Old Apr 17, 2012, 03:25 AM
OldMann is offline
Find More Posts by OldMann
Romania
Joined Dec 2006
Originally Posted by wparsons View Post
Practical output wattage = V * I * E, you don't need to know anything about resistance, etc.
V = voltage
I = current
E = efficiency.
Input wattage is simply V * I.
I do not think this formula is correct.
This formula would result E ; E= P /V*I
This means that if I lower the supply, increase efficiency .... that contradicts the laws of physics.
OldMann is offline Find More Posts by OldMann
Old Apr 17, 2012, 04:01 AM
norbique is offline
Find More Posts by norbique
norbique's Avatar
United States, HI, Honolulu
Joined Dec 2002
I am by no means an expert, but I think since efficiency is always less than 1 (that is 100%), the above formula should be consedered OK.
input wattage Pin=Uin * Iin
output wattage Pout=Uin * Iin * efficiency (which is <1)
so P out is always less than P in.
norbique is offline Find More Posts by norbique
Old Apr 17, 2012, 09:29 PM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Input Wattage = Voltage * Current.
Output Wattage = Voltage * Current * Efficiency or Output Wattage = Input Wattage * Efficiency
Rearranging that gives:
Efficiency = Output Wattage / (Voltage * Current) or Efficiency = Output Wattage / Input Wattage which is 100% correct.
Not sure what you mean about lowering supply and increase efficiency or contradicting the laws of physics, all the above is definitely correct as far as physics is concerned.
wparsons is offline Find More Posts by wparsons
Old Apr 18, 2012, 08:57 AM
pulsar is offline
Find More Posts by pulsar
United we race !
Slovenija, Ljubljana
Joined Oct 2006
Iīm still confused, about this discussion on efficiency.
Max 75A on 11S is correct data (3025W).
Lowering the voltage increases current, so I think on 6S (120-160Amp)?
I think itīs like that isnīt it?
Thanx to all comments.
Kruno
pulsar is offline Find More Posts by pulsar
Old Apr 18, 2012, 08:59 AM
pulsar is offline
United we race !
Joined Oct 2006
Originally Posted by renosa View Post
Pulsar how you ar going to cool this motors?
they are not water cooled!
For coolin, I wil made something like this:
http://www.hobbyking.com/hobbyking/s...ount_30mm.html
or using this:
http://www.hobbyking.com/hobbyking/s...75MM_BOAT.html
Old Apr 18, 2012, 04:52 PM
norbique is offline
norbique's Avatar
Joined Dec 2002
I use the T600 turnigy motors, 1400KV on 6S and I use the cooling plates in your 2nd link. They work good!
The ourtunners are torque monsters!!!
Here is the first test run of the boat:
Lithium (1 min 32 sec)
Old Apr 18, 2012, 09:51 PM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Kruno
If you lower the voltage without changing anything else, current draw will actually go down (opposite goes if you increase voltage but change nothing else). If you want to keep the same wattage output you would have to prop up to increase load (and amp draw).
Old Apr 19, 2012, 01:50 PM
hakan is offline
Find More Posts by hakan
Joined Apr 2012
send me again plase.
hakan is offline Find More Posts by hakan
Old Apr 19, 2012, 09:59 PM
Espressoo is offline
Find More Posts by Espressoo
United States, VA
Joined Aug 2011
And this I hope you all know what it is.
I have obut 20 models that I draw myself.
If someone need something, contact me I see what I can do.
pulsar, your work is very impressive and your generousity is unparalleled. Myself and many others might be interested in this model below. Do you happen to have a design of the Outerlimits SV43?
Specs: http://www.outerlimitspowerboats.com/43SV.htm
FE model: http://www.e-powerboat.de/archives/515
Profile pics: http://i62.photobucket.com/albums/h9...hipmodlow4.jpg
Very good scratch built: http://www.offshore-rc.com/forum/ind...howtopic=25587
Espressoo is offline Find More Posts by Espressoo
Old May 03, 2012, 05:01 AM
hakan is offline
Joined Apr 2012
hi;
Send me Mystic C5000R autocad dxf data plaese.
Hakanisik26@hotmail.com
Old May 03, 2012, 05:04 AM
hakan is offline
Joined Apr 2012
Mystic C5000R 3d autocad data
hello
my name is hakan
send me Mystic C5000R 3D autocad data, plaese
hakanisik26@hotmail.com
Old May 03, 2012, 05:21 AM
hakan is offline
Joined Apr 2012
send Mystic C5000R again plase
send again plase
Old May 03, 2012, 08:43 AM
pulsar is offline
United we race !
Joined Oct 2006
Hi.
Ok here is the 3D file of mystic c5000r V2.
Old May 04, 2012, 01:13 AM
hakan is offline
Joined Apr 2012
tanks a lot of
Old May 04, 2012, 03:28 PM
Themis96 is offline
Find More Posts by Themis96
Joined Mar 2012
Hi, check your pms. I need plans for the hrp mono. Please reply!
Themis96 is offline Find More Posts by Themis96
Discussion First scratch build kit? skychief80 Fuel Plane Talk 15 Sep 10, 2010 07:55 AM
Discussion Building a FPV platform as first scratch build. venquessa Foamies (Scratchbuilt) 9 Sep 08, 2010 11:13 PM
Discussion One to another-scratch build. The Antipodean Scale Boats 0 Sep 05, 2010 06:38 PM
Build Log F1 25" scratch build by special request F1 madness Racing Boats - Electric 9 Sep 04, 2010 06:50 AM
