Old May 10, 2012, 02:04 AM
K9000wner is offline
Find More Posts by K9000wner
Thatsright I drankthe rum
K9000wner's Avatar
USA, MN, Robbinsdale
Joined May 2006
most leds run on 3 v and I read someone running them as two in series and connected to rx for supply that would make about 3v sound right too ..or adding a resistor in line with one.
K9000wner is offline Find More Posts by K9000wner
Old May 10, 2012, 12:21 PM
BCSaltchucker is online now
Find More Posts by BCSaltchucker
fly by night
BCSaltchucker's Avatar
Joined Sep 2011
Hey thanks for the heads up, guess I won't bother with them.
BCSaltchucker is online now Find More Posts by BCSaltchucker
Old May 10, 2012, 06:28 PM
Eric209 is offline
Find More Posts by Eric209
Joined May 2012
can somone post a pic of the battery location. Im just not understanding how it's secured
Eric209 is offline Find More Posts by Eric209
Old May 11, 2012, 12:14 AM
fly by night
Joined Sep 2011
I put my battery right up into the nose. My 2200 4S fit inside it snugly.
But ... I killed my ESC!!!
I programmed my throttle to limit it to 75%. Started the takeoff roll and ... Bleah ...brown smoke. Killed the ESC within 1 second. Don't believe everything you read, this ESC can only handle a 3S. I will upgrade my ESC/motor and prop before trying to fly this thing.
Old May 11, 2012, 08:21 AM
Jboy90277 is offline
Find More Posts by Jboy90277
United States, CA, Palos Verdes Peninsula
Joined Dec 2011
What size prop are you using? I've been running on 4S with the stock prop and ESC for a while now without any problems ( did put some holes in the fuse for ventilation). I just switched to a 2 blade 12x6e prop and will be trying it out this weekend - hopefully the ESC holds up.
Jboy90277 is offline Find More Posts by Jboy90277
Old May 11, 2012, 10:21 AM
fly by night
Joined Sep 2011
I had the stock 3 blade 'Dynam' brand
Old May 11, 2012, 10:42 AM
Joined Dec 2011
Must be a defective ESC. if it's a new plane, I'd ask for a replacement.
Old May 12, 2012, 01:16 AM
hate2crash is offline
Find More Posts by hate2crash
Joined May 2010
Originally Posted by Spyro37 View Post
Stock motor mount and stock motor. They are pre-installed. I did some good amount of bench test, there should be good amount of power on 4S. Performance should be great!
Plane is tail heavy if stock 3S 2200mAh (as per Dynam.) is used.
BUT perfectly balanced with the 4S 3000-3300mAh li-po.
I just ordered this dynam p51 plane and am not looking for a lot of speed just decent speed and good handling... i have several 4000mah 3s 25c gens ace packs...i am thinking they probabely are about same weight and size as the 4s 3000 packs you say work good...do u think they will fit and work good for scale flying..i think flight times should be around 12 mins or so..thanks
hate2crash is offline Find More Posts by hate2crash
Old May 12, 2012, 10:27 AM
sihinch is offline
Find More Posts by sihinch
Canada, ON, Toronto
Joined Jun 2007
You will have to carve some foam to get the 3000mAh packs to fit, both 3S and 4S.
sihinch is offline Find More Posts by sihinch
Old May 12, 2012, 11:57 AM
mash76 is offline
Find More Posts by mash76
Yep! I'm addicted.....
mash76's Avatar
United States, AZ, Mesa
Joined Mar 2012
i smoked my esc on the first take off, got about 30ft into the air, it went up in smoke. that was with the stock prop, 4s 3000mah battery. If anyone wants to fly a 4S which I suggest you need to upgrade the ESC. I put a E Flight 60amp and havent had any issues, flys great with that battery plenty of air time and performance. I also switched to a 2blade prop as well.
mash76 is offline Find More Posts by mash76
Old May 12, 2012, 08:52 PM
Sammy70 is offline
Find More Posts by Sammy70
PSALM 14:1
Sammy70's Avatar
Central Ohio
Joined Feb 2008
What 2blader are you using?
I like the MAS 12x6 2 blade on these Dynam P-51/T-28 stock motors on 4s.
