Old Sep 25, 2012, 04:05 PM
dentalpain is offline
Find More Posts by dentalpain
dentalpain's Avatar
United States, FL, Marianna
Joined Apr 2011
3DHS 59 Slick
Motrolfly 4315 -800
Ice 100 Lite
Xoar 15x7
Hitec HS-225MGs x4
Spektrum AR600
Gens Ace 4s4000 25C
Castlelink Settings:
Fixed End Points
Throttle Response: High (8)
Motor Start Power Custom (75)
Motor Timing Low (0)
PWM Rate 8Khz
BEC 6v
Logging Disabled.
Watts Up Power Readings:
79 Amps
1170 Watts
3DHS 57 Extra
Motrolfly 4315-714
Ice 100 Lite
Protek 15x7
Hitec HS225MG x4
Spektrum AR600
Gens Ace 4s4000 25C
Fixed End Points
Throttle Response: Medium (5)
Motor Start Power: Medium (59)
Motor Timing: Normal (5)
PWM Rate 12 Khz
Bec 6v
Logging Disabled.
Watts Up Power Readings: (End Points 73/74)
88 Amps
1370 Watts
Alt Settings
Throttle Respons: High (8)
Motor Start Power: Custom (75)
PWM Rate 8Khz
1240 Watts
82 Amps
dentalpain is offline Find More Posts by dentalpain
Old Sep 27, 2012, 01:03 PM
RCPilot1234 is offline
Find More Posts by RCPilot1234
Joined Jan 2012
Here's my build thread on the 59 over at High Alpha http://www.highalpha.org/forum/viewt...hp?f=4&t=12458
I may post it here and on 3DRC also but will see as there's already so much info on this great plane here already
RCPilot1234 is offline Find More Posts by RCPilot1234
Old Sep 29, 2012, 09:11 AM
FlyDude is offline
Find More Posts by FlyDude
I still get nervous on final
FlyDude's Avatar
Richmond, VA
Joined Mar 2007
Very nice build review RCPilot. I especially liked the high quality in-flight photos. I picked up a Red '59 during the recent sale and will reference your tips when I assemble her.
I ordered the 4315 714 and was thinking of using one of the ZTW "B" series speed controls. They have adjustable BEC output voltage with a 5A continuous current rating. I've heard that their leads are on the short side. For anyone using the ZTW's, are there any issues with the leads not being long enough to reach the battery connector?
I've read that it is not recommended to lengthen the input wires, as an increase in voltage ripple can occur which can damage the input caps over time.
BUD...
FlyDude is offline Find More Posts by FlyDude
Old Sep 29, 2012, 10:20 AM
Eagle34 is offline
Find More Posts by Eagle34
TEAM HILLBILLY
Eagle34's Avatar
Pass Christian, MS
Joined Jan 2010
Nice build log. Did I read that right that you glued in your wing tube? Don't think I'll be doing that as I remove the wings for transport.
Eagle34 is offline Find More Posts by Eagle34
Old Sep 29, 2012, 06:24 PM
Joined Jan 2012
I haven't, haha! Although I did on another plane once and regretted it, LOL!
Old Sep 29, 2012, 07:03 PM
Joined Jan 2012
Testing out my new iPhone 5 camera on my 59 Slick!
iPhone 5 Camera Test: 3DHS 59 Slick Low and Slow 3D! (4 min 59 sec)
Will maybe remove the video in a few days due to it not being up to my standards. Although I'll see what you guys think of it It was just a test of the camera and iMovie app, haha!
Old Sep 29, 2012, 07:22 PM
H.D. is offline
Find More Posts by H.D.
ride hard and fly low
H.D.'s Avatar
Joined Aug 2011
Looking good RCPilot.
H.D. is offline Find More Posts by H.D.
Old Sep 29, 2012, 08:00 PM
Joined Jan 2012
Thanks! Much appreciated!
Old Sep 29, 2012, 08:24 PM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
http://www.youtube.com/watch?v=10Qp34FD0ZA
Nothing wrong with either the flying or video!! Both very good!!
SteveT
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Sep 29, 2012, 08:33 PM
Joined Jan 2012
SteveT
Thanks Steve!
Old Sep 30, 2012, 06:24 PM
DocOne is offline
Find More Posts by DocOne
Carpe Fermentum
DocOne's Avatar
United States, VA, Clifton
Joined May 2008
Don't have time to read all 400+ messages at the moment, but what do you recommend for ideal motor/prop/battery combo for this plane?
Doc
DocOne is offline Find More Posts by DocOne
Old Sep 30, 2012, 07:27 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
I love the Motrolfly 4315-714 on 4S in this plane...as do many others.... The plane in the video that "RCPilot1234" posted just a few posts back is powered by one.
SteveT
Old Sep 30, 2012, 07:29 PM
Joined Jan 2012
Doc
Hey buddy, this is the setup I have and is pretty much the best most expensive setup you can get for this plane
Motor: Motorfly DM4315-714 lightened version (only available from Subsonic planes)
Prop: Xoar 15x7
Battery: Thunder Power 3850mAh 65C 4S (will give flight times of around 4-5 minutes flying hard and 6-7 going gentle. Keeps the weight down fairly well too )
ESC: Castle ICE Lite 100
Servos: Qty 4. HS7245MH set to 7.4V (can do this by powering the servos through a 2S LiPo or setting the BEC on the ICE Lite 100 to 7.4V (you will need the Caslte USB Programming kit to do that). Alternatively you could use an external BEC like I do (I use Castle 10A BEC - still need the programmer to adjust voltage, though). If using external BEC or 2S LiPo to power servos, make sure to disconnect the middle red wire coming from the servo wire on the ESC to the receiver to stop it feeding any voltage into it )
Servo arms: Du-Bro ones (on the 3DHS site)
Hope this helps!
Old Sep 30, 2012, 07:31 PM
Alex Schauer is offline
Find More Posts by Alex Schauer
Alex Schauer's Avatar
United States, MN, North Mankato
Joined Feb 2011
Well you could get a Kontronik ESC and THEN you would have the absolute TOP OF THE LINE
Alex Schauer is offline Find More Posts by Alex Schauer
Old Sep 30, 2012, 09:13 PM
DocOne is offline
Carpe Fermentum
DocOne's Avatar
Joined May 2008
Do I need the Ice 100 with the motrolfly motor or can I get away with the Ice 75 ESC? I ask because I have a 75 laying around.
Doc
Wanted 3DHobbyShop 70" AJ Slick bbigdog2243 Aircraft - Electric - Airplanes (FS/W) 2 Dec 31, 2010 11:24 PM
Video 3DHobbyShop Aj Slick ''Rc Day Two Rockin'' with onboard video Get Real Electric Plane Talk 2 Jun 18, 2009 03:07 AM
Sold 3dhobbyshop AJ Slick Wings Flazo Aircraft - Electric - Airplanes (FS/W) 4 May 16, 2009 10:46 PM
Discussion 3DHobbyShop 51" AJ SLICK - how durable for 3D moves? Voyager 3D Flying 13 May 06, 2009 06:10 AM
