Old Feb 20, 2012, 05:14 PM
G-LO is online now
Find More Posts by G-LO
G-LO's Avatar
Va.Beach VA.
Joined Aug 2007
Thanks .
G-LO is online now Find More Posts by G-LO
Old Feb 20, 2012, 06:51 PM
hardlock is offline
Find More Posts by hardlock
hardlock's Avatar
United States, OR, Springfield
Joined Aug 2000
Originally Posted by harrisdouma View Post
G-Lo
...... i got the RTF version. because it directions do not list center of gravity
and company said RTF version positioned in right spot so now i do not have
to worry about Center of gravity and supplied radio is supposed to be trimmed
out correctly to fly bird
No directions on CG? Since you got the RTF, maybe you can pass on the stock CG location with the factory setup for this uninformed consumer?
hardlock is offline Find More Posts by hardlock
Old Feb 20, 2012, 07:52 PM
harrisdouma is offline
Find More Posts by harrisdouma
Beaver Dam.Wi.
Joined Jan 2003
measuring from the front of the wing close to the body going back
I come up with 4 inches
harrisdouma is offline Find More Posts by harrisdouma
Old Feb 20, 2012, 07:54 PM
hardlock is offline
hardlock's Avatar
Joined Aug 2000
Thanks much for that! I'm sure it will be helpful.
Old Feb 20, 2012, 08:22 PM
Beaver Dam.Wi.
Joined Jan 2003
More info on silk screen painted rc eagle by www.gootchrc.com
The wingspan is 6 ft, 7In.
The thrust vectering motor servo is coupled to the wing servo by a y harness.
So this means that when the motor turns left the right wing goes up and vice versa
I think if the motor would stop in flight you would still have control of eagle with
elevator servo and wing servo.
Old Feb 20, 2012, 08:42 PM
G-LO is online now
G-LO's Avatar
Va.Beach VA.
Joined Aug 2007
Do you think that it can be modded into a pusher? Just a thought....
Old Feb 20, 2012, 09:02 PM
Beaver Dam.Wi.
Joined Jan 2003
I don.t think very likely since the rear of the tail is used as elevator
and is controlled by elevator servo..
Also if you were to move the trust vectoring motor from the front
of the eagle to a spot further back on the eagle. I thing you would cause a
major center of gravity problem
Old Feb 20, 2012, 09:23 PM
G-LO is online now
G-LO's Avatar
Va.Beach VA.
Joined Aug 2007
What I mean is not relocating the motor stick to the back tail area. But, unscrew the motor from the front of the mount to the back of it. Thus a pusher.
Old Feb 20, 2012, 09:38 PM
Beaver Dam.Wi.
Joined Jan 2003
Ok I see what you mean. Yes you can move the motor from front of mount
to back of mount. You would have to go to a smaller prop.since the stock prop
would hit the top of the body. also remember the motor directional servo
is connected to the wing servo. by a y harness, But all in all it might work.
What do you think might be an advantage of pusher configuration
Old Feb 20, 2012, 09:41 PM
hardlock is offline
hardlock's Avatar
Joined Aug 2000
...The thrust vectering motor servo is coupled to the wing servo by a y harness.
So this means that when the motor turns left the right wing goes up and vice versa.
That mixing would explain the one video where every time the plane turns, it noses down.
That's just like a coupled rudder/aileron plane does if you hold the stick over too long due to the rudder becoming a down elevator once the plane is banked.
You may want to run them separate if you're comforable with full house controls.
Oh, and what were your shipping costs if you don't mind me asking?
Old Feb 20, 2012, 09:48 PM
G-LO is online now
G-LO's Avatar
Va.Beach VA.
Joined Aug 2007
What do I think the advantage of making it a pusher.... none that I could think of, just thinking out loud ..
hardlock is offline
hardlock's Avatar
Joined Aug 2000
I thought about reversing the motor also for use with a folding prop for soaring. Probably would work also as a puller but may not fold as far or could hit the post when opening.
Ideally the motor and boom could be retracted into the body for drag reduction but as already mentioned, the CG change would prevent this. Maybe a compensating weight shifting of the battery or other method could be used for CG trim but that's getting too complicated.
Old Feb 20, 2012, 10:03 PM
Beaver Dam.Wi.
Joined Jan 2003
Hardlock
Shipping cost were $44.00
The eagle arrived 4 days after it was shipped I
Hardlock I have sent you a PM
Old Feb 20, 2012, 11:36 PM
Beaver Dam.Wi.
Joined Jan 2003
Just received an email from rita@goothrc.com
Rita told me they will no longer be sellingl the silk screen painted RC eagles
to hobbyist. Rita said if you want one you will have to buy an eagle
in the U.S.A. from www.acesim.com which is run by Ken Hill
who is hardrock on this board. he is one of the good guys!l
Old Feb 21, 2012, 08:32 AM
STRINGFLY is offline
Find More Posts by STRINGFLY
STRINGFLY's Avatar
Little Rock Regional, Arkansas, United States
Joined Sep 2002
Boy, hardlock works fast !!!! He's great to do business with !!!
Stringfly <>+++++
http://item.taobao.com/item.htm?spm=...*&id=141398633
These are about 6 1/2 foot span and go for about 8.00 in China.
STRINGFLY is offline Find More Posts by STRINGFLY
Discussion RC Kites TheNiceGuy New Forum Requests 68 Aug 11, 2011 01:13 AM
Discussion RC Vector Kites proposal Harry D Site Chat 15 Feb 15, 2011 01:28 PM
Discussion Premier RC Kites flimnar Parkflyers 7 Feb 01, 2011 07:02 AM
Discussion Premier RC powered kites ghoti Aerial Photography 2 Nov 19, 2010 02:56 PM
