Old Apr 12, 2011, 01:00 AM
harrisdouma is offline
Find More Posts by harrisdouma
Beaver Dam.Wi.
Joined Jan 2003
Hi Patron.
You did what I was thinking of doing to my Premier eagle RC kite
You changed the moter to the heavier Micro Dan 2510 3d -970 kv moter
I was concerned that the heavier moter would put extra strain on the
Premier vector power unit servos. Am I to assume that the stock servos
of the vector power unit handled the extra weight of the heavier moter?
Also when you switched to the more powerful Micro Dan moter did you
change to different size bullet connectors or did you match the moter
to the vector unit's speed control 2.0 MM bullet connectors?
harrisdouma
harrisdouma is offline Find More Posts by harrisdouma
Old Apr 12, 2011, 08:53 AM
Patron is offline
Find More Posts by Patron
Account closed - user passed away
Patron's Avatar
Chicago
Joined Nov 2009
Hi harrisdouma,
The stock servos worked just fine and I didn't change anything else because the new motor with the larger props actually draw less amps than the stock motor.
The only thing I am going to do is change the JST connectors to Deans because I still want to try some 2100 mAh batteries for longer flight times and I think the JST's are just a little too small.
Patron is offline Find More Posts by Patron
Old Apr 12, 2011, 07:24 PM
harrymc is offline
Find More Posts by harrymc
Just Happy To Be Here!!!
harrymc's Avatar
United States, AL, Tuscaloosa
Joined Nov 2004
Mike,
I made a pigtail with JST on one end and male deans connector on the other. I stuck the JST connector and about 3"of wire through to the top of the Eagle leaving about 4" with the deans connector on the inside of the Eagle. I tied a couple of small black zip ties on the top side of the pigtail leaving 1/2" zip tie "fingers" sticking out, this keeps the pigtail from being pulled back through the slit in the fabric. Leaving this pigtail in the Eagle saves time. Just plug in the power unit in the top side and plug in your battery inside the Eagle. No more trying to find the slit and thread the wire through each time you put the Eagle together.
Harry
harrymc is offline Find More Posts by harrymc
Old Apr 25, 2011, 11:11 AM
JIMFRISKY is offline
Find More Posts by JIMFRISKY
Jimfrisky
United States, CA, Simi Valley
Joined Jan 2001
price
Worth it . But hard for those who are on SSI And to new to be much used
JIMFRISKY is offline Find More Posts by JIMFRISKY
Old Apr 25, 2011, 01:59 PM
harrymc is offline
harrymc's Avatar
Joined Nov 2004
Huh???
With the cost of living these days, anyone on a low fixed income looking at any nonessential items are a luxury they can't afford. How is this any different?
Old Apr 26, 2011, 08:26 PM
Jimfrisky
Joined Jan 2001
Worth it
Originally Posted by harrymc View Post
Huh???
If you love something you will find a way
Old May 05, 2011, 08:44 AM
Patron is offline
Patron's Avatar
Chicago
Joined Nov 2009
UPDATE - MicroDan motor
9x4.7 APC-SF Prop - this is the largest prop diameter you can run without the prop rubbing on the body when the Eagle is in flight with and the body is inflated.
IMHO, the MD motor with the APC 9x4.7 prop is a big improvement over the stock setup.
My conclusion is that even though the MD motor and 9x4.7 prop gives more thrust, this kite is best flown in light winds. It's much more fun to fly in light wind conditions.
Old May 15, 2011, 07:50 PM
Beaver Dam.Wi.
Joined Jan 2003
Hi All
My eagle flys great yet! I was thinking of cutting off the 2 legs. since they just
seem to dangle out there. I think it might give the eagle less drag, less weight,
and maybe make it more aerodynamic? Any thoughts on this??
Old May 15, 2011, 07:58 PM
harrymc is offline
harrymc's Avatar
Joined Nov 2004
You'll see no difference without the legs. The airframe has tons of drag and the legs gone will do nothing you can tell, to help. If you don't like the way it looks with the legs hanging out, that's another matter. Poor legless bird!
