Old Feb 23, 2011, 12:35 AM
devinvagt is online now
Find More Posts by devinvagt
United States, CA, Ukiah
Joined Jan 2011
circular polarized patch design
Thought I saw a tutorial for building a circular polarized patch antenna, but can't find it now! Was I dreaming?
Devin
devinvagt is online now Find More Posts by devinvagt
Old Feb 24, 2011, 10:02 AM
Derek_S is offline
Find More Posts by Derek_S
Videopilot
Derek_S's Avatar
United States, NC, Charlotte
Joined May 2009
I havent seen one on here, patch antennas are sorta hard to get to be truly circular from what I understand. You may look up some HAM websites and find the info, or build one of IBCrazy's other CP antenna designs.
Derek_S is offline Find More Posts by Derek_S
Old Feb 24, 2011, 07:25 PM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
I have one in the making. After failing countless number of times to do a dual fed patch (to improve axial ratio), I gave up and looked at a few corner trimmed designs. it's not quite as good, but it is the same as what most commercial units are doing.
@Derek - Check the .pdf file I sent you. There is a dual band CP patch design in there in the dish feed section
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Mini-HowTo The Skew-Planar Wheel circular polarized omni antenna IBCrazy FPV Equipment 972 Jun 21, 2016 05:24 AM
Discussion Circular-polarized Patch Antenna for 5,8 GHz Lonestar78 FPV Talk 25 Feb 22, 2015 08:01 PM
Discussion Left/Right circular polarized antenna ? SpookiePower FPV Talk 53 Feb 21, 2015 07:02 PM
Discussion 18dbi Circular Polarized Patch ? Coyote64 FPV Talk 3 Nov 10, 2010 04:59 PM
Discussion Advantage of a Circular Polarized Patch Ant? Mach61 FPV Talk 2 May 01, 2009 10:53 PM
