Old Feb 21, 2011, 11:55 AM
jeffscholl is offline
Find More Posts by jeffscholl
Joined Nov 2002
Panasonic GH2 on Hexakopter
Quick test with the GH2. Pretty excited over this little gem.
Panasonic GH2 1080P test flight on a Hexakopter (2 min 2 sec)
Cheers,
Jeff
jeffscholl is offline Find More Posts by jeffscholl
Old Feb 21, 2011, 12:08 PM
frogman1206 is online now
Find More Posts by frogman1206
Frogman
Stoughton, WI
Joined Jun 2009
http://vimeo.com/20181365
Cheers,
Jeff
Yea, the GH2 is a quite the camera in a small package. DSLR features and sensor in a point and click size. Could be a game changer for our little ventures. I'm a videographer and the DSLR movement is pretty crazy. These little GH2 cams are pretty popular and would do some damage to Canon's momentum if they had some decent fast glass available for it. You have very few options for good fast glass for low light environments. That is not an issue for what we do but for videographers it is huge. I'm still a Canon DSLR shooter for video but the GH2 has lots of potential...especially strapped to a plane/copter.
frogman1206 is online now Find More Posts by frogman1206
Old Feb 21, 2011, 12:18 PM
Joined Nov 2002
Just spent last week in the AZ desert shooting with multiple 5dmk2's and 7d's. Used a 14L, 24TS, 100 macro, and a 35L for most of the specialty camera content.
I've had my 5dmk2 since Dec 08. I think we are due for the mk3 with hopefully faster refresh rate and maybe a raw codec :-)
Old Feb 21, 2011, 12:58 PM
Tarro is offline
Find More Posts by Tarro
Long Island, New York
Joined Jun 2008
Cheers,
Jeff
Hi Jeff,
I love your work, thanks for posting.
Was that video shot at 60fps, if not how well does the 1080 60fps setting handle vibrations?
Tarro is offline Find More Posts by Tarro
Reply With Quote  (Disabled)
Old Feb 21, 2011, 01:42 PM
Joined Nov 2002
"Was that video shot at 60fps"
The GH2 doesn't have the 1080 60fps/overcrank that the AF100 does.
I do plan on testing out the 720 60P against the Canon DSLRS in regards to flicker/moire.
Best,
Jeff
Old Feb 21, 2011, 02:14 PM
Tarro is offline
Joined Jun 2008
Hi Jeff,
In the specs it says it does?
http://www.dpreview.com/previews/panasonicdmcgh2/
I use my Go Pro's on R3 which is 720p 60FPS.
Old Feb 21, 2011, 06:08 PM
Mactadpole is offline
Find More Posts by Mactadpole
San Marcos, TX
Joined Jan 2010
The specs on the Panasonic site for the GH2 (link):
AVCHD NTSC
[Full HD] 1,920 x 1,080, 24p (24H: 24Mbps, 24L: 17Mbps)
[Full HD] 1,920 x 1,080, 60i (sensor output is 60p) (FSH: 17 Mbps, FH: 13 Mbps)
[HD] 1,280 x 720, 60p (sensor output is 60p) (SH: 17 Mbps, H: 13 Mbps)
Why does it say "sensor output is 60p" after 60i?
Does that mean it records as interlaced and then converts to progressive?
I learned from Jeff that progressive is better than interlaced for post-processing stabilization.
@Jeff - so did you record it at the 24p or 60i setting?
Sorry for my ignorance on all this, trying to figure it out.
Thanks, Shawn
Mactadpole is offline Find More Posts by Mactadpole
Old Feb 21, 2011, 08:53 PM
cannondale1974 is offline
Find More Posts by cannondale1974
cannondale1974's Avatar
Lexington, KY
Joined Oct 2009
Left you a facebook comment, great work as always Jeff. So which is better, the GH2 or 550 T2i? I did a quick search on prices of the GH2 and some were like $1300, others $800? T2i's are around $800 I believe with the 18-55mm lens.
cannondale1974 is offline Find More Posts by cannondale1974
Old Feb 21, 2011, 09:43 PM
Joined Nov 2002
The T2i produces a moire/flicker with it's line skipping that I can't produce with the GH2.
