Old Mar 02, 2011, 05:05 PM
fltekdiver is offline
Find More Posts by fltekdiver
United States, FL, Melbourne
Joined Jan 2010
Can you run 6S on the 59", or would it be to much in Florida?
I could use my 6S 5000mah lipos for both the 71" & the 59"
fltekdiver is offline Find More Posts by fltekdiver
Old Mar 02, 2011, 05:12 PM
blucor basher is offline
Find More Posts by blucor basher
ExtremeFlight - 3DHS - Legacy
blucor basher's Avatar
United States, TX, Tyler
Joined Jun 2003
6S 5000mah would be far too much.
More like 6S 2750-3000mah.
blucor basher is offline Find More Posts by blucor basher
Old Mar 02, 2011, 05:35 PM
Joined Jan 2010
Thanks, I figured that
I pre-ordered the 59", and have to buy the recommended set up here soon
One question, the servos recommended looks like their less then the 51" Slicks use, I was wondering are the servos recommended ok for a 59" plane?
Old Mar 02, 2011, 06:25 PM
Joined Jun 2003
51" Slick uses HS-85MG.
59" Uses larger HS-225MG.
Old Mar 02, 2011, 06:36 PM
aerosheldon is offline
Find More Posts by aerosheldon
No one has more fun than me
aerosheldon's Avatar
United States, CO, Denver
Joined Sep 2003
Originally Posted by Andrew Jesky View Post
If it were me I would be running the 5s setup that I'm running, it just works out well and had quite a bit of power at my 4500 msl.
Andrew
Good enuff for me, I will go 5S. Thanks again for the great designs and for being so helpful! I can't wait for the orange 59 to arrive! I have the Futaba servos and the ICE 100 waiting, now for the motor/battery order tomorrow...
aerosheldon is offline Find More Posts by aerosheldon
Old Mar 02, 2011, 06:40 PM
Joined Jan 2010
Ok, the words Mighty Mini were throwing me off
I just looked up the specs, and its pumping out 54oz @ 4.8 volts
Old Mar 02, 2011, 10:32 PM
SalamSyed is online now
Find More Posts by SalamSyed
Fly Low-Fly 3D-Fly Often
SalamSyed's Avatar
United States, VA, Springfield
Joined Oct 2009
If using HS-225MG, which Dubro servo arms will go with it or if they are not really required?
With HS-85MG 3DHS suggests to use DUB-672 Servo Arms. Will these work with HS-225MG?
SalamSyed is online now Find More Posts by SalamSyed
Old Mar 02, 2011, 10:46 PM
Joined Jun 2003
yes, 672 is good.
Old Mar 02, 2011, 10:48 PM
Andrew Jesky is offline
Find More Posts by Andrew Jesky
Andrew Jesky's Avatar
United States, UT, Tooele
Joined Oct 2002
Glad to hear!!! Your going to have an awesome setup with that, exactly what I have and use!
Andrew
Andrew Jesky is offline Find More Posts by Andrew Jesky
Old Mar 02, 2011, 10:50 PM
xraydoc is offline
Find More Posts by xraydoc
xraydoc's Avatar
Little Rock, AR
Joined Apr 2009
I'm new to this size plane and bought hitec 5245 servos for it.
Will the stock arms do the job as far as getting the needed throws or do I need to get longer aftermarket ones?
xraydoc is offline Find More Posts by xraydoc
Old Mar 03, 2011, 08:31 AM
3DKid1995 is offline
Find More Posts by 3DKid1995
3DKid1995's Avatar
Woodland Hills CA
Joined Jun 2009
This or the 57" Extra!!!!!!!!!!!!! I can't choose! Anyway if I get one my setup will be:
Hacker A40-10s (APC 14x7e)
ICE 100 (I have it laying around)
Hitec HS225MGs/long throw arms
ZIPPY Flightmax 4000mAh 4S1P 20C
3DKid1995 is offline Find More Posts by 3DKid1995
Old Mar 03, 2011, 08:37 AM
starzen is offline
Find More Posts by starzen
starzen's Avatar
USA, FL, Stuart
Joined Jul 2009
definately both. The 57 is awesome and i know the 59 will be so it is on order
i will be using the motrolfly 36250-800
will be interesting how it compares to my 57 rocket with the gr60. with a 15x8 it was pulling 96A now i am using a 14x8 at 86A
starzen is offline Find More Posts by starzen
Old Mar 03, 2011, 08:38 AM
starzen is offline
starzen's Avatar
USA, FL, Stuart
Joined Jul 2009
Originally Posted by xraydoc View Post
I'm new to this size plane and bught hitec 5245 servos for it.
you'll probably need the Dubro 672 arms
Old Mar 03, 2011, 08:54 AM
ryan_m is offline
Find More Posts by ryan_m
doh!
ryan_m's Avatar
United States, AR, Little Rock
Joined May 2006
Slick.
You might want a 15x7 prop, I tried a 14x7, 15x6, and landed on a 15x7 with that motor. Not that the 14x7 won't fly it, but the motor is capable of more power pretty comfortably, and the 15x7 gets you that power.
ryan_m is offline Find More Posts by ryan_m
Old Mar 03, 2011, 11:56 AM
3DKid1995's Avatar
Woodland Hills CA
Joined Jun 2009
Originally Posted by ryan_m View Post
Slick.
What is your flight time with the 15x7?
Wanted 3DHobbyShop 70" AJ Slick bbigdog2243 Aircraft - Electric - Airplanes (FS/W) 2 Dec 31, 2010 11:24 PM
Video 3DHobbyShop Aj Slick ''Rc Day Two Rockin'' with onboard video Get Real Electric Plane Talk 2 Jun 18, 2009 03:07 AM
Sold 3dhobbyshop AJ Slick Wings Flazo Aircraft - Electric - Airplanes (FS/W) 4 May 16, 2009 10:46 PM
Discussion 3DHobbyShop 51" AJ SLICK - how durable for 3D moves? Voyager 3D Flying 13 May 06, 2009 06:10 AM