Old Jun 27, 2013, 12:56 AM
Tom in Cincy is offline
Find More Posts by Tom in Cincy
Tom Para
Tom in Cincy's Avatar
Cincinnati, Ohio, United States
Joined May 2003
After 2 + years I finally ordered one. I hope to make my own power unit. does anyone have close up photos of the ready made unit that I could use to work off of??
Tom in Cincy is offline Find More Posts by Tom in Cincy
Old Jun 27, 2013, 03:58 PM
Beaver Dam.Wi.
Joined Jan 2003
Hi Tom in cincy
When I bought the smaller thust vectoring eagle I also purchased the
gimble and frame for $48 added my own electronics and was ready to fly.
to see large photo of gimble and frame go to www.premierrc.com
than click on buy online and than go to parts section where you will see gimbles
and other parts of the power unit. hope this helpful?
Old Jun 27, 2013, 09:31 PM
Tom Para
Joined May 2003
Thanks for the link. I was able to see the parts. The gimble and frame is about $56. I'll have the Eagle tomorrow and can then evaluate if I can make my own or not. Maybe you can tell me where the cg is and how far out from the mounting rods the the motor sits.
thanks
Old Jun 28, 2013, 04:10 PM
Beaver Dam.Wi.
Joined Jan 2003
Hi Tom in Cincy
I modified my eagle long ago I fly with 3 cell thunderpower 2100 batteries
I put in micro dan 2510 970kv moter for more power, I use 10X6 GWS prop. and
flattened out top of body so prop does not hit it. I can not tell you where the stock moter
should sit. I threw away the stock moter because I found it to be a bit underpowered
to my way of thinking (micro dan moter is heavier)
Center of cravity can be found through trial and error. generally between the
back of the front Velcro strip and the front of the rear Velcro strip You will know when
you have center of gravity right
Patron mentions on page 3 of this thread where he put the size battery he used for balance
Good luck.
l
Old Jun 28, 2013, 08:41 PM
Tom Para
Joined May 2003
Ok Very good. I got my Eagle kite today from Horizon in good shape. The triangle motor support sets the width of the frame at about 2 3/8" on centers and with the photos on Premiers site of the frame (being pretty square on) I was able to scale up the picture and get some accurate sizes.
I have the frame and gimble about 50% there. I hope to have it done by tomorrow.
Thanks for your posts. They do help...
Old Jul 15, 2013, 11:38 AM
Tom Para
Joined May 2003
I got to maiden the Eagle yesterday. It flew without incident. I first flew it on a 1300mah pack for 4 minutes and depleted the pack by 50%. On the second flight I tried a 2200mah but noticed it was difficult to gain much altitude. I am guessing the weight of the battery is too much. It was blowing about 8-10 mph and made flying a bit more difficult. I think it also hampers the eagles ability to gain a lot of height, at least wind does with my ornithopter.
The vector thrust unit is homebuilt and costs under $50 for materials.
So far I am liking it alot.
Discussion Scratchbuilt vector kite: ultra slow flier slebetman RC Paragliders and Kites 60 Mar 19, 2013 09:18 AM
New Product NEW! MONSTER THRUST VECTOR EDF F22 buy the RTF get ARF kit free? rjp0325 Electric Ducted Fan Jet Talk 17 Sep 24, 2010 07:12 PM
Discussion Vector-thrust pusher with 3-axis gyo, anyone ever build? learn2turn Foamies (Scratchbuilt) 8 Sep 23, 2010 06:34 PM
Discussion SU34 360 thrust vector on lightweight 3s & hand launch topforce Foamy EDFs 2 Sep 15, 2010 04:45 AM
Discussion JAS 39 360 VECTOR THRUST about to click Buy it Now. need advise airbagit13 Foamy EDFs 3 Sep 08, 2010 11:28 AM
