Old Oct 12, 2012, 10:59 AM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
Originally Posted by fliprob17 View Post
2cents again so that's 4 total for today
on anything under 70"+/- i stay away from adding excess gear and "spaghetti"
the internal bec's on the ice-75 lite, ice-100 are good to go. If redundancy is what you are after, by all means drop a separate bec in the mix, it just isn't a necessity.
+1.
losifanatic is offline Find More Posts by losifanatic
Old Oct 12, 2012, 11:00 AM
rimaarts is offline
Find More Posts by rimaarts
United Kingdom, London
Joined Jul 2011
on anything under 70"+/- I stay away from adding excess gear and "spaghetti"
the internal BEC's on the ICE-75 Lite, ICE-100 are good to go. If redundancy is what you are after, by all means drop a separate BEC in the mix, it just isn't a necessity.
is internal bec really ok for 4x digitals??? 2x digitals+2x 225's - been running for a while on my 57" but 4 digitals im kinda scared to run without external bec...
rimaarts is offline Find More Posts by rimaarts
Old Oct 12, 2012, 11:03 AM
Sippin the Koolaid!
Joined Oct 2007
It will handle 4 digitals minis like the 5245s with no issues.
Fliprob17 is offline
Find More Posts by Fliprob17
ADC Vinyl
Fliprob17's Avatar
SoCal-Rancho Santa Marg.
Joined Mar 2007
Yep, no issues. With the surfaces taped in place/binded the most I saw was 2.2amps with all servos loaded. The internal BEC is rated at 5amps.
I have the ICE-75 Lite with (4) HS-5245MG's, no issues.
Fliprob17 is offline Find More Posts by Fliprob17
Old Oct 12, 2012, 11:08 AM
PlaneCraz3d is offline
Find More Posts by PlaneCraz3d
Perpetual 3D Noob
PlaneCraz3d's Avatar
United States, KY, Calvert City
Joined Jun 2010
Exactly, Ice 100 lite, 4x 5245mg's motor and esc are cooler than battery which is only warm to the touch after 6-7 mins. I haven't tried the max load test yet, I'll have to do that.
PlaneCraz3d is offline Find More Posts by PlaneCraz3d
Old Oct 12, 2012, 11:34 AM
Shirty is offline
Find More Posts by Shirty
Aussies fly Down Under!
Shirty's Avatar
Australia, WA, Perth
Joined Oct 2012
(Thats 5 cents in Aussie dollars!) Thanks for the explanation.
Shirty is offline Find More Posts by Shirty
Old Oct 12, 2012, 12:11 PM
Trill is offline
Find More Posts by Trill
Trill's Avatar
United States, TN, Murfreesboro
Joined Oct 2008
Max amps to the receiver using an ICE-75
Thanks for the load test data. I wanted to know what is the amp draw with all four HS 5245MG servos loaded using the ICE-75.
My ICE-75 ESC has the one line and connector that goes into the throttle channel on my Spektrum 8 channel receiver. What's the maximum amps the one line and connector from the ESC to the throttle channel will input to the receiver?
Trill is offline Find More Posts by Trill
Old Oct 12, 2012, 12:15 PM
Perpetual 3D Noob
Joined Jun 2010
A standard servo connector is rated for 3 amps continuous, but can handle up to 5 amps burst.
Old Oct 12, 2012, 12:42 PM
Trill is offline
Trill's Avatar
Joined Oct 2008
Preventing electronics failures
Thanks, that's good to know. I'll have to check with Castle to see if the connector is standard or high amp. The ICE-75 is rated for 5 amps. I wouldn't feel safe in presuming that because the ESC can max 5 amps to the servos that the wire and connector supplied with the ICE-75 is rated for 5 amps continuous.
What's the time for 5 amps burst on a standard servo connector? 10 seconds? 20 seconds?
Old Oct 12, 2012, 12:45 PM
shadow102 is offline
Find More Posts by shadow102
shadow102's Avatar
United States, GA, Acworth
Joined Mar 2011
i have been running 4 hs5245's off the internal BEC on a ZTW esc running 6s without a single issue i cant see there being a problem unless you completely short a servo
shadow102 is offline Find More Posts by shadow102
Old Oct 12, 2012, 12:46 PM
Perpetual 3D Noob
Joined Jun 2010
I'm not sure on the time alloted for burst current. I know when charging my A123's through the charge port on the switch with a servo plug (on a different Glow powered plane) I can charge at 4 amps with no heating of the wire of connector, however 5 amps I both the wire and connector start to get warm. This is with a continuous current obviously. Maybe someone else can chime in with better numbers.
Old Oct 12, 2012, 12:58 PM
Trill is offline
Trill's Avatar
Joined Oct 2008
Optimum setups
Guys, thanks for your replies and sharing your experience. I'm still searching for an optimum setup on multiple 48"-65" WS airframes.
Old Oct 12, 2012, 01:10 PM
DocOne is offline
Find More Posts by DocOne
Carpe Fermentum
DocOne's Avatar
United States, VA, Clifton
Joined May 2008
Here's what I ended up getting for mine:
- Motrofly 4315-714 Motor
- Castle Ice 100 ESC
- XOAR 15x7E wood prop
- 4Sx4000 batteries
- HS-225 servos
I'll let you know how it flies in a bit!
Doc
DocOne is offline Find More Posts by DocOne
Old Oct 12, 2012, 01:45 PM
Perpetual 3D Noob
Joined Jun 2010
pics and vids please.
Old Oct 12, 2012, 02:11 PM
RCPilot1234 is offline
Find More Posts by RCPilot1234
Joined Jan 2012
That is some great flying RCPilot! My skills are nowhere near that yet. I'm still closer to a sport flyer with some light 3d mixed in but I'm getting better. I just recieved my replacement 59 yesterday and hope to have it up soon. Those servos do look good, I'm running HS 5245mg's but if ever need to upgrade I may try them out. Are you still having trouble with them jittering at center?
Thanks!
I am having trouble with them jittering (others have reported this also with the 7245's) but I can honestly say it does not affect flight performance at all. And if you wish to stop it, just place a small piece of Velcro between the counterbalance on the evelevator and the horizontal stab (as the pressure stops the jittering)
RCPilot1234 is offline Find More Posts by RCPilot1234
Wanted 3DHobbyShop 70" AJ Slick bbigdog2243 Aircraft - Electric - Airplanes (FS/W) 2 Dec 31, 2010 11:24 PM
Video 3DHobbyShop Aj Slick ''Rc Day Two Rockin'' with onboard video Get Real Electric Plane Talk 2 Jun 18, 2009 03:07 AM
Sold 3dhobbyshop AJ Slick Wings Flazo Aircraft - Electric - Airplanes (FS/W) 4 May 16, 2009 10:46 PM
Discussion 3DHobbyShop 51" AJ SLICK - how durable for 3D moves? Voyager 3D Flying 13 May 06, 2009 06:10 AM
