Old Feb 24, 2011, 09:26 AM
wac is offline
wac
Find More Posts by wac
wac
Joined Jun 2005
Should I keep my octo or make an X8?
Hi Guys,
I just finished up my latest ship, a heavy lift octocopter and im wondering if i should convert it to an X8?
my setup is;
FCB - Hoverfly Pro
Frame- Rustys rev 7 & 8 plate mix (one level), Carbon fiber 12mm tubing
esc's - Kens Fast
Motors - Rctimer 2836-11
Props 12x3.8 APC
Batteris - 2x 4s 500mah
Camera Mount - Askman AP 360 Pro
My main problem with the current octo setup is its pretty big and not very practical for travel. From tip to tip it is 36" long and not very easy to break down.
what do you guys think the pros and cons are
Thank you
Bill
wac is offline Find More Posts by wac
Old Feb 24, 2011, 10:12 AM
Z06 Tony is online now
Find More Posts by Z06 Tony
Z06 Tony's Avatar
United States, NY, Rochester
Joined Sep 2008
I built an Octo and did not like the bulkiness and out of all the multis I have flown I like the flight charecteristics the least on the octo. Here is a vid I just shot of my Y6->
Carbon Fiber Y6 Hexacopter on 4s (4 min 24 sec)
I like the Y6 alot and you can buy a foldable Y6,X8.hexa here and they are nice and light. A little more than rustys frames though. The foldable Y6 is $270. I can say they are nice and light. I have 2 and the CF is not the same as china CF. They use more CF and less epoxy. So it is lighter and more flexable-> http://www.rchobbyhelicopter.com/sto...tom_UAV_Frames
Z06 Tony is online now Find More Posts by Z06 Tony
Site Sponsor
Old Feb 24, 2011, 11:13 AM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
Hi Bill,
Here are some nice foldable octo builds to consider:
Imagecatcher - http://www.rcgroups.com/forums/showp...ostcount=12785
Maximus-RC - http://www.rcgroups.com/forums/showp...&postcount=846
AZ Choppercam - http://www.rcgroups.com/forums/showp...&postcount=800
BTW, you have a typo on your lipo mah, I'm sure you meant 5000 not 500mah
@Tony,
Nice Y-6 video what board are you using?
Cheers,
Jim
Quadrocopter and Tricopter Mega Link Index
jesolins is offline Find More Posts by jesolins
Old Feb 24, 2011, 11:17 AM
llamatrails is offline
Find More Posts by llamatrails
Gainesville GA USA
Joined Nov 2004
Originally Posted by wac View Post
Hi Guys,
my setup is;
FCB - Hoverfly Pro
esc's - Kens Fast
Props 12x3.8 APC
Thank you
Bill
I'd be concerned about running 4s. Your motor/prop combo is good to 3s.
Model: BC2836-11
Motor size: Ф28*36mm
Shaft size: Ф4.0*49mm
Weight: 70g
KV(rpm/v): 750
Max Power: 206W
Battery: 2-4Li-Po
Test Prop: 12x6/9x6
Ri(M Ω): 0.160
ESC(A): 40A
Take a look at http://personal.osi.hu/fuzesisz/strc_eng/index.htm
Here is how I figure the RPM for the 2836-11 motors:
750KV * 14.8v * .8 = 8880 rpm (80% efficiency, I'm being conservative)
Wattage comes out to 291. Way over the rated 206W above.
Drop back to 3s and your wattage is 122.
I'm just finishing up my HF octo, same motors and props. As I get it all together, it is looking bigger than it did on paper.
Rick
llamatrails is offline Find More Posts by llamatrails
Old Feb 24, 2011, 11:39 AM
Hamanu is online now
Find More Posts by Hamanu
Hamanu's Avatar
United States, MI
Joined Nov 2003
Z06 Tony that is a really nice looking Y6 you got there. What control board and motors are you using?
http://www.youtube.com/watch?v=V7pNh...layer_embedded
Hamanu is online now Find More Posts by Hamanu
Old Feb 24, 2011, 11:48 AM
wac is offline
wac
wac
Joined Jun 2005
Hi Rick, i didn't think that the wattage was going to be that extreme. Is the 291 at full throttle?
I think I'm going to convert the octo to an x8 and put a watt meter on one of the motors and see what's going on. If it's way to much then I might drop down to11inch props
Thank your for the info
Bill
Old Feb 24, 2011, 11:51 AM
Tarro is offline
Find More Posts by Tarro
Long Island, New York
Joined Jun 2008
Hi Bill,
Don't worry about those motors on 4s, there is no problem with that combo at all. I will never go back to 3s on any of my copters.
Tarro is offline Find More Posts by Tarro
Reply With Quote  (Disabled)
Old Feb 24, 2011, 12:44 PM
jesolins is offline
Joined Feb 2007
Rick,
Not really sure what your point is. Nice calculator though Too bad they don't have a constant factor APC SF or EPP props. We need a calculator like that made specifically designed for multicopters. And here is why:
For multicopters the critical values for efficiency are wattage at the hover speed for the AUW or total flying weight. Max wattage is OK for general aircraft model specifications, not necessarily for multicopters, as we do not fly around continuously at max RPM's. For the BC2836-11 750Kv motors on 4s, yes the max rated wattage will be higher than 3s which is actually closer to the 206W listed on the www.rctimer.com site. Here: http://www.rctimer.com/index.php?gOo=goods_details.dwt&goodsid=128&produc tname= So they do work well with 3s or 4s lipos.
