Old Oct 01, 2011, 07:55 PM
fuzzyhead is online now
Find More Posts by fuzzyhead
Old F-4 Crewchief
fuzzyhead's Avatar
Schertz, Texas, United States
Joined May 2004
Are the Dynam servoless retracts normally slow to power up? Takes 7 or so seconds for them to energize after plugging the battery in. Work fine otherwise.
Question answered by Glen in a different thread.
fuzzyhead is online now Find More Posts by fuzzyhead
Old Oct 13, 2011, 01:39 PM
winginman is offline
Find More Posts by winginman
United States, KY, Louisville
Joined Aug 2010
Tried out my landing gear mods yesterday. Worked ok on grass, got in 5 flights. Last flight landing was a bit rough and the gear bent back some. Was easy to bend back in place when I got home. Mods work but gear wire is a bit weak. I will post some pictures of the mods later this evening.
Other issue was vibration. I had to scrap the original spinner due to vibration. Went to a a two blade prop and a SIG spinner. It was better but still had too much vibration at anything over 1/2 throttle. Finally found a DuBro 3" spinner and used a Master Airscrew 10x8 prop with a Great Planes prop adapter for the 4mm shaft. Wow, it is smooth as glass now at all speeds. Got a DuBro 3" for a three blade on the way and a MA 10x7 3 blade prop. I will also give the stock prop a try as well. Without the spinner the balanced stock prop is very smooth as well.
With the LG mods and the new prop/spinner this plane is sweet. And it looks so great on a low pass with the wheels up.
winginman is offline Find More Posts by winginman
Old Oct 14, 2011, 12:54 PM
Razors edge 29 is offline
Find More Posts by Razors edge 29
QuAd FaNaTiC
Razors edge 29's Avatar
Canada
Joined Aug 2009
Burn them; burn them all.
Razors edge 29 is offline Find More Posts by Razors edge 29
Old Oct 14, 2011, 04:13 PM
inspector5419 is offline
Find More Posts by inspector5419
inspector5419's Avatar
USA, TX, Van Alstyne
Joined Nov 2010
Whats that all about
inspector5419 is offline Find More Posts by inspector5419
Old Oct 17, 2011, 09:45 AM
Joined Aug 2010
Finally, had a little problem resizing the picture, had do download a new program. But here is what the LG looks like bent and tilted forward. Works in the grass now. (Short grass)
Old Oct 17, 2011, 01:52 PM
drypipe is offline
Find More Posts by drypipe
Joined Aug 2009
Possible simple solution then.
drypipe is offline Find More Posts by drypipe
Old Nov 05, 2011, 10:46 AM
malden86 is offline
Find More Posts by malden86
malden86's Avatar
San Antonio, TX.
Joined Feb 2009
After a couple of months of having this plane I finally got to maiden it this morning with the stock motor and ESC the Extra 300 prop and a 4 cell batt. I was pleasantly surprised with the performance and flight characteristics of this plane. After some trimming It flew like it was on rails and I never went above half throttle and it was plenty fast for me. Excellent roll rate for a plane of this size and landings were a breeze and uneventful, to me it is easier to land than my Parkzone P-47 and the landing gear held up real well. No nose overs except when I went off the pavement but I did put about a 1/4 shimmy on the retracts so I did not have to carve out any foam in the wheel well. On one of my flights I forgot to set the timer and I ran out of juice tried to deadstick it and did a cartwheel on the grass and absolutely no damage on the plane so it's pretty rugged too, all in all a great deal for the $99.00 I paid for it and I am really happy with it.
malden86 is offline Find More Posts by malden86
Old Nov 07, 2011, 12:21 AM
Sinai1 is offline
Find More Posts by Sinai1
s-s-s-S-O-L-I-D!!!!!
