Old Aug 05, 2003, 05:44 AM
Cush is offline
Find More Posts by Cush
Gentleman, scholar and acrobat
Cush's Avatar
United Kingdom, England, Poole
Joined Mar 2001
Corona – how twitchy is your rudder servo?
Corona
HS81 MG
GY240
While my tail is rock steady, my tail servo is constantly twitching back and forth at about 2 or 3 times a second though about 15 degrees. This happens in the hover even when there are no throttle changes. Running up on the ground with it strapped down the servo is steady. If I turn the gain down the twitching reduces, but I lose the rock steady tail.
The servo itself seems fine with no missing teeth and it centres properly.
My guess is that is that this is caused by vibration moving the gyro around and giving false yaw signals that cancel each other out. My heli appears to be a smooth as a very smooth thing and any vibes must be of small amplitude, as I can’t see anything actually shaking.
I’m not really worried about this, other than wearing out the servo prematurely. As I fly alone I’ve never seen another R/C heli fly close up so have nothing to compare with. Is this twitching normal?
Cush
Cush is offline Find More Posts by Cush
Old Aug 05, 2003, 12:16 PM
bps is offline
bps
Find More Posts by bps
bps
bps's Avatar
Indianapolis, IN
Joined Apr 2001
I have the same problem. My quess is the gyro moves (vibrates) and the hs81mg servo that I am using (non-digital) moves at a slower rate than a digital would and creates this. Just my quess. Does not bother the flying though.
JEB
bps is offline Find More Posts by bps
Old Aug 05, 2003, 02:50 PM
GKurt is offline
Find More Posts by GKurt
Chicago
Joined May 2002
I found it's the vibrations of the heli shaking the gyro. It will eat your servo to the point where it will cause glitchy tail movements, then you'll have to buy another HS81. If you dismount the gyro and let it hang in a way that it's level and still works, the twichyness goes away.
I had an HS81 on the Logo 10 do the same thing, I think the pot gets dirty or wears in one spot. The first servos lasted pretty long, and they are inexpensive anyway. I look at them as spare gearsets now.
Greg
GKurt is offline Find More Posts by GKurt
Old Aug 05, 2003, 06:23 PM
davensocal is offline
Find More Posts by davensocal
Super Member
davensocal's Avatar
United States, NY, Mechanicville
Joined Mar 2003
We started calling it "stroking" the servo... Seems the servo is going so fast, the tail never really has a chance to repsond to the pitch changes.
Yup, it will cook the servo..
Yup, it is probably from vibrations.
I also reduced my vibrations to where I could not see the tail or the skids moving in flight, but I still had the "stroking".
I wrapped the gyro in receiver foam, to try and dampen the vibes. It worked pretty good, I was able to get up to 80 - 90% gain with no stroking.
If you are mounting with zip ties, etc., remember the zip ties can transmit the vibes as well. You would want to make sure nothing that touches the heli also touches the gyro (except for the foam).
davensocal is offline Find More Posts by davensocal
Old Aug 06, 2003, 03:47 AM
Cush is offline
Cush's Avatar
Joined Mar 2001
Thanks for confirming my thoughts – “stroking” I love it.
My gyro is mounted using the foam tape that Futaba supplied with it. I’ll try mounting the gyro in a different place to see if I can find a less vibe prone spot. In the UK HS81 MGs cost around $30 – not a disposable item.
Ta again.
Old Aug 06, 2003, 01:24 PM
GKurt is offline
Chicago
Joined May 2002
I do not like metal gears on the tail servo. There is much more slop in the gear train, they're more expensive, and it's not a servo that gets stripped all that easily anyway (like the cyclic servos).
Greg
How heavy is your corona? msg73 Electric Heli Talk 9 Aug 23, 2004 01:22 AM
hunter69 How's Your Corona/Hacker flying? vkmaynard Electric Heli Talk 2 Aug 27, 2002 01:48 PM
a.gator How's your Corona/Hacker Flying? vkmaynard Electric Heli Talk 3 Jul 24, 2002 09:09 AM
RCAddiction, how's Your Corona/Aveox 27/26 Flying? vkmaynard Electric Heli Talk 0 Jun 23, 2002 10:02 PM
GWS R4P Receiver - How long is your antenna? realdeal Electric Plane Talk 11 May 11, 2001 12:01 AM