I'm going to get the Lumix 14mm prime and compare to the T2i with the 20mm.
Also on the GH2 I haven't been able to push the ISO past 3200 for video - stills you can go up to 12800.
"@Jeff - so did you record it at the 24p or 60i setting?"
24P
1080 60i is exactly that for the file, but perhaps in the future they can give us a firmware upgrade to extract the 60P stream out of the HDMI out.
Old Feb 21, 2011, 09:56 PM
Tarro is offline
Joined Jun 2008
24P
Hi Jeff,
Thanks for sharing all your great work and knowlegde, I have great respect for what you do and learn alot from it.
Cheers
Gary
Old Feb 21, 2011, 10:30 PM
San Marcos, TX
Joined Jan 2010
Well said! I agree totally. Just learned a little more. Thanks, Shawn
Originally Posted by Tarro View Post
Hi Jeff,
Cheers
Gary
Old Feb 21, 2011, 11:38 PM
Lexington, KY
Joined Oct 2009
Hi Jeff,
Cheers
Gary
Couldn't have said it better myself. There are about 4-5 guys (that I've seen on all the forums) that have this aerial video stuff nailed down. Jeff is one of them.
Old Feb 21, 2011, 11:41 PM
Beauregard is offline
Find More Posts by Beauregard
My three sons...
Beauregard's Avatar
Steamboat Springs Co.
Joined Nov 2004
"I set the GH2 to 1080 24fps at 80% and then conformed it to 30fps for real time - 24Mbs :-) "
Above from facebook..
So when you say "real time" your referencing the 30fps? And this is how you were able to get 30fps at 24Mbs?
Wow.. If you got that from that hideous manual I'm stunned.. Nice tweak..
Beauregard is offline Find More Posts by Beauregard
Old Feb 21, 2011, 11:53 PM
Av8Chuck is offline
Find More Posts by Av8Chuck
Av8Chuck's Avatar
USA, CA, Thousand Oaks
Joined Feb 2010
A couple of things you may want to keep in mind.
Since the T3i is just now being released you can expect the price of the T2i to come down significantly, I think its already down to $650 or less (camera body).
However as Jeff mentioned the Canon's 7D and T2i [and probably the T3i] have moire issues. If you know under what conditions and which lenses cause it to happen you can work around it. Of coarse your adding one more layer of complexity to your Aerial Photography that will lower your probability of a successful shoot. But only you can decide whether its worth the difference in price. I do quite a bit of aerial photography from real helicopters, ultralights and airplanes with the 5dMkII and 7D the problem with moire hasn't ruined a shoot but you have to be mindful of it whereas with the GH2 [or better yet] the AF100 it doesn't seem to be an issue.
Also, the GH2 weights 382g (+ lens) and the T2i weights 530g(+ lens) and the AG-AF100, for anyone brave enough to fly a $5K camera is about 1.3Kg.
There are a lot of variables but for me if the price of the T2i goes low enough I'll hang it under a hexa or maybe even a quad. The GH2 is a very nice camera, but so is the T2i.
Av8Chuck is offline Find More Posts by Av8Chuck
Old Feb 22, 2011, 07:31 AM
My three sons...
Beauregard's Avatar
Joined Nov 2004
I just realized "real time" is the playback speed.. So how did it look at 80%.. Nice to have the option when shooting 1080p.
Discussion My carbon fibre frame Hexakopter filipinto Multirotor Talk 39 Jul 14, 2011 04:12 PM
Discussion Want to add Eagle Tree FPV to Hexakopter MK Ohio guy Eagle Tree Systems 4 Mar 01, 2011 06:08 PM
Wanted Okto/Hexakopter for DSLR- aerial photography/videography Jonkke Aircraft - General - Miscellaneous (FS/W) 0 Oct 26, 2010 02:41 PM
