Old May 27, 2011, 09:35 PM
drypipe is offline
Find More Posts by drypipe
Joined Aug 2009
Originally Posted by drypipe View Post
The forward rake on the LG is a very important factor, which is most particular for that scale size model and being a "Mustang" which always comes in fast during landings, even with the flaps are deployed.
Also, on paved surfaces, a forward rake in the LG is a good Factor of Safety!
The model must ALSO be tested on a GRASS FIELD because not everyone belongs to a club that has a paved airfield or acess to a clear paved surface!
ALSO ::
We need photos of the inside of the cowl. Is there a good quality Box Motor Mount or cheap balsa stick mount? Is there a Bell Type Motor Or good quality outrunner? Also, we need photos of the inside of the servo tray and battery compartment.
P.S. In addition to MORE FORWARD RAKE on the retract landing gear plates, It appears, from the video, that the hatch needs stronger, and or more, magnets to hold down the hatch. Rare Earth Magnets around the hatch that are attracted to small metal plates around hatch frame fuselage, would be the best choice for a $169.00 model.
drypipe is offline Find More Posts by drypipe
Old Jun 12, 2011, 09:16 AM
turbinefancy is offline
Find More Posts by turbinefancy
wish for Tomcat....granted!
turbinefancy's Avatar
United States, CA, Irvine
Joined Jun 2009
Just saw the review video. It's a decent looking standoff Mustang. But that landing gear rake must change. Antonio greased the last landing on smooth pavement and the plane still nosed over.
Can't beat the price though. $109 for an arf with etracts. Maybe a couple of washers on the rear of the etract mount will do?
turbinefancy is offline Find More Posts by turbinefancy
Old Jun 12, 2011, 01:08 PM
BRUTUS2238 is offline
Find More Posts by BRUTUS2238
Huge member!
BRUTUS2238's Avatar
Pawtucket R.I.
Joined May 2008
Thats what Ill probably do. I ordered it yesterday so I dont expect to see it untill next Mon. If the retract mounts look strong enough Ill try a couple of washers,if not probably pulling the mounts and adding a hardwood wedge for the mount to sit on should do it. Untill it actually arrives its all spec. Brutus
BRUTUS2238 is offline Find More Posts by BRUTUS2238
Old Jun 13, 2011, 12:39 PM
PacificPilot is offline
Find More Posts by PacificPilot
User Registered
PacificPilot's Avatar
United States, MD, Germantown
Joined May 2011
I'm debating whether I should get this or the FMS 1400M version... need too look for a 4 bladed prop and spinner... you guys think there's enough room to make the tail wheel retractable???
PacificPilot is offline Find More Posts by PacificPilot
Old Jun 21, 2011, 07:15 PM
Huge member!
BRUTUS2238's Avatar
Pawtucket R.I.
Joined May 2008
Mine came in yesterday,I just got thru checking it out. It looks real nice. The retracts need to be raked forward a bit ,otherwise its quite nice.If you thought "Goofy" was a BOGUS pilot,wait till you see "RED"! Brutus
Old Jul 19, 2011, 04:46 PM
Vic Arcudi is online now
Find More Posts by Vic Arcudi
B-17 freak
Vic Arcudi's Avatar
NE Italy near Aviano AB
Joined Jan 2004
I just got mine, it comes with a 3 bladed prop & spinner, which are NOT scale, so I ordered a 4 blade prop & spinner for the HK version which has the same span (hopefully the spinner & prop will fit). I pried the canopy off & got rid of the guy that seems to have been added as an afterthought. Thankfully I had a latex 1/10 scale US WWII pilot which I cut to size & glued in after adding headrest & armor plate cut from depron. The whole office was then painted in Tamiya flat black & the canopy glued back on.
Next I brush painted the yellow plastic exhausts in Humbrol gun metal & buffed it to a nice sheen. Looking much better now. What remains to be done is reglueing all the horns & servos which were all loose and came off in my hands!
What I need to know before applying decals is whether the 'feeble eagle' ever carried invasion stripes. All the pics I've seen of this aircraft DON'T have them! Any help here would be greatly appreciated.
Vic
Vic Arcudi is online now Find More Posts by Vic Arcudi
Old Jul 19, 2011, 08:03 PM
Alrus1 is offline
Find More Posts by Alrus1
352nd FGA
Alrus1's Avatar
United States, PA, Philadelphia
Joined Dec 2006
Vic
that is the "Dynam" for you!Some assembly required!
About scale painting i did place some pics of real plane,here it go again http://www.rcgroups.com/forums/showp...5&postcount=20
Alrus1 is offline Find More Posts by Alrus1
Old Jul 20, 2011, 10:50 AM
B-17 freak
Vic Arcudi's Avatar
Joined Jan 2004
Well, it's finished! Job's made simpler by the fact that the full scale 'feeble eagle' had no invasion stripes, so there's a few less stickers to apply! On the downside, the fuselage has the invasion stripes painted on, so I took a little poetic license and left them, lots of P-51s left them on. As a finishing touch the front cockpit coaming was painted to a colour matching the kits'. I used 2 parts SEA forest green & 1 part SEA dark green.
