Old Feb 26, 2011, 12:28 PM
Andrew Jesky is offline
Find More Posts by Andrew Jesky
Andrew Jesky's Avatar
United States, UT, Tooele
Joined Oct 2002
Originally Posted by soundchaser View Post
Hey Andrew,
Are you running the hacker a40-12s with those 5s lipos? If so,.......what prop size and watts are you producing?
I was just able to check on the motor, I'm running the A40-12s on a 15x8 prop. I haven't checked watts but I wouwld imagine somewhere over 1200 watts. Its great power for me up in Salt Lake City, which the Elevation is about 4500msl.
You may have to come back on the prop a bit down in lower elevations.
I also have another 59 setup on 4s and its running the A40-10s. I have it on the same prop and it flies just as good. It was basically because I have a bunch of 5s packs that I went with the 12s. If you have a lot of 4s setups for your planes to run 8s on the bigger stuff I think you will be happy with 4s.
Once I get the Orange 59" back from Mark Leseberg I'll measure the CG and give it to you. This airframe is really happy with running a bit more forward CG and still 3d's extremely well. It tracks amazingly well, probably the best tracking small plane I have flown. I was actually out practicing a ton of IMAC with it before the weather got nasty.
Andrew
Andrew Jesky is offline Find More Posts by Andrew Jesky
Old Feb 26, 2011, 01:12 PM
myp is offline
myp
Find More Posts by myp
myp
Joined Oct 2007
Seems like many folks are planning to run close to 1200W on the Slick. That's about 240W per lb assuming a heavy 5 lb set up. I have always thought that Ben & company were advocating about 160W to 180W per lb to allow better control of the throttle in 3D. So, is it for precision/pattern flying with the Slick that requires the higher power?
myp is offline Find More Posts by myp
Old Feb 26, 2011, 01:56 PM
Joined Oct 2002
We do usually go for 180W per pound. I think we have just been buffering this number a bit as some people do no like the power of some of the systems that I have selected as it doesn't give you that rocket power when you get in trouble. I still prefer that power setup but we also want to make sure we give a little head room for those that want that extra power.
Andrew
Old Feb 26, 2011, 02:53 PM
myp is offline
myp
myp
Joined Oct 2007
Thanks AJ for your sharing your thoughts. Would running an A40 12S on 4S 25C 3300/3700 packs and 15x6 prop give us closer to the 180W per lb?
Also, I noticed that the 59" Slick has a shorter length than the wing span just like the 42" Slick while other Slicks have a length similar to the wing span. What is the design goal for a shorter length? Would the shorter length be related to theKM's impression that the 59 is more "high strung" compared to the 57 SC? AJ, if you do not want to share things related to design, I understand completely.
Old Feb 26, 2011, 03:40 PM
Joined Oct 2002
Myp,
I would probably go with the A40-10s and run that on 4s. It seems to work out pretty well on that setup.
As far as the design goes we decided to get the slick in to the 10% rule that Imac follows, this way people will not complain about the rule. To be honest this is probably the best flying generations of the slicks.
Andrew
Old Feb 26, 2011, 04:07 PM
myp is offline
myp
myp
Joined Oct 2007
Thanks AJ.
Old Feb 26, 2011, 06:02 PM
Rishelman is offline
Find More Posts by Rishelman
Knobbs
Friday Harbor, WA -San Juan Island
Joined Aug 2008
sub'd
Rishelman
Rishelman is offline Find More Posts by Rishelman
Old Feb 26, 2011, 09:39 PM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
The 71 slick is 71" wide by 68" long. It feels much different than the 51 slick and alot like the 42 slick. Hope the 59 feels like the 42 and 71
losifanatic is offline Find More Posts by losifanatic
Old Feb 26, 2011, 09:45 PM
Sippin the Koolaid!
Joined Oct 2007
Sorry guys I had to post my 8000th post here since I have my 59 red one ordered and I LOVE a slick(and trying to leave my mark in the thread ). The 59 is going to be my lovely daily flier! April cant come soon enough
Old Feb 26, 2011, 09:59 PM
mustang347 is offline
Find More Posts by mustang347
I drank it, and it is good.
United States, OH, Powell
Joined Sep 2009
I'll have to get a red 59" Slick here soon. I need to wait a little longer...
mustang347 is offline Find More Posts by mustang347
Old Feb 26, 2011, 10:04 PM
Sippin the Koolaid!
Joined Oct 2007
Might want to hurry up. Dont know how many are in the first shipment but they are selling like hotcakes
Old Feb 26, 2011, 10:33 PM
gonzoman5 is offline
Find More Posts by gonzoman5
Up,Up!up!!up!!!
gonzoman5's Avatar
Ashland, OR
Joined Jul 2009
Got mine
gonzoman5 is offline Find More Posts by gonzoman5
Old Feb 26, 2011, 11:44 PM
cactus is offline
Find More Posts by cactus
United States, CO, Durango
Joined Sep 2001
Wow! I just ran across this plane on the 3DHS website. Looks great. I am looking to move up into a bigger plane this year. Currently flying the v2 47" SHP on 13x8 prop on 3s 3000mah packs for several seasons now and it goes to the field every time. I like big air precision flying with some light 3d mixed in. My question would be if I could get a setup to use some of my existing packs? Maybe two 3S 2200-3000 packs for a 6S or perhaps use my 5S 5000 20C packs I use in my Swift heli? Does this plane handle a little more weight for wind penetration?
Edit: I was considering a 72" Extra /DLE 30 setup for long flights, but I don't think it will fit in my xTerra! This seems about the right size to get that bigger feel without having to get a trailer to haul it to the field.
cactus is offline Find More Posts by cactus
Old Feb 27, 2011, 12:03 AM
BoneDoc is offline
Find More Posts by BoneDoc
Team 3DHS
BoneDoc's Avatar
San Antonio, TX
Joined Sep 2004
FWIW, my 103" SC fits into my Honda Fit, and CTunder's 89" Slick fits into his Nissan Sentra. I doubt your Xterra is any smaller than the Sentra .
BoneDoc is offline Find More Posts by BoneDoc
Old Feb 27, 2011, 12:09 AM
Balsadancer is offline
Find More Posts by Balsadancer
Balsadancer's Avatar
Joined May 2010
I think there is another brand of 58" ish plane that runs a pair of 3S 2200s so that may work fine. I think the 5S 5000 pack could be a bit heavy. But, the 3dHS planes will still fly better on the heavy side than most comparable planes set up as light as possible, from what I hear.
My hanger is quickly becoming 3DHS only so I don't have much experience with other brands. But I do run a light setup on my 72 SC and I like it that way. My 57 SC is a med weight, high power setup and its great. I will use the same stuff on the 59" Slick.
Balsadancer is offline Find More Posts by Balsadancer
Wanted 3DHobbyShop 70" AJ Slick bbigdog2243 Aircraft - Electric - Airplanes (FS/W) 2 Dec 31, 2010 11:24 PM
Video 3DHobbyShop Aj Slick ''Rc Day Two Rockin'' with onboard video Get Real Electric Plane Talk 2 Jun 18, 2009 03:07 AM
Sold 3dhobbyshop AJ Slick Wings Flazo Aircraft - Electric - Airplanes (FS/W) 4 May 16, 2009 10:46 PM
Discussion 3DHobbyShop 51" AJ SLICK - how durable for 3D moves? Voyager 3D Flying 13 May 06, 2009 06:10 AM
