This thread is privately moderated by Damian Couzoff, who may elect to delete unwanted replies.
Old Feb 22, 2011, 05:19 AM
Damian Couzoff is offline
Find More Posts by Damian Couzoff
Damian Couzoff's Avatar
Melbourne,Victoria,Australia
Joined Apr 2010
Build Log
DG 808S-4 METRE-Graupner Spoilers -370mm
I am in the process of fitting Graupner spoilers-370mm in length,to my DG 808S-4 Metre scale slope glider.This model has no spoilers,only flaps.A y reverser lead,and two HS 82 MG servos are required to fit out and metal threaded rod and metal clevises-dubro.Total cost to fit out is $190 Australian Dollars.The flap servo well will be used for the spoiler servo.UPDATED-21/3/2011-GO TO COMMENTS
Damian Couzoff is offline Find More Posts by Damian Couzoff
Old Feb 22, 2011, 07:47 AM
bwilman is offline
Find More Posts by bwilman
Melbourne
Joined Apr 2005
Why not keep the flaps and the spoilers? wouldn't that be more effectuve?
bwilman is offline Find More Posts by bwilman
Old Feb 23, 2011, 05:08 AM
Joined Apr 2010
Hi Brad,There is only enough room for the spoiler servo,which will go into the flap servo well.If l located the spoiler servo next to the existing flap servo,the spoilers would not fit into the top skin,as there is an outer tip panel join(the wing comes in two pieces).Rather than reposition the flap servo even more inboard,the flaps could be retained,but l think spoilers will be good enough alone.I have a set of foam core wings also,that have flaps only,the spoilers will go into the built up set of wings instead.If you are interested to go sloping on a weekend sometime,send a PM,cheers,regards damo
Old Mar 21, 2011, 06:44 AM
Joined Apr 2010
Spoiler installation Completed.
After rethinking through the entire installation once again,l have RETAINED the flaps and cut a servo well next to the spoiler servo,for the flap servo.The flaps only go down 15mm max-on sliders-channel 6-only will be required for launching or for slowing it down a little bit in flight.The spoilers were a fiddly job to install-as expected,both are working well,and fully extend to 30mm out from the top skin.Spoilers are on the throttle stick-channel 3
Discussion Graupner 370mm spoilers Damian Couzoff Scale Sailplanes 13 Oct 10, 2012 08:34 AM
Video DG-808S from Fly-Fly Thomas Nelson Sailplane Talk 4 Aug 27, 2011 07:30 AM
Found Graupner 370mm Airbrakes / spoilers sruelle Aircraft - Sailplanes (FS/W) 3 Jan 01, 2011 09:29 PM
