Old Mar 21, 2011, 07:31 PM
stanordave is online now
Find More Posts by stanordave
stanordave's Avatar
Joined Jan 2006
quick vid of movement..need to use mixers to keep from hitting supports
http://www.youtube.com/embed/2plo3WJ_pZM
stanordave is online now Find More Posts by stanordave
Old Apr 18, 2011, 02:35 PM
schorhr is offline
Find More Posts by schorhr
schorhr's Avatar
Originally Posted by Joel K. Scholz View Post
Harry, I got my ball links from SIG Manufacturing. They are made by KAVAN. Dubro also makes several good ball links. I have already figured out how to simlify and lighten this design. I haven't measured deflections yet, but I am quessing around 60 degrees. Flatterman , in my case it is almost a question of overchoice. I probably have 120 different designs in my attic. I can't decide whether to choose show or go. Most likely show. Dragon, 3Dbird or Pteranadon. Vector thrusting one of my F-16 juts might be interesting.
Wow, my girlfriend is looking for the shrek dragon kite all over... any idea where it can still be bought?
schorhr is offline Find More Posts by schorhr
Old Apr 26, 2011, 01:05 PM
TheNiceGuy is offline
Find More Posts by TheNiceGuy
Expat
Japan
Joined Apr 2010
Do you think these have enough range?
http://www.hobbyking.com/hobbyking/s...idProduct=8233
I can't find suitable ball joints anywhere.
TheNiceGuy is offline Find More Posts by TheNiceGuy
Old May 06, 2011, 10:38 AM
flattermann is offline
Find More Posts by flattermann
check the crazyplanes ...
flattermann's Avatar
Germany
Joined Dec 2006
...have built a lightweight interchangeable 3D Vector Unit using 'Swashplate' - technology:
This Vector Unit weighs only 42 grs. and comes with an excellent performing Mighty Midget 'Gold-Line' - 7.5 grs. 12N/16P BL-Motor, controlled by a 0.9grs. weighing YGE 4 ESC.
http://www.microbrushless.com/productsG3.htm
The Swashplate is moved by 2 Modelcraft 5.5grs. Metal Gear servos.
The unit runs on a 3S - 200mA 20C AHA-Lipo (smaller kites) or 3S-460mA (larger kites) and generates around 200grs. of thrust, using a 5043 GWS prop.
It could be used in leightweight Vector Kites up to a total flightweight of 350 grs.
flattermann
flattermann is offline Find More Posts by flattermann
Old May 07, 2011, 04:01 PM
slebetman is offline
Find More Posts by slebetman
slebetman's Avatar
Malaysia, Selangor, Kajang
Joined Jun 2009
Oh wow, that is one sweet motor. 200g of thrust for an 8g motor is amazing efficiency. Got to get me one of those. Where did you buy yours?
slebetman is offline Find More Posts by slebetman
Old May 07, 2011, 04:28 PM
Germany
Joined Dec 2006
... in Germany, here:
http://www.wes-technik.de/English/mainpage.htm
Microbrushless.com has a dealer list:
http://www.microbrushless.com/dealers.htm
take Your choice
flattermann
Old Nov 21, 2011, 01:49 PM
Germany
Joined Dec 2006
New Bi-Rotor Vector Unit
Progress never stops!
I've developped a very special Birotor-Vector Unit, consisting of
1 Gimbal
2 Counterrotating BL-motors
2 9035 Props
2 MG Servos
2 ESCs
2 Receivers
Total weight is around 240grs., thrust should be around 900 grs.
Video of the today's demo/maiden:
www.crazyplanes.de/birotor1.wmv
*** SORRY for the bad camera adjustments :-)) ***
===> New video under
RC - VECTOR KITE 34 - 2 * birotor vector propulsion * NEW VIDEO * (2 min 53 sec)
taken on Oct. 7th, 2012, at Menden Kite Festival ( Germany )
Have fun!
flattermann
Old Nov 22, 2011, 09:32 AM
IFLYOS is online now
Find More Posts by IFLYOS
14s 180mah should be enough...
