Old Aug 30, 2011, 11:50 PM
drypipe is offline
Find More Posts by drypipe
Joined Aug 2009
Originally Posted by inspector5419 View Post
I got my Dynam Spitfire in on Monday, and that was my worry too, the motor
and it did not come with bell motor so hopefully Mustang will have the same motor, after market props & spinners should be ok
Servos seem to be ok I have talk to a few who are flying the T-28 with no problems and with the stock ESC. I have the dynam ESC on some smaller 800 airfields and have no problems but I am upsizing my 30-amp to a 50-amp with a castle 10a BEC to power all of my servos adding flaps.
I guess it is somewhat of a decent outrunner motor then? Does the motor have the name "Dynam" on it like their ESCs?? The Dynam ESCs look be to dependable but that is just from the photographs?
keep us posted on the performance of the stock motor and servos?
drypipe is offline Find More Posts by drypipe
Old Aug 31, 2011, 12:25 AM
inspector5419 is offline
Find More Posts by inspector5419
inspector5419's Avatar
USA, TX, Van Alstyne
Joined Nov 2010
Looked on the motor and saw no markings on it but I can tell you it is not the motor NP has listed in there spare parts for the Mustang or the Spitfire.
And other guy on the Spitfire thread got his maiden in and said that it was a great flyer but no barn burner
some guys are having some small QC issues minor dings and such
it will be a while befor I get mine up just started on the flaps and then the paint job.
inspector5419 is offline Find More Posts by inspector5419
Old Aug 31, 2011, 01:22 AM
drypipe is offline
Joined Aug 2009
OK. The Dynam spare parts must me upgrades on NP?
Correction they are not upgrades. The spare motor parts listed on NP for the Dynam Mustang and Spitfire are the cheap, junk stick mount bell type outrunner motors.
Old Aug 31, 2011, 03:01 PM
malden86 is offline
Find More Posts by malden86
malden86's Avatar
San Antonio, TX.
Joined Feb 2009
Has anyone had any sucess drilling holes in the stainless steel motor mount? I want to swap the stock motor with a Power 15 and the mounting holes don't line up so I needed to drill some holes but I'm having a hell of a time drilling through the stainless steel. Anybody have any suggestions?
malden86 is offline Find More Posts by malden86
Old Aug 31, 2011, 05:49 PM
Vic Arcudi is online now
Find More Posts by Vic Arcudi
B-17 freak
Vic Arcudi's Avatar
NE Italy near Aviano AB
Joined Jan 2004
Have you tried drilling thru the firewall?
Vic Arcudi is online now Find More Posts by Vic Arcudi
Old Aug 31, 2011, 08:21 PM
drypipe is offline
Joined Aug 2009
You have to use either Cobalt Steel Drill Bits, or better, get Titanium (HHS), high speed steel drill bits. you can get then at Grainger Industrial Supply Co., or any store that sells industrial hardware.
Old Aug 31, 2011, 09:19 PM
malden86 is offline
malden86's Avatar
San Antonio, TX.
Joined Feb 2009
Thanks for the replies guys.
Vic, I removed the motor mount to measure the replacment motor amd it's a perfect fit if it is bolted on directly to the motor mount. The existing holes on the motor mount do not align with the new motor.
drypipe, I did a search and most people recommend the cobalt and the Titanium. It is also recommended to use slow speed and high pressure. I don't have a Grainger close to where I live but I can check a few hardware stores in the area.
Thanks for the help guys, I'll get this done somehow.
Old Aug 31, 2011, 09:46 PM
drypipe is offline
Joined Aug 2009
Any machining tool steel is classified as HHS or high speed steel. That does not mean you must run the bit on high speed, but means that it can take the high temp due to friction when drilling stainless.
Also good idea to use a little cutting machine oil as you drill, to take away the heat from the friction which will make drilling faster and make your bits last longer.
Old Sep 01, 2011, 05:38 PM
fuzzyhead is offline
Find More Posts by fuzzyhead
Old F-4 Crewchief
fuzzyhead's Avatar
Schertz, Texas, United States
Joined May 2004
Well it was waiting for me when I got home. Less than 4 days from Athens GA to San Antonio. First impressions are good. Not a top of the line plane so don't expect perfection. All parts are accounted for. No eagle decal though. Its shown in the parts list but the manual is for an RTF. Mine is PNP.
