Old Feb 22, 2011, 03:43 PM
David T is offline
Find More Posts by David T
UK
Joined Aug 2000
HK-282A 2g servo/geared motor
Hi. HK have what I think is a fairly new 2g servo, the HK-282A. 2.56g according to my scales for the 'single-screw' version. http://www.hobbyking.com/hobbyking/s...dProduct=14839 Putting it on a diet as shown I get it down to 1.9g. Quite a nice companion for the 1.7g linear servo.
At $3.99 it's cheap enough to experiment with. It has a 10ohm 4x8mm pager motor. I canabalised one to make a nice small geared unit. The servo has a steel 1mm pin on which some gears pivot. I used one of those gears as my main gear and the other as the shaft holder. Another gear with a smaller hole became the stop to hold the shaft in place. The shaft is 1mm carbon and the main drive gear is cyano'd in place as it is a loose fit on the 1mm shaft. A 45mm plastic prop of unknown origin draws 140mA at 4v. The finished unit without prop or connector weighs 0.54g. With prop it's 0.83g.
I have a drill bit set which increments every 0.05mm or 0.1mm from 0.3 to 1.6mm. They are not very expensive. I found this useful for reaming out the gears and prop where necessary.
Regards, David.
David T is offline Find More Posts by David T
Old Feb 22, 2011, 03:57 PM
gklein is offline
Find More Posts by gklein
Gary
gklein's Avatar
USA, CT, Sandy Hook
Joined Dec 2009
Great work! Very inventive on the power unit. Can you measure thrust?
gklein is offline Find More Posts by gklein
Old Feb 22, 2011, 05:18 PM
David T is offline
UK
Joined Aug 2000
No sorry, I've not got a rig for that yet.
dt.
Old Feb 23, 2011, 05:19 AM
David T is offline
UK
Joined Aug 2000
Made a rig. It generates 1g of thrust at 3v and 1.5g at 4v.
By comparison, a 4x11mm that measures about 9ohms generates 1.1g at 3v (140mA) and 1.65g at 4v (194mA) with a PicooZ 30mm prop.
dt.
Sold two HK 282A 2.5g servos dbennettya Aircraft - Electric - Helis (FS/W) 1 Dec 29, 2010 02:57 PM
New Product Power HD 2g Servo and HobbyKing 2.2g Servo boredom.is.me Scratchbuilt Indoor and Micro Models 52 Nov 24, 2010 09:35 AM
Discussion 2.2g servo running on computer.... nemoskull Scratchbuilt Indoor and Micro Models 0 Nov 09, 2010 10:30 PM
Discussion 2.2g smallest servo used at 2V~4.5V,you know it? zebramodel Scratchbuilt Indoor and Micro Models 10 Sep 30, 2010 10:49 AM
For Sale gws EM 400 geared motor $10 shipped aerowoof Aircraft - Electric - Power Systems (FS/W) 0 Sep 11, 2010 06:13 PM
