Old Aug 05, 2003, 03:00 AM
Phil
Guest
n/a Posts
Saito 91 and 100 air filter
My first Saito's, is there an air filter made to go over the carb?
Phil
Old Aug 05, 2003, 03:01 AM
Six_O'Clock_High
Guest
n/a Posts
Re: Saito 91 and 100 air filter
No, but wise men make one out of window screen cloth covered with old
stocking material. Use zip ties to hold the assembly together and on the
venturi stack.
I took the screen wire and wrapped it around the knob on my drill press to
get the shape since I wanted lots of surface area to avoid choking the
engine. This got zip tied to the venturi stack. THEN I got an old pair of
stockings and put a chunk over the wire and zip tied it to the venturi
stack. Keeps the dirt out and does not appear to starve the engine for air.
YMMV - good luck,
Jim Branaum
AMA 1428
Six_O'clock_High
Target_Lock@Guns.com
"Phil" <pminmo_spam@msn.com> wrote in message
news:3F2EDE8B.189825DB@msn.com...
> Phil
Wanted Saito 91 or 100 DiabloKid Aircraft - Fuel - Airplanes (FS/W) 1 Aug 25, 2005 04:09 PM
For Sale Nib Slimline Pitts Muffler, Saito 72,80,82,91,100 u8racing Aircraft - Fuel - Airplanes (FS/W) 6 Aug 14, 2005 10:34 PM
Wanted saito gk 91/ 100 srvblues Aircraft - Fuel - Airplanes (FS/W) 1 Aug 14, 2005 02:30 PM
Wanted Slimline Inverted Pitts Muffler Saito 82, 91, 100 u8racing Aircraft - Fuel - Airplanes (FS/W) 0 Jul 27, 2005 02:31 PM
Magnum XL 91 RFS vs Saito FA 100. Which is better? Starguard Engines 14 Mar 16, 2005 04:15 AM