-No damage other then a few small foam indentions(from factory). Small painting overspray and scuffs. Overall looks good.
-Canopy magnet is small and weak. Will be replaced befor flight. Snug fit though.
-Elevator was stiff due to excessive glue on connector wire. Easily fixed.
-Wiring can quickly confuse you. A y-cord was attached to the elevator and rudder
servos. Attached to that was a tricord. My guess is that someone just connected
them at random to secure them in the cockpit. Puzzled about the tri-cord. What does
the third lead go to? The y-cord will take care of the ailerons. Two of the three leads
from the tri-cord will attach to the retracts. Feel free to guide me here.
-Other than connecting the ailerons, theres no wiring instructions in the manual.
-The motor is attached to a metal mount. The mount is held in by 4 screws. Not sure
what it attaches to. To answer a question from previous, looks like you have to remove
the motor to replace the esc. Can't see a way to get to the bullets. As I plan on doing
such I'll tell you whats behind the metal mount when I get to that point.
Will pass on more hopefully useful info that I come across.
fuzzyhead is offline Find More Posts by fuzzyhead
Old Sep 01, 2011, 06:19 PM
drypipe is offline
Joined Aug 2009
Well, from looking at the pics, I guess you get for what you pay for. That is, a slice of moldy cheese.
Old Sep 01, 2011, 06:39 PM
JimNM is offline
Find More Posts by JimNM
WAA-08 THANK FRANK!
JimNM's Avatar
Las Cruces, New Mexico, United States
Joined Jun 2002
Hey Fuzzy - I friend of mine has this plane. The hatch magnet needs to be repositioned to mate up with the canopy better. We had to add 4 oz of weight to the nose to achieve proper C/G, which makes taxi/take off and landing kinda touchy. We are exploring bending the LG legs forward to make ground handling better. The plane flies nice and very slow. On his first flight, the canopy popped off and the battery jumped out and hung back over the TE of the wing. He managed to pancake the plane with only a slight bend in the right gear leg. Do make sure the canopy has a good and tight fit and that your battery has some sort of extra retainer
JimNM is offline Find More Posts by JimNM
Old Sep 01, 2011, 07:43 PM
Old F-4 Crewchief
fuzzyhead's Avatar
Joined May 2004
A few more pictures to answer other questions. The motor mount is a simple metal bracket type. It attaches to a metal plate that is installed in a slot as the two fuselage halves are glued together. Mount does have right and down thrust bent into it. Seems to be very sturdy.
Old Sep 01, 2011, 07:57 PM
JimNM is offline
WAA-08 THANK FRANK!
JimNM's Avatar
Joined Jun 2002
Fuzzy, what are dims on the motor mounting holes? From the photos I guess 25mm center to center?
Old Sep 01, 2011, 08:26 PM
Old F-4 Crewchief
fuzzyhead's Avatar
Joined May 2004
From top to bottom 18mm. From left to right 37mm. Those are for the mount to fuselage. For mount to motor its 18mm.
Old Sep 01, 2011, 09:19 PM
drypipe is offline
Joined Aug 2009
Just like the FMS designs.
For Sale GWS P-51 - New in box martimer Aircraft - Electric - Airplanes (FS/W) 1 Oct 24, 2010 09:45 PM
For Sale Laser Arts P-51 Mustang Kit - New in box martimer Aircraft - Electric - Airplanes (FS/W) 3 Oct 24, 2010 09:42 PM
Sold So Iím selling my NEW IN BOX P-51 (green) from HobbyKing.com lowwing Aircraft - Electric - Airplanes (FS/W) 9 Oct 15, 2010 06:28 PM
Yippee! Another HK new one.......P-51!!!!!! Xanadu Foamies (Kits) 4 Oct 02, 2010 06:10 PM
Discussion New Engine for UM P-51 - HH may be using Sukhoi Spi1993 Scratchbuilt Indoor and Micro Models 10 Sep 14, 2010 07:38 PM
