Old Feb 25, 2011, 12:39 PM
Kevinr25 is offline
Find More Posts by Kevinr25
Joined Jun 2008
Just a quick question. With the Ice lite 75 work with the Motorlfly 2620
Kevinr25 is offline Find More Posts by Kevinr25
Old Feb 25, 2011, 01:06 PM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
3620? yes
losifanatic is offline Find More Posts by losifanatic
Old Feb 25, 2011, 04:09 PM
TG43 is offline
Find More Posts by TG43
TG43's Avatar
Glens Falls, NY
Joined Apr 2010
Wonder what kind of flight times a 3000mah 5s would give?
Picked up a hacker combo from ADC.
Hobbypartz has 5s 3000mah bats for $26. or 3300mah for $48. I'm cheap.
First Slick by the way.
TG43 is offline Find More Posts by TG43
Old Feb 25, 2011, 04:14 PM
theKM is offline
Find More Posts by theKM
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
for the same power (wattage), it's a thing you can work out... 4S 4000's overall have 16000mah if it were a single cell pack (4000 x 4)... so, 5S 3000, 5 x 3000, 1500mah... pretty close. I fly 7 minutes, so 16:15 on that figure ((7/16)x15) will be 6.5 minutes if you were just as aggressive with the throttle as I am and your plane is set up for the same wattage as mine...
theKM is offline Find More Posts by theKM
Latest blog entry: Updated Hatcam - Apr2016
Old Feb 25, 2011, 04:22 PM
TG43 is offline
TG43's Avatar
Glens Falls, NY
Joined Apr 2010
Hmm thats really cool. Never thought of it that way. Thanks. Should be a super poweful, light setup.
Old Feb 25, 2011, 04:51 PM
simon737 is offline
Find More Posts by simon737
Triple boxed goodness!
simon737's Avatar
United Kingdom, Doncaster
Joined Sep 2008
I have the Scorpion 4020 on my 57" Extra using 5s3000 with a 15x9 prop - timer set for 7 minutes usually put back in around 2300-2400.
simon737 is offline Find More Posts by simon737
Old Feb 25, 2011, 06:21 PM
Andrew Jesky is offline
Find More Posts by Andrew Jesky
Andrew Jesky's Avatar
United States, UT, Tooele
Joined Oct 2002
I have the Hacker Setup in mine on 5s3900's and I can fly for around 8 minutes and only put back about 2500 mah.
Andrew
Andrew Jesky is offline Find More Posts by Andrew Jesky
Old Feb 25, 2011, 06:55 PM
danamania is offline
Find More Posts by danamania
Advocating for RC Aviation
USA, NJ, Phillipsburg
Joined Jul 2010
Andrew
Thanks AJ, I'm going to play in this space rather than go 4S when I get a 59." Dana
danamania is offline Find More Posts by danamania
Old Feb 25, 2011, 07:20 PM
soundchaser is offline
Find More Posts by soundchaser
soundchaser's Avatar
Joined Sep 2009
Andrew
Hey Andrew,
Are you running the hacker a40-12s with those 5s lipos? If so,.......what prop size and watts are you producing?
soundchaser is offline Find More Posts by soundchaser
Old Feb 25, 2011, 10:11 PM
xraydoc is offline
Find More Posts by xraydoc
xraydoc's Avatar
Little Rock, AR
Joined Apr 2009
For any of the team guys that have flown both 4s and 5s setups do you have a preference for one over the other or does it just boil down to the ratio of amps to volts you are running through the esc to achieve the desired power output.
xraydoc is offline Find More Posts by xraydoc
Old Feb 26, 2011, 12:42 AM
aerosheldon is offline
Find More Posts by aerosheldon
No one has more fun than me
aerosheldon's Avatar
United States, CO, Denver
Joined Sep 2003
Originally Posted by soundchaser View Post
Hey Andrew,
I wanted to know this also...
aerosheldon is offline Find More Posts by aerosheldon
Old Feb 26, 2011, 07:32 AM
ryan_m is offline
Find More Posts by ryan_m
doh!
ryan_m's Avatar
United States, AR, Little Rock
Joined May 2006
One good thing on 5s would be lower amp draw, easier on batteries, more consistent power delivery as a result as the battery voltage should hold a bit better. I imagine that might be very important depending on your flying style.
But even on 4s at about 1200 watts this only pulls around 82 amps or so. The 57"SC that I had with the Motrolfly 3625-800 was making around 1200 watts and flew with a lot of power. The Hacker A40-10s on my 55" Edge is a bit less, maybe 1100 watts, about 75 amps. I'm currently running Hyperion 4s4200 35c packs which weigh 449 grams. (My Edge needed a bit more nose weight than the 4s4000 25c Hyperion had).
Rodney is running these: http://www.valuehobby.com/product_de...=9&item_id=236
in his 57" SC, they weigh more than the Hyperion and are only 30c 4000s.
Guy is running Hyperion 25c 5s3300's in his 57" SC, they weigh about 455 grams. So the weights are pretty comparable from 4s to 5s.
I don't think 75-80 amps is too bad out of a 4000 pack, around 20c, and I like the flexibility of being able to double up for 8s someday maybe so I stuck with 4s personally.
ryan_m is offline Find More Posts by ryan_m
Old Feb 26, 2011, 08:16 AM
racin06 is offline
Find More Posts by racin06
United States, IN, Indianapolis
Joined Dec 2006
I own the 72" 330SC and am doubling up for 8S on the 4S lipos. Looks like I now have an excuse to buy the 59" Slick...I can "single down" on the 4S lipos .
racin06 is offline Find More Posts by racin06
Old Feb 26, 2011, 10:59 AM
SalamSyed is offline
Find More Posts by SalamSyed
Fly Low-Fly 3D-Fly Often
SalamSyed's Avatar
United States, VA, Springfield
Joined Oct 2009
racin06, you can always find an excuse for a new plane. You just got some nice planes; leave some for us man.
Just kidding... the more the better.
SalamSyed is offline Find More Posts by SalamSyed
Old Feb 26, 2011, 12:12 PM
Kachu is offline
Find More Posts by Kachu
USA, TX, Katy
Joined Mar 2009
ASSUMING you mean a 3620,
Depending on the prop yes, but an ICE lite 100 weighs the same and dosnt cost that much more. I would recommend using the standard ICE over the lite series if you are using the built in BEC. The lite are supposed to have a decent amount of airflow and with the extra stress of the bec would be pushing it. I plan on using standard servos (non-digital) and an ICE 100 with either a 3625 or the new 4315.
. . . I dont have any 5S packs so I should get an Osiris
Kachu is offline Find More Posts by Kachu
Wanted 3DHobbyShop 70" AJ Slick bbigdog2243 Aircraft - Electric - Airplanes (FS/W) 2 Dec 31, 2010 11:24 PM
Video 3DHobbyShop Aj Slick ''Rc Day Two Rockin'' with onboard video Get Real Electric Plane Talk 2 Jun 18, 2009 03:07 AM
Sold 3dhobbyshop AJ Slick Wings Flazo Aircraft - Electric - Airplanes (FS/W) 4 May 16, 2009 10:46 PM
Discussion 3DHobbyShop 51" AJ SLICK - how durable for 3D moves? Voyager 3D Flying 13 May 06, 2009 06:10 AM
