Old Oct 18, 2012, 10:28 AM
Chuck is offline
Find More Posts by Chuck
Balsa to the Wall
Chuck's Avatar
Deep in the East Texas Piney Woods
Joined Dec 2001
Originally Posted by Lardog View Post
You mean your rudder isn't at the rear? J/K
That's the beauty part about installing as pull/pull first. if it isn't right, simply take the servo out and rear mount it. No worries. All the parts are included for both methods.
Mount it in the rear first, and if it doesn't work, you now have holes you have to patch up.
HAHA!! Good one. I meant rudder SERVO. I'll fix it.
And you do have a point - easier to cut a new hole than cover one that's there.
Chuck
Chuck is offline Find More Posts by Chuck
Old Oct 20, 2012, 02:21 PM
Komet ME163 is online now
Find More Posts by Komet ME163
Komet ME163's Avatar
E TN
Joined Jan 2003
flew a flight this morning with the new skylipo 40c 2650mah packs. 8.5 min landed, and checked voltage 11.5volts. Bivens had previously marked 90 and 100 mm ranges for his 2600, put them at 90 and flew, it was great even got a 1.5 turn inverted flat spin. Wish I knew what i did to get that. Several upright flat spins, knife edge, and a couple of attempts at hovers too, of course elev and harriers. Man this bird is a great flier. What have liked to flown more but honey do's called.
Bill
Komet ME163 is online now Find More Posts by Komet ME163
Old Oct 21, 2012, 05:57 AM
1st timer is offline
Find More Posts by 1st timer
Inverted tail dragger
1st timer's Avatar
Australia, WA, Kalamunda
Got mine Yesterday can't wait to start building it,but at the moment the 42" comes first,so once that's finished the 59 is on the bench
1st timer is offline Find More Posts by 1st timer
Old Oct 21, 2012, 10:29 AM
Shirty is online now
Find More Posts by Shirty
Aussies fly Down Under!
Shirty's Avatar
Australia, WA, Perth
Joined Oct 2012
Thats my 59 on your bench you mean...
Shirty is online now Find More Posts by Shirty
Old Oct 21, 2012, 09:28 PM
Ogrestud is offline
Find More Posts by Ogrestud
KI4KRA
United States, NC, Spring Lake
Joined May 2005
Finally finished! Took her out today for a possible maiden, but forgot my driver for the spinner and hadn't tightened the prop nut down so I just did some ground maneuvers =)
Ogrestud is offline Find More Posts by Ogrestud
Old Oct 21, 2012, 09:31 PM
RCPilot1234 is offline
Find More Posts by RCPilot1234
Joined Jan 2012
Looks great! The 59 is such a good looking (and flying! ) aircraft
RCPilot1234 is offline Find More Posts by RCPilot1234
Old Oct 22, 2012, 08:06 AM
lowkeylaidback is offline
Find More Posts by lowkeylaidback
Custom Crasher
lowkeylaidback's Avatar
USA, FL, Jacksonville
Joined Jan 2010
Wanted 3dhobbyshop 48" EPP Extra 330 Starboard main wing
Each post of this request was meant to target buyers of models from 3DHS that may like most have more then one model from that vendor as many here do and not use the classified adds this seem to be the only way to reach the buyers of this brand. A little dog not mine ruined my wing and I have not gotten a response from 3DHS since 10/9 about getting a new wing, as the wing is the only part that is damaged I am searching for a replacement
I need the starboard main wing for a 3dhobbyshop 48" EPP Extra 330, if you have one I am in the market, please send me a PM
lowkeylaidback is offline Find More Posts by lowkeylaidback
Old Oct 22, 2012, 08:41 AM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
Dang man you got to be kidding. Every thread?
losifanatic is offline Find More Posts by losifanatic
Old Oct 22, 2012, 08:57 AM
1st timer's Avatar
Hahaha ...no yours is still in tha mail mate
Old Oct 22, 2012, 09:01 AM
shadow102 is offline
Find More Posts by shadow102
shadow102's Avatar
United States, GA, Acworth
Joined Mar 2011
Successful maiden and successful emergency landing on the second flight due to a elevator control rod slipping.
shadow102 is offline Find More Posts by shadow102
Old Oct 22, 2012, 09:03 AM
Joined Jan 2012
Good catch!
I was VERY worried about this happening. What I did was dab some thick CA glue on the seam between the rod and the gromit thing. Hasn't slipped at all
Old Oct 22, 2012, 09:09 AM
PlaneCraz3d is offline
Find More Posts by PlaneCraz3d
Perpetual 3D Noob
PlaneCraz3d's Avatar
United States, KY, Calvert City
Joined Jun 2010
I've been worried about that happening. I think I'm going to change the elevator and ailerons over to double ball links. I wasn't real happy with the aileron linkage geometry anyway. At max throws the servo arm would bind and flex a small amount, ball links would stop this.
Shadow, glad to hear you got it back down in one piece.
PlaneCraz3d is offline Find More Posts by PlaneCraz3d
Old Oct 22, 2012, 09:10 AM
Ogrestud is offline
KI4KRA
Joined May 2005
I used a 5" Titanium turnbuckle Rod and double ball links for the Elevator. It is 4/40 I just used the 4/40 tap set drilled both ball links, then used a drill to thread the turnbuckle into the ball link since one side is reversed thread. Very light, and no worries of failure... well the strong arms could break I guess =)
Old Oct 22, 2012, 09:11 AM
shadow102's Avatar
Joined Mar 2011
i am going to flat spot the rod and put some hot glue on it for the time being until i pick up some double ended ball links
Old Oct 22, 2012, 09:39 AM
GoldCraft is offline
Find More Posts by GoldCraft
GoldCraft's Avatar
United States, GA, Woodstock
Joined Jan 2007
Looks good. Let me know the next time your at JJ and Ill try to get out there. I finally finished up my 30cc 72sc with smoke ....just workn too many days to get a maiden in anytime soon.
GoldCraft is offline Find More Posts by GoldCraft
Wanted 3DHobbyShop 70" AJ Slick bbigdog2243 Aircraft - Electric - Airplanes (FS/W) 2 Jan 01, 2011 12:24 AM
Video 3DHobbyShop Aj Slick ''Rc Day Two Rockin'' with onboard video Get Real Electric Plane Talk 2 Jun 18, 2009 04:07 AM
Sold 3dhobbyshop AJ Slick Wings Flazo Aircraft - Electric - Airplanes (FS/W) 4 May 16, 2009 11:46 PM
Discussion 3DHobbyShop 51" AJ SLICK - how durable for 3D moves? Voyager 3D Flying 13 May 06, 2009 07:10 AM