In operational use as measured with an EagleTree or other wattmeter we like to use watts per gram of thrust for measuring multicopter motor/prop combo efficiencies. At hover on average this works out to about 100W per motor at 14.8v and a 1.0-1.4kg multicopter. Here is an excellent link to Old Man Mike's Motor tests for multicopters: http://www.rcgroups.com/forums/showt...s#post11657593
OMM's post on motor/prop efficiency: http://www.rcgroups.com/forums/showp...ostcount=16592
Other available motor prop estimaters not optimized for hovering multicopters:
--Estimaters for electric motor and prop combinations: http://adamone.rchomepage.com/calc_motor.htm and http://personal.osi.hu/fuzesisz/strc_eng/index.htm and http://www.peakeff.com/MotorDetails....ID=2753&v=10.5 and http://www.drivecalc.de/
Cheers,
Jim
Model: BC2836-11
Weight: 70g
KV(rpm/v): 750
Max Power: 206W
Battery: 2-4Li-Po
Test Prop: 12x6/9x6
Ri(M Ω): 0.160
ESC(A): 40A
Rick
Old Feb 24, 2011, 01:26 PM
pug398 is offline
Find More Posts by pug398
VA
Joined Nov 2009
There are two paths to propping a 'coptor or so I think. Overpropping and getting better efficiency at hover. Downside is load it up and you could burn out motors. If you are the only one that will operate it there shouldn't be a problem. The other path is the engineers view. Try to make it work for everyone, all the time, with no tweaking no matter what they do even strap it to a concrete pad and run it wide open and it would make no difference. I have used both methods myself just a matter of preference.
pug398 is offline Find More Posts by pug398
Old Feb 24, 2011, 02:25 PM
Z06 Tony's Avatar
Joined Sep 2008
The board is a KK Blue board with no accels just the board.
BTW as Tarro mentioned once you go 4S you will not want to go back to 3S. I tried 4S on my X650 and liked it so much I used the same motors on 4S with my Y6. My props are 12" Xair props.
Site Sponsor
Old Feb 24, 2011, 02:48 PM
Hamanu's Avatar
United States, MI
Joined Nov 2003
Wow thats just a KK board with no accelerometers it looks very stable what size batt are u using and whats the KV on those motors?
Old Feb 24, 2011, 03:25 PM
Z06 Tony's Avatar
Joined Sep 2008
Not sure why but Xaircraft does not list a KV rating. I am guessing about 750kv. I am using a Thunder Power 2250mAh 45C. I am waiting for the new XPS 65c to get back in stock cus all my batts are new and the Hyperion 25C batts have less punch as they should cus they are only 25C. Want to compare the TP 45C and the XPS 65C. They both have a top number of 90C so might not make a diff but they are cheaper.
Site Sponsor
Old Feb 24, 2011, 03:51 PM
Joshbb is offline
Find More Posts by Joshbb
Ironbridge (UK)
Joined Jan 2009
yes they do Tony, you have to check the wiki here
Material:Steel, Aluminum, Copper, Magnet etc.
Weight:86.5g
Mark:850KV, 150W.
I see you cannibalised your x650 then your Y6 seems to fly really great very nice, It's made me want to build one now
Joshbb is offline Find More Posts by Joshbb
Old Feb 24, 2011, 04:40 PM
Quad_Addict is offline
Find More Posts by Quad_Addict
United States, IL, Chicago
Joined Dec 2006
tony sell me your y6 :P
Quad_Addict is offline Find More Posts by Quad_Addict
Old Feb 24, 2011, 05:57 PM
Z06 Tony's Avatar
Joined Sep 2008
Weight:86.5g
Mark:850KV, 150W.
Thanks for the info JB. No I can afford 6 motors so I did not need to take them from the X650. Remember I have no kids. If I had a few children I would be flying 1 quad if I was lucky. Prolly with used and donated parts. All it took was 1 flight on 4s with the X650 to make me want to buy those motors for my Y6. What I like about the Y6 is no wobbling at all but not due to the FC but the motor configuration.
BTW My AHRS is messed up on my X650 and I did not crash or even land hard and it is a replacement.
Site Sponsor
Discussion 2.4ghz or 1.2ghz which should i keep. stevessub27 FPV Talk 4 Feb 22, 2011 05:33 PM
Discussion Have an S111G - Should the next one be a S026 or S107? comstar Coaxial Helicopters 6 Jan 15, 2011 04:10 PM
Help! Decided to make an RC plane for my diploma project Confuzled Chit Chat 19 Jan 15, 2011 12:35 PM
Discussion Should I keep my Blade CP or step up to something else? zephix Micro Helis 10 Apr 20, 2008 01:41 PM
Discussion Crossroads - Should I keep my Honey Bee King II, Get a Blade CP, or Walk Away? Cloudbase2 Micro Helis 17 Apr 14, 2008 12:35 PM
