Old Sep 03, 2012, 12:19 PM
keithy4129 is offline
Find More Posts by keithy4129
United States, NJ, Clayton
Joined Aug 2010
Originally Posted by keithy4129 View Post
+1, I run hitec hs-5245 servos all the way around (digital) with the built in bec on my hacker x70, flawless, I did try a 2s a123 (life) pack to get a higher voltage but the added weight wasnt worth it.
i should add that I run this set-up on my 58" edge
keithy4129 is offline Find More Posts by keithy4129
Old Sep 03, 2012, 12:21 PM
Joined Aug 2010
Originally Posted by Mr Big Head View Post
Did they change the scheme on the 59 from the original?
to my knowledge this is the original 59" slick (version 1)
Old Sep 03, 2012, 12:22 PM
H.D. is offline
Find More Posts by H.D.
ride hard and fly low
H.D.'s Avatar
Joined Aug 2011
The 59" Slick is one great looking plane.
H.D. is offline Find More Posts by H.D.
Old Sep 03, 2012, 12:31 PM
Joined Aug 2010
looks even better out of the box! its a rainy day, what are you waiting for?
Old Sep 03, 2012, 12:37 PM
H.D. is offline
H.D.'s Avatar
Joined Aug 2011
I fly inside on rainy days.
Old Sep 04, 2012, 09:26 AM
Mr Big Head is offline
Find More Posts by Mr Big Head
Mr Big Head's Avatar
United States, CA, Redding
Joined Feb 2011
The pics they have on the website show the planes without any of the small stars on them.
Mr Big Head is offline Find More Posts by Mr Big Head
Old Sep 04, 2012, 10:42 AM
RCPilot1234 is offline
Find More Posts by RCPilot1234
Joined Jan 2012
I noticed that too I think the photos were shot of Andrew Jesky's prototype version which I guess didn't need the stars
RCPilot1234 is offline Find More Posts by RCPilot1234
Old Sep 04, 2012, 10:56 AM
Eboyles is offline
Find More Posts by Eboyles
Eboyles's Avatar
United States, NY, Smallwood
Joined Aug 2011
hs-5245mg
I just put together a 59inch slick with these servos, great servos but unfortuantly one locked up on the 7th flight this last weekend. I almost saved it but at about 5 feet off the ground it started to tip stall and i corrected but didnt add some throttle, it pancaked the ground breaking in half right behind the Gear.
Fixed it already and contacted hitec and there replacing my servo for me as there were about 1 week old.
Bought a whole new plane before i was like well ill fix this. So now i have a brand new one on the way and my repaired slightly heavier one. More the merrier.
Eboyles is offline Find More Posts by Eboyles
Latest blog entry: Bigfoot.
Old Sep 04, 2012, 11:27 AM
dentalpain is offline
Find More Posts by dentalpain
dentalpain's Avatar
United States, FL, Marianna
Joined Apr 2011
Just pulled some info from my 59 Slick for your consumption. Poor baby has been sold. Its was a great flying plane and I hate to see it go (it wont go far)
3DHS 59 Slick
Motrolfly 4315 -800
Ice 100 Lite
Xoar 15x7
Hitec HS-225MGs x4
Spektrum AR600
Gens Ace 4s4000 25C
Castlelink Settings:
Fixed End Points
Throttle Response: High (8)
Motor Start Power Custom (75)
Motor Timing Low (0)
PWM Rate 8Khz
BEC 6v
Logging Disabled.
Watts Up Power Readings:
79 Amps
1170 Watts
dentalpain is offline Find More Posts by dentalpain
Old Sep 04, 2012, 05:04 PM
Joined Jan 2012
Hucking the 59 This plane is just incredible! So refined and feels chunkier than a 50 airfcraft, but not too intimidating like the 71 I had Really love it
Build log coming very soon
Old Sep 04, 2012, 06:28 PM
dentalpain's Avatar
Joined Apr 2011
Great photos!
Question for the group: My friend want (and is) going to use a Eflight 46 w/ice 75 lite on this plane. I think it is a 670kv motor. What prop and lipos should I recommend?
Old Sep 04, 2012, 06:37 PM
Jboy90277 is offline
Find More Posts by Jboy90277
United States, CA, Palos Verdes Peninsula
Joined Dec 2011
The eflite 46 seems underpowered IMO. I'm flying at about 1250-1300W - the eflite 46 seems to be a 925W motor from their literature, which is closer to the power level of my 48" planes.
Jboy90277 is offline Find More Posts by Jboy90277
Old Sep 05, 2012, 08:13 AM
nebwake is offline
Find More Posts by nebwake
nebwake's Avatar
United States, NE, Lincoln
Joined Mar 2011
this plane would fly on 925W no problem, although 1300W from a motrolfly 4315 is nuts, it is not needed. Jboy, you must have some ROCKET 48" planes, I run my 48 Edge on about 500W 3DHS only rates their 48" planes at 700W when running 4S systems, which isnt all that fun anyways since they like to be nice and light.
Eflight recommends a prop range of 12x8 to 14x10 on 4-5s packs. I would static test with an amp meter on big 4S packs with a 15x7 or 15x8 and make sure you are not over amping anything and fly it. Eflight also mentions that the MAX burst amp load on this motor is 55A for 15 seconds.
nebwake is offline Find More Posts by nebwake
Old Sep 05, 2012, 08:21 AM
dentalpain's Avatar
Joined Apr 2011
Thanks for the help guys. The 59 is going to an older guy who is a reformed circle flier. He loved the 41" edge I hooked him up with so he wanted more. He already had this motor/esc combo and I thought this airframe would work. No extreme 3d stuff here, but the eflight 46 is listed on recommended components.
The question remains on lipo cell count/prop. Any help here would be greatly appreciated.
Edit: Nebwake - THANKS!
Old Sep 05, 2012, 08:27 AM
Joined Dec 2011
The literature on the eflite motor isn't that impressive for a 3D plane. The configurations they provide get anywhere from 89W/lb to 128W/lb. IIRC, for 3D, you want 150W/lb or better.
I do like to have plenty of power on my planes - great for getting out of trouble while doing 3D and building up smash for a high speed tumble or spin.
Wanted 3DHobbyShop 70" AJ Slick bbigdog2243 Aircraft - Electric - Airplanes (FS/W) 2 Dec 31, 2010 11:24 PM
Video 3DHobbyShop Aj Slick ''Rc Day Two Rockin'' with onboard video Get Real Electric Plane Talk 2 Jun 18, 2009 03:07 AM
Sold 3dhobbyshop AJ Slick Wings Flazo Aircraft - Electric - Airplanes (FS/W) 4 May 16, 2009 10:46 PM
Discussion 3DHobbyShop 51" AJ SLICK - how durable for 3D moves? Voyager 3D Flying 13 May 06, 2009 06:10 AM
