Old Oct 02, 2012, 05:56 PM
chq28 is offline
Find More Posts by chq28
chq28's Avatar
USA, MI, Portage
Joined Feb 2009
Originally Posted by DocOne View Post
OK,
I went with the Mortrofly 4315-714 and Ice Lite 100 amp. All is good.
However I went to order some Gens Ace 4S 3800 or 4000's and of course Hobby Partz is out of stock on both (even though they showed in stock).
Recommendations for inexpensive 4S-3800 or 4S-4000 batteries? I would prefer something in the $40-50 range as opposed to the $100+ battery range.
Doc
Here is another option that people have been happy with. EPBuddyhttp://http://epbuddy.com/index.php?...roducts_id=367
chq28 is offline Find More Posts by chq28
Old Oct 02, 2012, 06:03 PM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Your link doesn't work, but probably the same Glacier battery I suggested....
SteveT
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Oct 02, 2012, 06:22 PM
Trill is offline
Find More Posts by Trill
Trill's Avatar
United States, TN, Murfreesboro
Joined Oct 2008
Glacier 4S 4000 mAh batteries
Originally Posted by SteveT. View Post
Haven't tried them myself, but I hear the Glacier Lipos for EPBuddy are good... I know that Ben Fisher has said he likes them, and that's good enough for me!!
SteveT
+1 on the Glacier batteries! I have three 4S 4000 mAh Glacier batteries. They perform as well as my Gens Ace batteries.
Added benefits of the Glacier batteries:
1) T Plug (Deans compatible) is preinstalled.
2) Removable AB clip to protect the balance connector is preinstalled.
Trill is offline Find More Posts by Trill
Old Oct 02, 2012, 07:17 PM
Wing-span is offline
Find More Posts by Wing-span
Chuck it and see!
Wing-span's Avatar
UK, Cambridgeshire, Huntingdonshire
Joined Sep 2006
Does anyone fly this plane on 6s 5000mah?
Wing-span is offline Find More Posts by Wing-span
Old Oct 02, 2012, 07:26 PM
Trill is offline
Trill's Avatar
Joined Oct 2008
6S battery sizes for the 59" AJ Slick
Per theKM, 3DHS Team pilot "As for packs... both are perfect for 4S 4000's. going to 6S... this is just about energy density. 6S 2600 is pretty much the same weight as 4S 4000. If you use 6S 2200's, you'll actually have a lighter setup (and shorter flight times as a result), and 6S 3000's a heavier setup. If you use 6S 2600's, you wont have to move anything around as everything should be able to work out the same. 6S 3000's, you may need to use a tail mounted rudder servo."
Old Oct 02, 2012, 07:27 PM
losifanatic is online now
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
No. Thats 65+inch plane area. Way to heavy for the 59
losifanatic is online now Find More Posts by losifanatic
Old Oct 02, 2012, 08:25 PM
RCPilot1234 is offline
Find More Posts by RCPilot1234
Joined Jan 2012
Originally Posted by Trill View Post
Yes, your analysis is helpful. I have the 51 Slick and the 71 Slick. Please elaborate on how the 59 is different fom the 51. I'm particularly interested in how it feels more refined. Losifanatic wrote that the 59 is like a refined 57" Extra 330SC.
"http://www.rcgroups.com/forums/showthread.php?t=1713694#post22883666 post #13 gives a 3DHS Team member's analysis of the difference between the 57" Extra 330SC and the 59" AJ Slick.
The discussion of the Motrolfly 4815-480 is spot on.
Thanks for sharing!
Glad to be of help!
It just feels sharper and tracks better. I prefer the design of it as well
RCPilot1234 is offline Find More Posts by RCPilot1234
Old Oct 02, 2012, 09:18 PM
Sippin the Koolaid!
Joined Oct 2007
The slick hovers better too
Old Oct 02, 2012, 09:33 PM
Trill is offline
Trill's Avatar
Joined Oct 2008
59 vs 51
Just what I needed to read. I expect the flight envelope of the 59 to help take me to the next level of precision and 3D flight!
Old Oct 02, 2012, 09:35 PM
Joined Jan 2012
Just what I needed to read. I expect the flight envelope of the 59 to take me to the next level of precision and 3D flight!
Definitely! The plane is pretty docile when you want it to but will 3D like mad when you want it to as well
Old Oct 02, 2012, 09:48 PM
TK421 is offline
Find More Posts by TK421
Plainfield, IN
Joined Sep 2004
I finally got two flights on mine sunday. This plane is amazing! I flew the maiden in 15mph winds and it was totally a non-event. I can't wait to fly her on a calm day.
4315-714, Ice 100 lite, CC BEC, 9650's all around with metal gear conversion on the rudder, 15x7 APC, and a Gens Ace 25c 4s 4000.
I read what everyone else was using as I did not want to reinvent the wheel with this project. The power is stunning! I spend most of the flight at half throttle and only burned 2500mah after 6 mins.
Thanks to all for my repeated question answering. This plane is for sure a keeper.
Lou
TK421 is offline Find More Posts by TK421
Old Oct 02, 2012, 10:11 PM
Trill is offline
Trill's Avatar
Joined Oct 2008
59 in the wind
Lou
Thanks for your flight report. I especially enjoyed reading that the 59 is at home in
15mph winds.
Old Oct 03, 2012, 04:15 AM
AlexGold is offline
Find More Posts by AlexGold
AlexGold's Avatar
Russian Federation, Voronezhskaya oblast, Voronezh
Joined Mar 2011
Flown Slick yesterday with Mortrofly 4315-714, Ice Lite 75 and XOAR 15x7 for the first time. Did 40 flights with APC 15x7 before this moment. Wow! There is huge difference between this props! I will never fly APC again. With XOAR it has much more speed and power and it's more predictable in hover, torqu roll and harrier. I was able to bring everything much closer to the ground. Ice Lite 75 withstood 1250W good. I measured peak 84A in static and 81A in flight. ESC was barely warm after flight.
Oh, forgot to mention, I've changed throttle response to high (8)
AlexGold is offline Find More Posts by AlexGold
Old Oct 03, 2012, 06:59 AM
Joined Jan 2012
Awesome! Yes, changing throttle response is a must! Thas why I love the Castle's, as when set to 10, it's just so sharp. The Hacker ESC I tried once just felt mushy, haha!
Old Oct 03, 2012, 07:03 AM
TK421 is offline
Plainfield, IN
Joined Sep 2004
Anyone have a link for the xoar prop? I can't seem to find it in stock anywhere.
Lou
Wanted 3DHobbyShop 70" AJ Slick bbigdog2243 Aircraft - Electric - Airplanes (FS/W) 2 Dec 31, 2010 11:24 PM
Video 3DHobbyShop Aj Slick ''Rc Day Two Rockin'' with onboard video Get Real Electric Plane Talk 2 Jun 18, 2009 03:07 AM
Sold 3dhobbyshop AJ Slick Wings Flazo Aircraft - Electric - Airplanes (FS/W) 4 May 16, 2009 10:46 PM
Discussion 3DHobbyShop 51" AJ SLICK - how durable for 3D moves? Voyager 3D Flying 13 May 06, 2009 06:10 AM