Sinai1's Avatar
Joined Apr 2007
Free Dynam P51
This plane looks solid...I got mine as a gift for free. it has fixed LG. So Ive ordered the replacement Dynam retracts here:
http://www.graysonhobby.com/catalog/...ct-p-1409.html
Thank you for the ideas here. I moved my Wheels forward a bit too. As for my 1st flight it was incredibly tail heavy and I added 42 g to the nose. Ive got the battery shoved all the way forward.
Good luck with your flights everybody; i'll try to get a vid up if i can
Sinai1 is offline Find More Posts by Sinai1
Old Nov 07, 2011, 08:43 AM
QuAd FaNaTiC
Canada
Joined Aug 2009
Anyone have issues with landing this plane?
A friend has one and it always touches down then flops forward yet CG is good. It's not his piloting skills and landing gear is freed up and working well.
Even on powered landings it has very odd tendencies.
Old Nov 07, 2011, 01:45 PM
drypipe is offline
Joined Aug 2009
How does the retracts handle grass?
Old Nov 07, 2011, 01:58 PM
malden86 is offline
malden86's Avatar
San Antonio, TX.
Joined Feb 2009
Did you friend move the landing gear forward? The stock retracts are too straight and most people have been moving them forward by either bending the strut or putting a shimmie on the rear part under the retract screws. You can look at winginman's photo above to get an idea on how to do it, I did not move mine as much as in the above pic but it does seem to help. You also need to keep full down elevator after landing and during the rollout. Hope this helps.
Old Nov 07, 2011, 02:57 PM
JimNM is offline
Find More Posts by JimNM
WAA-08 THANK FRANK!
JimNM's Avatar
Las Cruces, New Mexico, United States
Joined Jun 2002
Originally Posted by malden86 View Post
You also need to keep full down elevator after landing and during the rollout. .
NOT!
Down elevator will push the tail up and the nose into the ground, hold "up" elevator to keep the tail down and the nose up.
JimNM is offline Find More Posts by JimNM
Old Nov 07, 2011, 03:04 PM
QuAd FaNaTiC
Canada
Joined Aug 2009
Yes he moved gear forward quite a bit actually.
Also the airframe has not been crashed so that isn't a problem.
This plane from what I have seen is Disapointing it seems. Not very powerful and stock ESC start up functions are slow even when on fast start. It'd underPowered and has off handling characteristics.
Needs better electronics I think and the servoless retracts are garbage. Many people having issues with these retracts in this model and others as well.
Old Nov 07, 2011, 03:24 PM
malden86 is offline
malden86's Avatar
San Antonio, TX.
Joined Feb 2009
Originally Posted by JimNM View Post
NOT!
Sorry JimNM, my mistake and thanks for clearing that up.
Razor, I'm running mine with stock electronics but using a Parkzone Extra 300 prop and a 4 cell lipo and the plane really scoots around on half throttle but I'll be putting a 50amp ESC that I have laying around. I've read all the concerns on this model but mine flies great and landings are real easy and the retracts do seem kinda cheap but they seem to be holding up so far.
Old Nov 07, 2011, 03:38 PM
QuAd FaNaTiC
Canada
Joined Aug 2009
Okay
I'll tell him he should run 4S
For Sale GWS P-51 - New in box martimer Aircraft - Electric - Airplanes (FS/W) 1 Oct 24, 2010 08:45 PM
For Sale Laser Arts P-51 Mustang Kit - New in box martimer Aircraft - Electric - Airplanes (FS/W) 3 Oct 24, 2010 08:42 PM
Sold So Iím selling my NEW IN BOX P-51 (green) from HobbyKing.com lowwing Aircraft - Electric - Airplanes (FS/W) 9 Oct 15, 2010 05:28 PM
Yippee! Another HK new one.......P-51!!!!!! Xanadu Foamies (Kits) 4 Oct 02, 2010 05:10 PM
Discussion New Engine for UM P-51 - HH may be using Sukhoi Spi1993 Scratchbuilt Indoor and Micro Models 10 Sep 14, 2010 06:38 PM
