Old Feb 23, 2011, 04:34 PM
Fabio1970 is offline
Find More Posts by Fabio1970
Fabio1970's Avatar
Italia, Puglia, Taranto
Joined Feb 2011
Adding an external Gyro to a Fixed pitch , it is possible ?
Hi guys,
I’m Fabio a new italian member of this wonderful forum but not new in the RC heli world
This is my page on youtube :
http://www.youtube.com/user/Fabio4408?feature=mhum
I usually fly with the Innovator MD 530 ( 450 class ) and a Hughes 300 ( 400 class ), you can see on my page many videos of these two models
I had also a Kestrel 500 SX and I enjoyed a lot, upgrading it
You can see what I did on these two additional video here :
RC Heli - Nine Eagles - Kestrel 500SX - Fabio - Part 2 (7 min 17 sec)
RC Heli - Nine Eagles - Kestrel 500SX - Fabio - Part 3 (8 min 23 sec)
I start to have problem when I decided to leave the fuselage of the Kestrel 500 SX and starting from the skeleton build on, a fuselage of the B 47 g.
I made a first video during the construction, and how you can see so far it was everything ok :
http://www.youtube.com/watch?v=JA2HbZ8yi20
, but going ahead with the work , the overall weight increase from the original 185 grams to the actual 260 grams.
The problem I am having right now, and I cannot resolve is that, I’m not more able to find a balance between the two engines and thus the heli is not keep the tail hold, with the original tail motor I could not contrast the main rotor , then after I burned 3 tail engines...I change it with the most powerful tail motor from honey bee Fp 2.
Now this engine is too powerful and pulls the tail in the opposite direction, I also changed the original nine eagles receiver with the last black receiver using the new technology “ ez bind “ but having the same problem , I changed it again with a RX2423A Walkera 3 in 1, but the problem remained, as you can see from this little video :
http://www.youtube.com/watch?v=3AaOJazeLj0
Now after a lot of frustations, I’m thinking to add and external Gyro and change if it is the case the receiver unit with a Spektrum ,
Can some of you help me to resolve this matter, explaining wich can be the most simple and definitive solution to adopt?
Thank you very much for any kind of help
Best regards and greetings from Holland
Fabio
Fabio1970 is offline Find More Posts by Fabio1970
Old Feb 23, 2011, 07:24 PM
Ampdraw is offline
Find More Posts by Ampdraw
Australia...we live inverted.
Joined May 2008
Not an easy task with a tail motor heli.
Heaps of related info here:
http://www.rcgroups.com/forums/showthread.php?t=1092636
Not sure how many cells that heli runs on but I would suggest, for ease of getting a fast enough tail esc, that you run 2s. Then you can use the Plush 6A, Thunderbird 9 etc for the tail.
Amp
Ampdraw is offline Find More Posts by Ampdraw
Old Feb 23, 2011, 08:47 PM
Balr14 is online now
Find More Posts by Balr14
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
You need a separate ESC for the tail motor and some trick wiring. Both the HeliMax Axe CP and EFlight CP Pro had external gyro upgrade options. The wiring diagrams can be found if you Google search for the owners manuals.
Balr14 is online now Find More Posts by Balr14
Old Feb 24, 2011, 05:03 AM
Fabio1970's Avatar
Joined Feb 2011
thank you for your answer
I still have some doubts,
I need a new receiver like the one used from the E-Flite Blade Pro ?
or it is better go straight to a Spektrum like the AR6100?
I have to connect the E-Flite Gyro ( wich model will be the best for my case ? I notice that the Blade Pro and the Blade Sr use different model ) to the channel 4 and 5 of this receiver, where I have to connect the plug coming from the tail motor ? Directly to the gyro?
I need also an ESC or it is not necessary ? I still using the original brushes motor and not a brushless
thank you for your patience
Fabio
Old Feb 24, 2011, 06:41 AM
copperclad is offline
Find More Posts by copperclad
Coaxially Fixated
copperclad's Avatar
Rochester N.Y.
Joined Oct 2005
Hi
i'm not sure if this is what you are looking for , but
this link has some nice wiring diagrams , and info on going separates
http://www.helihobby.com/html/separate_electronics.html
copperclad is offline Find More Posts by copperclad
Old Feb 24, 2011, 08:34 AM
mdugas is offline
Find More Posts by mdugas
Joined Aug 2003
hi,mabe im wrong but cant you just plug gyro into tail rotors rx slot then tail rotor into
the gyro
in know it works that way if adding to on a/c put gyro on rudder bit
mdugas is offline Find More Posts by mdugas
Old Feb 24, 2011, 08:40 AM
Coaxially Fixated
copperclad's Avatar
Rochester N.Y.
Joined Oct 2005
then tail rotor into the gyro
Hi mdugas
the motor needs to be driven by an ESC ( electronic speed control ) , the gyro does not contain an ESC , so plugging the motor into the gyro would not work
note: the link and photos i posted , assume the the original 4 in 1 is being binned , and a standard RX is being used instead .
Old Feb 28, 2011, 03:50 AM
Fabio1970's Avatar
Joined Feb 2011
Originally Posted by copperclad View Post
Hi
what's happening to these links..........I'm not more able to see the entire articles were everything was explained
ciao
Fabio
Old Feb 28, 2011, 08:07 AM
Coaxially Fixated
copperclad's Avatar
Rochester N.Y.
Joined Oct 2005
Hi
i see they just updated their site , and the links don't work now , here is another link to the same info
http://www.rcgroups.com/forums/showthread.php?t=956581
Old Feb 28, 2011, 10:14 AM
Fabio1970's Avatar
Joined Feb 2011
Hi
Thank you so much for your help, I apprecciate it really a lot
I have another question, do you think it can work anyway if I use a Spektrum RX 6100 and an a different Gyro........or only their kit will work properly ?
anyway still thanks for your kindness
best regards
Fabio
Sold *reduced* Walkera HM-4# Helicopter RTF Fixed Pitch 370 Motor Heli Hellsiege Aircraft - Electric - Helis (FS/W) 6 Jun 07, 2014 06:04 AM
Question Eflight 5-in-1 with external rx, is it possible? Doug101 Radios 3 Oct 31, 2010 06:53 AM
Discussion biggest fixed pitch Hot_Wheels Large Electric Helis 8 Sep 17, 2010 11:28 PM
Sold HBFP Hony Bee Fixed Pitch V2 w/tons of spares Z06 Tony Aircraft - Electric - Helis (FS/W) 6 Sep 03, 2010 11:21 AM
Discussion Adding an external power source to AeroAce/XTwin transmitter Tachikoma Micro Ready-to-Fly 16 Sep 18, 2007 12:44 PM
