch. channel 6 of the radio is attached to a knob.
Regards;
Old Mar 02, 2011, 09:54 PM
dskalski is offline
Find More Posts by dskalski
Turn up the G's !!!!
dskalski's Avatar
United States, VA, Virginia Beach
Joined Jul 2010
Do you have those assigned switches and knobs controling anything? I know in fms (at least from my using of it) if you don't have a channel controling anything it won't see the channel. Try setting a switch or knob to control a servo in the tx and see if that works.
dskalski is offline Find More Posts by dskalski
Old Aug 11, 2011, 04:16 AM
Bloowl is offline
Find More Posts by Bloowl
Joined Aug 2011
Hello,
I also have a turnigy 9x.
It' my first transmitter and plane.
Before going in the air I want to practice with Realflight...and the 9x
Can you give some descriptiojn how to hook up my turnigy to the computer and get it working with realflight?
Realflight normally is USB, isn't it???
I already tried earlier descriptions with another soft , made a selfmade cable to connect to the audio in of my computer, but the soft (FMS) doen's seem to react)
I woul be very thankful for your detailed description...
Regards,
Bloowl...
Bloowl is offline Find More Posts by Bloowl
Old Aug 11, 2011, 06:24 AM
jeffpn is offline
Find More Posts by jeffpn
Joined Mar 2011
Interesting question. Leads me to believe you did not buy RF.
jeffpn is offline Find More Posts by jeffpn
Help! Can't get my Turnigy 9X to work with Phoenix agent1940 Simulators 1 Oct 22, 2010 01:42 AM
Discussion How to use TH9x (Turnigy 9x, etc) with DX6 in trainer mode? polar8 Radios 7 Oct 19, 2010 03:04 AM
Question Turnigy TGY 9X with Corona 2.4Ghz - Very short range giluriel Radios 5 Aug 01, 2010 10:20 AM
Sold Turnigy 9X, with Spektrum Module 2.4ghz $90 Shipped crd Aircraft - General - Radio Equipment (FS/W) 5 May 15, 2010 09:45 AM
FAQ Binding/Synching the Turnigy 9x, with their module to the 4ch rx. Ravenseye Radios 0 May 10, 2009 09:41 PM
