Old Mar 03, 2011, 12:17 PM
TG43 is offline
Find More Posts by TG43
TG43's Avatar
Glens Falls, NY
Joined Apr 2010
When using HS-225mg's, how many packs of the 672 arms will be needed?
TG43 is offline Find More Posts by TG43
Old Mar 03, 2011, 12:40 PM
starzen is offline
Find More Posts by starzen
starzen's Avatar
USA, FL, Stuart
Joined Jul 2009
one package should be fine
starzen is offline Find More Posts by starzen
Old Mar 03, 2011, 12:44 PM
ryan_m is offline
Find More Posts by ryan_m
doh!
ryan_m's Avatar
United States, AR, Little Rock
Joined May 2006
I've only got a handful of flights so far, and still getting it settled. I'm using Hyperion 4s4200 35c packs, and so far flying for 7 minutes and putting back about 2500. I will probably settle on 7:30-8 minute times expecting about 3000 mah drawn. I like to leave a bit of margin, flying only 70% or so out of my packs.
My style of flying tends to be more low/slow, not heavy throttle usage. So if you are more high energy and zooming around you will get less...
ryan_m is offline Find More Posts by ryan_m
Old Mar 03, 2011, 12:49 PM
xxD-Manxx is offline
Find More Posts by xxD-Manxx
Go Fly Yourself...!!
xxD-Manxx's Avatar
United States, WA, Bonney Lake
Originally Posted by starzen View Post
you'll probably need the Dubro 672 arms
FYI:
These Hyperion arms work great and a you'll save couple of dollars too!
http://www.rcdude.com/servlet/the-15...vo-Arms/Detail
D-Man
xxD-Manxx is offline Find More Posts by xxD-Manxx
Old Mar 03, 2011, 04:37 PM
starzen is offline
starzen's Avatar
USA, FL, Stuart
Joined Jul 2009
picked up my motrolfly 3625-800 today (a first for me as almost a hacker snob to date well besides a reaper and a few omegas and a turnigy or 2)
for those who have already flown the 3625-800. i am planning on using it on 4S on the 59. What props are you guys using and whats the amps/watts you are getting from this ?
wonder how it compares to my gr60 on the 57. currently i am using a 14x8.5 on the gr60 at 86amps or so 1300W
only other question: are they here yet ?
wow - another month ...
Old Mar 03, 2011, 05:30 PM
SalamSyed is online now
Find More Posts by SalamSyed
Fly Low-Fly 3D-Fly Often
SalamSyed's Avatar
United States, DC, Washington
Joined Oct 2009
Will this 59" have a pull pull or a direct link to the rudder setup?
SalamSyed is online now Find More Posts by SalamSyed
Old Mar 03, 2011, 05:38 PM
theKM is offline
Find More Posts by theKM
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
it's a choice based on balance. so far we're all flying them pull-pull... AJ and I both fly with the plane ahead of neutral... if you preferred the CofG back further the rudder servo could ride in the back (also if you ran a heavier power system, etc)... it's a balance thing.
theKM is offline Find More Posts by theKM
Latest blog entry: Updated Hatcam - Apr2016
Old Mar 03, 2011, 05:39 PM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
Probably both. Pull pull for a light setup and direct for a heavy. Just guessing as the rest of the 3dhs line up is that way
losifanatic is offline Find More Posts by losifanatic
Old Mar 03, 2011, 08:24 PM
SalamSyed's Avatar
Joined Oct 2009
theKM, that exactly I wanted to know that what 3DHS view point is on this Thanks
Old Mar 03, 2011, 08:44 PM
ryan_m is offline
doh!
ryan_m's Avatar
Joined May 2006
I don't know that I ever put mine on a wattmeter to get an accurate reading on the watts. I think with the 14x7 it was around 1200 or so. I wound up flying a 15x6 mostly on it. With the 800kv it flew very quick with the 14x7 at full power, the 15x6 was a touch better. I suspect the watts there were 1250 or so, pretty similar to what you used on the GR60.
I'll say this... I burned up an Ice 75 on mine. So I think it was pulling more than 75 amps. Though that said, this was around the time that Castle announced the recall on some Ice series due to heat sinks. I don't know if the ESC burning up was due to that, or to more than 75 amps being drawn through it... at the time it failed it was very low throttle in a harrier about 10 feet high, and had been for the last 20-30 seconds. I now use and plan to continue using Ice 100 lite's on this size plane.
Old Mar 03, 2011, 08:48 PM
starzen is offline
starzen's Avatar
USA, FL, Stuart
Joined Jul 2009
thanks that sounds good. did the same with a hacker 70 on the gr60. completely desoldered every part on the board and burned down the nose on my 57
running an ice 100 lite now
Old Mar 03, 2011, 09:40 PM
xraydoc is offline
Find More Posts by xraydoc
xraydoc's Avatar
Little Rock, AR
Joined Apr 2009
Need some advice
My setup:
Hacker a40 10s on 4s packs probably xoar 15x7 prop
I ordered a ice LITE 100 for the plane and they sent me a REGULAR Ice 100.
The regular is about 1oz heavier than the lite.
Is it worth sending the esc back to get the ice lite or should I just run the regular ice 100 with the 1oz penalty?
xraydoc is offline Find More Posts by xraydoc
Old Mar 03, 2011, 09:42 PM
aerosheldon is offline
Find More Posts by aerosheldon
No one has more fun than me
aerosheldon's Avatar
United States, CO, Denver
Joined Sep 2003
I hope you are OK because I ordered the regular ICE 100 yesterday (that's what I wanted)...
aerosheldon is offline Find More Posts by aerosheldon
Sippin the Koolaid!
Joined Oct 2007
Take the ice regular its worth haveing!!! That one ounce wont hurt a thing
Old Mar 04, 2011, 12:34 PM
Kevinr25 is offline
Find More Posts by Kevinr25
Joined Jun 2008
Has any one orded or tryed the new Motorlfly 3620-750. and how does it compare to the 3625-800?
Thanks for any input
Kevinr25 is offline Find More Posts by Kevinr25
Wanted 3DHobbyShop 70" AJ Slick bbigdog2243 Aircraft - Electric - Airplanes (FS/W) 2 Dec 31, 2010 11:24 PM
Video 3DHobbyShop Aj Slick ''Rc Day Two Rockin'' with onboard video Get Real Electric Plane Talk 2 Jun 18, 2009 03:07 AM
Sold 3dhobbyshop AJ Slick Wings Flazo Aircraft - Electric - Airplanes (FS/W) 4 May 16, 2009 10:46 PM
Discussion 3DHobbyShop 51" AJ SLICK - how durable for 3D moves? Voyager 3D Flying 13 May 06, 2009 06:10 AM