IFLYOS's Avatar
United States, NC, Pfafftown
Joined Feb 2001
Pretty darn cool!!!
1 Gimbal
2 9035 Props
2 MG Servos
2 ESCs
2 Receivers
Have fun!
flattermann
IFLYOS is online now Find More Posts by IFLYOS
Latest blog entry: Intro..a few years to late!
Old Nov 23, 2011, 09:51 AM
Expat
Japan
Joined Apr 2010
That's very nice FM. What is the advantage of coaxial? Just for anti-torque roll?
Old Nov 23, 2011, 11:02 AM
samwei1950 is offline
Find More Posts by samwei1950
DIY Mania from Taiwan
Taiwan
Joined Aug 2011
1 Gimbal
2 9035 Props
2 MG Servos
2 ESCs
2 Receivers
Have fun!
flattermann
A work of art.
is it possible for you to inform why two receivers
Regards
Sam
samwei1950 is offline Find More Posts by samwei1950
Old Nov 23, 2011, 12:51 PM
IFLYOS's Avatar
Joined Feb 2001
I am gonna guess that and a lessening of gyroscopic effects on the mount and servos...
Old Nov 25, 2011, 01:29 AM
Germany
Joined Dec 2006
Hi guys,
Why 2 receivers?
With the very first version of the bi-vector unit I tried 1 receiver and I used a V -cable to plug in the 2 ESCs. First tests showed then, that one of the both motors has stopped often under full throttle.
Tests with a 2nd lightweight receiver only for the ESC of the 2nd motor showed faultless function all over the full RPM - range.
Now, it is also possible to stop one motor when the vector kite is soaring, and only a little thrust (and energy) is used for flight direction controls.
"....I am gonna guess that and a lessening of gyroscopic effects on the mount and servos... "
Yes, that's another advantage, especially for use in rotating kites, where the LiPo-pendulum weight is influenced by the torque of a single-directional turning BL-motor.
flattermann
Old Nov 26, 2011, 05:38 PM
Pepsi is offline
Find More Posts by Pepsi
Joined Oct 2011
Flatterman do you have a Youtube version of the birrotor, i can't see
Pepsi is offline Find More Posts by Pepsi
Old Dec 05, 2011, 07:43 AM
Germany
Joined Dec 2006
... uploaded today:
RC - VECTOR KITE 34 * birotor vector controlled * 2 counter rotating props * (1 min 37 sec)
Have Fun!
flattermann
Old Dec 05, 2011, 10:27 AM
Tsavah is offline
Find More Posts by Tsavah
Watt Waster
Tsavah's Avatar
Joined Oct 2010
Interesting RC Kite
... uploaded today: Have Fun! flattermann
It was a little hard to see the RC kite, but the gimbal was interesting. I suppose the hat-cam was aimed a bit high. I am experimenting with the same hat-cam idea and it can be tricky to keep the subject centered. I am trying the recycled sunglasses idea. The mini DVR spy camera sets on a tiny shelf glued to one arm and one lens has a thin piece of short tubing glued on the lens to act as a sighting device. As long as the camera is aligned, and the subject is kept in the center of the short tube, all is good.
Tsavah is offline Find More Posts by Tsavah
Latest blog entry: Center of Gravity - Airplanes
Discussion Vector-thrust pusher with 3-axis gyo, anyone ever build? learn2turn Foamies (Scratchbuilt) 8 Sep 23, 2010 06:34 PM
Discussion JAS 39 360 VECTOR THRUST about to click Buy it Now. need advise airbagit13 Foamy EDFs 3 Sep 08, 2010 11:28 AM
Sold Sold Pending: Two NIB Turbo Vector kits Wattage/Hobby People w/o fan units 50% off jcstalls Aircraft - Electric - Airplanes (FS/W) 7 Oct 21, 2008 06:13 PM
Discussion Vector Vector **with maiden vid** sno Slope 82 Apr 21, 2008 09:50 AM
Wanted Vector Schuebeler VECTOR II PerfTech Aircraft - Electric - Airplanes (FS/W) 0 Jan 22, 2008 10:32 PM