Furthermore the chin scoop was opened up with a dremel tool to admit some airflow over the motor & esc, only problem is, there's nowhere for the air to exit!
Another issue is the landing gear with insufficient forward rake. Having balanced the model as per instructions the cg ends up smack in the middle of the wheel wells, seems strange to me. Anyway here's some pics...
Old Jul 20, 2011, 11:57 AM
drypipe is offline
Joined Aug 2009
Now Dynam needs to produce a FW-190a, in the same scale, to combat all those manufacturer P-51s, including now their own P-51 redundancy!
Old Jul 20, 2011, 01:09 PM
gnats82 is offline
Find More Posts by gnats82
Coy, peruser of worlds
gnats82's Avatar
Augusta, KS USA
Joined Dec 2007
Vic - post #68
Thanks Vic, that's a surprisingly good looking P-51.
FWIW - There was discussion on the large FMS P-51 thread about the rake of the P-51 landing gear as it was too vertical also. Information came up that placed the correct scale P-51 strut geometry as a having a 15 degree rake forward from vertical, that is with the fuselage propped up at the tail and the center reference line level to a flat surface.
gnats82 is offline Find More Posts by gnats82
Old Aug 28, 2011, 04:18 PM
fuzzyhead is online now
Find More Posts by fuzzyhead
Old F-4 Crewchief
fuzzyhead's Avatar
Schertz, Texas, United States
Joined May 2004
After much thought I ordered the P-51 today. Initially I was after the FMS 55" P-47. Had major concerns that my flying area, which is down the block, was too small. The nearest place I felt comfortable flying the P-47 was 5 miles away. No guarantee that it was always available. So for the sake of conveinence, I opted for the slightly smaller and much lighter Mustang. Was not thrilled with the comments regarding Dynams customer service so I paid a bit more and ordered from Grayson Hobby. Great service from previous orders. They guarantee UPS delivery in 3-4 business days. Will report back on that.
Other than adjusting the rake of the landing gear I didn't notice any mods mentioned. A lot of cosmetic scale issues were brought up. I plan on putting some of the invasion stripes on the bottom. Its a visual orientation thing for me. A silver plane against a pale hazy sky can lead to disaster. My eyes ain't as young as they used to be. All my planes have them. Looking forward to sharing my success.
fuzzyhead is online now Find More Posts by fuzzyhead
Old Aug 30, 2011, 06:16 PM
drypipe is offline
Joined Aug 2009
Does it have one of those cheesy "bell type" outrunner motors? Also how's the esc and servos?
Old Aug 30, 2011, 07:49 PM
Old F-4 Crewchief
fuzzyhead's Avatar
Joined May 2004
Haven't received it yet. The promised shipping time appears to be accurate. UPS tracking shows a Thursday delivery. I plan on swapping out the esc with a Turnigy 40A. Partially for the quality issue and that would be easier than soldering a Deans connector on.
Old Aug 30, 2011, 10:12 PM
drypipe is offline
Joined Aug 2009
Please let me know if it has an outrunner bell type motor when you receive it ok ?
Old Aug 30, 2011, 10:37 PM
inspector5419 is offline
Find More Posts by inspector5419
inspector5419's Avatar
USA, TX, Van Alstyne
Joined Nov 2010
I got my Dynam Spitfire in on Monday, and that was my worry too, the motor
and it did not come with bell motor so hopefully Mustang will have the same motor, after market props & spinners should be ok
Servos seem to be ok I have talk to a few who are flying the T-28 with no problems and with the stock ESC. I have the dynam ESC on some smaller 800 airfields and have no problems but I am upsizing my 30-amp to a 50-amp with a castle 10a BEC to power all of my servos adding flaps.
inspector5419 is offline Find More Posts by inspector5419
For Sale GWS P-51 - New in box martimer Aircraft - Electric - Airplanes (FS/W) 1 Oct 24, 2010 08:45 PM
For Sale Laser Arts P-51 Mustang Kit - New in box martimer Aircraft - Electric - Airplanes (FS/W) 3 Oct 24, 2010 08:42 PM
Sold So Iím selling my NEW IN BOX P-51 (green) from HobbyKing.com lowwing Aircraft - Electric - Airplanes (FS/W) 9 Oct 15, 2010 05:28 PM
Yippee! Another HK new one.......P-51!!!!!! Xanadu Foamies (Kits) 4 Oct 02, 2010 05:10 PM
Discussion New Engine for UM P-51 - HH may be using Sukhoi Spi1993 Scratchbuilt Indoor and Micro Models 10 Sep 14, 2010 06:38 PM