Sammy70 is offline Find More Posts by Sammy70
Old May 12, 2012, 10:11 PM
mash76 is offline
mash76's Avatar
Joined Mar 2012
I have been using a APC 12x6
Old May 15, 2012, 12:03 AM
canopee is offline
Find More Posts by canopee
Joined Dec 2009
hk p51 four blade prop
Originally Posted by Muskoka1 View Post
Hi Fuzzy, missed your post. I also had nose overs on takeoff and just sanded the prop ends. Stripped her down for paint and decals from Callie Graphics "Glamorous Glen III" so no new flight info. Installed the flaps the other day and put a mix in the DX6i for 2 flap settings, 50% with the flap switch and then down to 100% with the mix switch. Bought a Turnigy speed regulator to adjust the rate the flaps deploy, looks cool, and at about half speed it will help with getting used to them. Might slow them down more. Only slow in one direction though. They retract at full speed, just in case I need to get rid of them quick.
How much weight have you put in the nose? I've removed a third of what I had, now at just under 40g. Will see how that goes. I found it was taking too much room to get it down to land, although I now have flaps installed. May need to add weight back. Been too windy, will report back with results when I get her up again.
Also waiting for 2 and 4 blade props from HK, plus the spinner that go with the 1200mm p51 they sell.
Glen
What part number at Hobby king for 4-blade prop and spinner for their 1200 mm p-51?
canopee is offline Find More Posts by canopee
Old May 15, 2012, 08:16 AM
Muskoka1 is offline
Find More Posts by Muskoka1
Canada, ON, Muskoka
Joined Jul 2011
See below for the part numbers. When I click on the items I ordered the links no longer exist. It appears they don't sell the stuff anymore. It was "junk". The best set-up I've used after much trial and error is upgrading the esc to 40 amp, use either a 12 x 6 or 7 APC 2 blade prop with a Dubro spinner, and most of all a 4s battery. She moves along very nice with this set-up, radar clocked at 107 kph, heat is not an issue. With the stock 3 blade prop, and the 4 blades I tried from HK, with the 30 amp ESC and 3s battery she was far too underpowered.
I'm using Zippy 2200mah 40c batteries that I got on sale from HK for $15 and they work great, flight times around 6 minutes. Didn't have to modify the battery tray at all, just shove them in and go.
Also, if you use the Dubro plastic 2 blade spinner with the wider blade APC props you have to Dremel out a bit of the bottom edges of the blade openings on the spinner or the prop will bind when you go to tighten it down. In other words the blades of the prop are wider than the openings in the spinner, and it will be unbalanced and vibrate like crazy. You only need to remove a little bit, just enough to get the prop to sit flat without twisting the blades. You'll see what I mean when you have the prop tightened down and you go to put the spinner on, it ever so slightly binds on the prop blades, and when you tighten it down, the blades will twist and cause awful vibration.
These are the part numbers for the prop and spinner.
4 blade prop : P-51PNP-4BLA http://www.hobbyking.com/hobbyking/s...dProduct=16308
4 blade spinner : P-51PNP-SPIN http://www.hobbyking.com/hobbyking/s...dProduct=16312
Glen
Muskoka1 is offline Find More Posts by Muskoka1
Old May 15, 2012, 05:27 PM
canopee is offline
Joined Dec 2009
fellow sin city dweller
Originally Posted by jk671 View Post
Here's the maiden flight! Had some weird noise coming from the motor in the beginning! Not sure what it was.... good flight... but i definitely could've landed her a lot better! I wish my second flight was more succesful!
https://www.youtube.com/watch?v=CDfs...e_gdata_player
I noticed you're not flying at the local club sites are you close to downtown'where I live?PM me,we could meet and talk RC,or not?
For Sale GWS P-51 - New in box martimer Aircraft - Electric - Airplanes (FS/W) 1 Oct 24, 2010 08:45 PM
For Sale Laser Arts P-51 Mustang Kit - New in box martimer Aircraft - Electric - Airplanes (FS/W) 3 Oct 24, 2010 08:42 PM
Sold So Iím selling my NEW IN BOX P-51 (green) from HobbyKing.com lowwing Aircraft - Electric - Airplanes (FS/W) 9 Oct 15, 2010 05:28 PM
Yippee! Another HK new one.......P-51!!!!!! Xanadu Foamies (Kits) 4 Oct 02, 2010 05:10 PM
Discussion New Engine for UM P-51 - HH may be using Sukhoi Spi1993 Scratchbuilt Indoor and Micro Models 10 Sep 14, 2010 06:38 PM
