Old Jun 23, 2012, 03:32 PM
frankmoser72 is offline
Find More Posts by frankmoser72
frankmoser72's Avatar
United States, GA, Albany
Joined Jun 2012
I only had this issue one day in one area i'm not sure if it was interference or what but it definately geeked out on me twice with two different batteries but has not happened since of course i was near the airport maybe signal interference i don't fly there anymore on a different note i hear a lot of you guys talkin about gettin bigger motors for more power did any of you think about gettin a smaller one with more kv say 1200-1400 with say a 60-70 amp esc runnin on 14.8 4s 2200-2600 mah with a 9-10 inch prop should be about twice as quick as a 650-800 kv with an 11-12 inch prop but i don't know still untested theory but as i get more money i WILL be tryin different set-ups and now that i found a hobby shop within an hour of my house no more 20 dollar shipping no more 6-7 day waiting periods no more damaged products the sky is mine and the birds better watch out now at least the ones in southern geogia lol yep hodges hobbies above americus ga if you look up mac hodges on you tube he specialized in giant multi engines i think his b-17 has like a 32 foot wingspan anyhow you can check him out on youtube
frankmoser72 is offline Find More Posts by frankmoser72
Old Jun 23, 2012, 07:38 PM
fastflyer12345 is offline
Find More Posts by fastflyer12345
Joined Jan 2012
what size prop should i use for changing this to 2 bladed
fastflyer12345 is offline Find More Posts by fastflyer12345
Old Jun 23, 2012, 08:32 PM
Sammy70 is offline
Find More Posts by Sammy70
PSALM 14:1
Sammy70's Avatar
Central Ohio
Joined Feb 2008
I like 12x6 with 4s lipos and the stock motor...
Sammy70 is offline Find More Posts by Sammy70
Old Jun 23, 2012, 09:26 PM
P-51 flyby is offline
Find More Posts by P-51 flyby
P-51 flyby's Avatar
United States, NC, Rocky Mt
Joined Oct 2003
I have tried a lot of different prop and batteries. If you want true P-51 Scale flying use a parkzone extra 300 10.5x9 with dubro spinner on 3s. If you want unscale fast can climb very quickly and unscale go with 11x7....or 12x6 on 4s. To me the most scale is the 100.5x9 with 4s....it would be like a scale P-51 with WEP turned on.
P-51 flyby is offline Find More Posts by P-51 flyby
Old Jun 23, 2012, 09:44 PM
Sammy70 is offline
PSALM 14:1
Sammy70's Avatar
Central Ohio
Joined Feb 2008
12x6 2blade on 4s can fly scale just fine if you don't stay WOT the whole time
Old Jun 23, 2012, 10:12 PM
P-51 flyby's Avatar
Joined Oct 2003
Hence why I said its like having WEP on.
Old Jun 24, 2012, 02:21 AM
Joined Jun 2012
hey sammy was wonderin your top speed with that set-up or a roundabout estimate
Old Jun 24, 2012, 08:15 AM
Muskoka1 is offline
Find More Posts by Muskoka1
Canada, ON, Muskoka
Joined Jul 2011
Hi Frank, don't know what Sammy gets, but I run the same setup and had one of our local Provincial Police radar it for me, 107kph (66mph), straight line, no wind.
Glen
Muskoka1 is offline Find More Posts by Muskoka1
Old Jun 24, 2012, 02:06 PM
Joined Jan 2012
Thanks for the help guys
Old Jun 24, 2012, 05:50 PM
Sammy70 is offline
PSALM 14:1
Sammy70's Avatar
Central Ohio
Joined Feb 2008
Glen
I was going to guess 60-70mph so it's nice to see a radar verified pass...
Old Jun 24, 2012, 08:59 PM
Joined Jun 2012
[QUOTE=Muskoka1;21981426]Hi Frank, don't know what Sammy gets, but I run the same setup and had one of our local Provincial Police radar it for me, 107kph (66mph), straight line, no wind
Thanks man
Old Jun 24, 2012, 10:05 PM
luigirox is offline
Find More Posts by luigirox
Joined May 2011
Ay one have issues tighting the stock prop on with the collet? I can tseems to tighen it withou the somthing spinning the motor spins of the backing on the spinnner spins
Please advise-
luigirox is offline Find More Posts by luigirox
Old Jun 25, 2012, 05:39 AM
Joined Jun 2012
Ok man luigirox what I used was a long piece of clear-tape I just folded it n slid it n between the back-plate on the spinner n the body n wrapped it around a couple of times then got a good hold on it.when I started tightenin it down it seemed to grab hold.After swappin out the prop a few times don't have that problem anymore it just tightens right up now oh yeah by the way the stock spinners are junk I have heard changin the chinese screws with usa screws will fix the wobble.I don't know about that but changing to a 2 blade certainly will!I have found the 12x6 two blade to be the best suited to the stock setup although I didn't try 11x7 two blade.But as far as I know EVERY SINGLE ONE HAS UNBALANCED SPINNER but a small annoyance cheap n easy to fix.
Old Jun 25, 2012, 06:05 AM
Joined Jun 2012
Ok ok I think I got it the recipe for lightenin up your wallet lol!1st we need 1 Turnigy G10 1200kv brushless outrunner 2nd we need 1 Turnigy plush 60 amp esc 3rd we need 1 set of 11x7 and 1 set of 10x5 e props and 1 2400-2600 mah 14.8 4s no need for two plane probably won't survive maiden flight lol but at some point I gotta try it!Suppose to pull 2140 g of thrust at 53a using 11.1 and 11x5.5 prop it pulls 1800g of thrust at 41a using 11.1 10x5 motor weighs 140g esc 60g weight should be about perfect the whole setup is less than 80 bucks. Seems like overkill THAT'S JUST MY POINT!!!!! for me rc flyin is for FUN so why not be silly sometimes lol I think I may have a brain affliction that causes me to obsess over things like this well at least that's what my girlfriend says lol from what I can tell you really don't even need 4s for these numbers apparently they used 11.1 in testing! So we might need a 8 or 9 inch prop not sure . I know reinforcements will be a must for the airframe. In case anyone is wondering I saw a really fast phase 3 a while back .I think it was a spitfire but it was so fast I couldn't even tell you.! Only thing I know for sure it was a prop plane of warbird appearance that flew 100+ mph .A dream was born lol
Old Jun 25, 2012, 09:12 PM
luigirox is offline
Joined May 2011
One more thing I noticed that the retracts hang lower than the wing when up is this normal seems like it would cause drag. How would you adjust this?
For Sale GWS P-51 - New in box martimer Aircraft - Electric - Airplanes (FS/W) 1 Oct 24, 2010 08:45 PM
For Sale Laser Arts P-51 Mustang Kit - New in box martimer Aircraft - Electric - Airplanes (FS/W) 3 Oct 24, 2010 08:42 PM
Sold So Iím selling my NEW IN BOX P-51 (green) from HobbyKing.com lowwing Aircraft - Electric - Airplanes (FS/W) 9 Oct 15, 2010 05:28 PM
Yippee! Another HK new one.......P-51!!!!!! Xanadu Foamies (Kits) 4 Oct 02, 2010 05:10 PM
Discussion New Engine for UM P-51 - HH may be using Sukhoi Spi1993 Scratchbuilt Indoor and Micro Models 10 Sep 14, 2010 06:38 PM
