Old Jun 28, 2012, 05:19 PM
RCPilot1234 is offline
Find More Posts by RCPilot1234
Joined Jan 2012
Originally Posted by Mr Big Head View Post
Red is faster! Oh wait that only works on my motorcycle forums! I chose the orange because of the black and white bottom over the blue and white. The sky is blue................
Haha, red is in fact a lot faster!
RCPilot1234 is offline Find More Posts by RCPilot1234
Old Jun 28, 2012, 05:59 PM
Mr Big Head is offline
Find More Posts by Mr Big Head
Mr Big Head's Avatar
United States, CA, Redding
Joined Feb 2011
Faster in any color = a motor from Ken at Motrolfly! My 4315 668 rips on 5 cells with a 15x7 and runs like a normal 3D plane with the same prop on 4 cells. I am waiting on the wind to try it with a 16x8 on 4 cells. Should be Lower and Slower! I love my 59 and I hope they have not changed it up too much as I still need a left wing. Ben are you listening?
Mr Big Head is offline Find More Posts by Mr Big Head
Old Jun 28, 2012, 10:40 PM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Awesome to hear that!
And that's why I want this plane, because it just looks so nice! If ADC HobbyStore lets me due to shipping, I might order two just incase it goes out of stock and I ever need spares
Now, just need to decide orange or red? I really like the black outlines on the cowl on the red so I think I might just have to be that!
All it takes is money....I don't think ADC is going to restrict the number you can buy..
SteveT
SteveT. is online now Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Jun 28, 2012, 10:54 PM
PowerSlave is offline
Find More Posts by PowerSlave
Gaint Scale
PowerSlave's Avatar
United States, KY, Louisville
Joined Dec 2009
Ooooo, which MKS servos do you use? I'm a massive fan of theirs!
Thanks!
DS9660A+
Details
SKU RC-MKS-DS9660A+ Dead Band 0.0008ms (Default) Control System +Pulse Width Control Working Frequence 1520μs / 333hz
(RX) Required Pulse 3.0 ~6.0 Volt Peak to Peak Square Wave Operating Voltage 4.8 ~6.0 V DC Volts
Operating Temperature Range
-10 to + 60 Degree C
Operating Speed (4.8V) 0.12 sec/60 degrees at no load Operating Speed (6V) 0.09 sec/60 degrees at no load Stall Torque (4.8V) 3.8 kg.cm (52.8 oz/in)
Stall Torque (6V) 4.7 kg.cm (65.3 oz/in) 360 Modifiable NO Motor Type Coreless Motor Potentiometer Drive Indirect Drive
Driver Type FET Bearing Type Dual Ball Bearings Gear Type 1 Titanium Gears + 4 aluminum-alloy Gears Programmable NO Connector Wire Length 24.0 cm (9.4 in)
Dimensions 35.8X15.2X29 mm (1.41x 0.6x 1.14 in) Weight 28 g (0.99 oz)
PowerSlave is offline Find More Posts by PowerSlave
Old Jun 29, 2012, 04:25 AM
Gaint Scale
PowerSlave's Avatar
Joined Dec 2009
The DS9660A+ are listed for $69.99 each but one of my local hobby shops had them for $20.99 each so I bought everyone they had. I've been very happy with them. Others that have flown my 59 could also tell the difference between them and the Hitec servos.
Old Jun 29, 2012, 04:32 AM
Gaint Scale
PowerSlave's Avatar
Joined Dec 2009
They are also a little bigger than the Hitec servos so you will need to open the holes in the plane. It's only a very small small amount.
Old Jun 29, 2012, 06:12 AM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
I like MKS servos.
losifanatic is offline Find More Posts by losifanatic
Old Jun 29, 2012, 07:08 AM
Joined Jan 2012
That's great to hear! And they're lighter than the Hitecs!
Joined Jan 2012
SteveT
I'll email them and ask!
Old Jun 29, 2012, 07:09 AM
Joined Jan 2012
Originally Posted by losifanatic View Post
I like MKS servos.
Same - they are such good quality!
Old Jun 29, 2012, 09:01 AM
Gaint Scale
PowerSlave's Avatar
Joined Dec 2009
Here is a few shots of the servos.
Old Jun 30, 2012, 03:42 PM
Reaper802 is offline
Find More Posts by Reaper802
Reaper802's Avatar
United States, MD, Lexington Park
Joined Jun 2002
New rudder is here! Will install tomorrow and if this heat doesn't kill me should be able to get her back in the air.
Reaper802 is offline Find More Posts by Reaper802
Old Jun 30, 2012, 06:26 PM
Gaint Scale
PowerSlave's Avatar
Joined Dec 2009
Did some more prop testing today. Props used APC 15x6 15x7 15x8 and XOAR 15x7. I was not expecting the Xoar to be the worst of the 4 but at only 900+ watts its was. The APC 15x8 was my favorite one of the bunch with the best feel and also pushed out 1300 watts. The APC 15x7 would be my second choice.
Set up was on a Motorlfly 3620-750, Castle Ice Lite 100, 4cell 4000mah 40c
Old Jun 30, 2012, 08:15 PM
aero550 is offline
Find More Posts by aero550
United States, OH, Tipp City
Joined Oct 2011
Interesting. I have the exact same motor/ESC/Batt combo. I started flying mine on an APC 15x8 but felt it was too fast. It would zoom out of a manuever with the least little blip of throttle. I was having trouble flying slow, gentle stuff. I have since tried a Xoar 15x7 and am currently using a Xoar 15x6 - It really settled it down. I still have plenty of "get out of trouble" power and it takes off in about a foot, it seems, so overall power is still not an issue. It just seems like softer, more user friendly power.
I'm still a newb, though, so take that all with a grain of salt. I may start ratcheting up the prop again as I get better. I really like the look of that wood prop, though, so I'd probably stick with the Xoar.
aero550 is offline Find More Posts by aero550
Old Jun 30, 2012, 08:26 PM
Joined Jan 2012
Thanks for that! very much appreciated!
So you think these will be better than Hitec 7245MH? I've noticed the MKS don't quite have as much torque, you're not experiencing any blow-back are you?
Wanted 3DHobbyShop 70" AJ Slick bbigdog2243 Aircraft - Electric - Airplanes (FS/W) 2 Dec 31, 2010 11:24 PM
Video 3DHobbyShop Aj Slick ''Rc Day Two Rockin'' with onboard video Get Real Electric Plane Talk 2 Jun 18, 2009 03:07 AM
Sold 3dhobbyshop AJ Slick Wings Flazo Aircraft - Electric - Airplanes (FS/W) 4 May 16, 2009 10:46 PM
Discussion 3DHobbyShop 51" AJ SLICK - how durable for 3D moves? Voyager 3D Flying 13 May 06, 2009 06:10 AM
