Old Mar 01, 2011, 03:43 PM
TheNiceGuy is offline
Find More Posts by TheNiceGuy
Expat
Japan
Joined Apr 2010
Nice pictures Mitchy. Those look bullet-proof, lol!
TheNiceGuy is offline Find More Posts by TheNiceGuy
Old Mar 03, 2011, 11:14 PM
Joel K. Scholz is offline
Find More Posts by Joel K. Scholz
Joel K. Scholz's Avatar
Kingsland, Texas USA
Joined Aug 2000
I decided to build a thrust vector unit today. I figure the cost of materials minus the electronics is less than $5. The unit weights 7.4 oz, minus the battery. The prop is 8". Total length = 8". Requires only a drill press, screw driver and pliars to build. I didn't get a chance to finish the mount, but plan on using a single Kingpin setup. This should allow it to be pretty universal.
Joel K. Scholz is offline Find More Posts by Joel K. Scholz
Old Mar 03, 2011, 11:48 PM
Harry D is offline
Find More Posts by Harry D
TLAR Aviation
Harry D's Avatar
Canada, AB, Edmonton
Very nice. Joel. I'm working on my own setup, similar to yours. Can I ask what ball links you used, and what angular deflections you can get? Thanks.
Harry D is offline Find More Posts by Harry D
Old Mar 04, 2011, 03:49 AM
flattermann is offline
Find More Posts by flattermann
check the crazyplanes ...
flattermann's Avatar
Germany
Joined Dec 2006
Joel: Thumbs up!
Think about interchangeability - 1 unit, different kites (You must have a lot, I think )
flattermann
flattermann is offline Find More Posts by flattermann
Old Mar 04, 2011, 09:11 AM
Joined Aug 2000
Harry, I got my ball links from SIG Manufacturing. They are made by KAVAN. Dubro also makes several good ball links. I have already figured out how to simlify and lighten this design. I haven't measured deflections yet, but I am quessing around 60 degrees. Flatterman , in my case it is almost a question of overchoice. I probably have 120 different designs in my attic. I can't decide whether to choose show or go. Most likely show. Dragon, 3Dbird or Pteranadon. Vector thrusting one of my F-16 juts might be interesting.
Old Mar 04, 2011, 12:39 PM
realglow is offline
Find More Posts by realglow
Eat, Sleep, Fly!
realglow's Avatar
Joined Mar 2001
Mechanical Mixer
I have used the elevon mixer mentioned above (comment #15) many times when the radio did not support mixing itself. It is easy to implement and works great.
Simply put, the aileron servo is mounted on a forward/aft slide which is driven by the elevator servo. This provides the elevon function.
James in eTX
realglow is offline Find More Posts by realglow
Old Mar 04, 2011, 01:45 PM
Joined Aug 2000
As I have never actually seen a vector powered kite, only video, I have no basis for judging suitable wingloading parameters. The commercial Premier designs are large kites, but the vector system looks like it is very heavy. What do do these systems weight? I am using a speed 400 outrunner , probably generating 20 t0 24 oz thrust. My vector unit is 7.4 oz plus around 4oz for a battery. What is a practical wingloading?
Old Mar 04, 2011, 01:56 PM
IFLYOS is offline
Find More Posts by IFLYOS
14s 180mah should be enough...
IFLYOS's Avatar
United States, NC, Pfafftown
Joined Feb 2001
Joel,
According to this site, the Premier kites weigh between 19.2 and 27.2 ounces. This and some data from the "regular" Premier website should give you an idea for wingloadings.
Tim
AG4RZ
IFLYOS is offline Find More Posts by IFLYOS
Latest blog entry: Intro..a few years to late!
Old Mar 04, 2011, 02:16 PM
Harry D is offline
TLAR Aviation
Harry D's Avatar
Thanks for the info on the ball links, Joel. I think those are a very critical item in building a good gimbal. Those Kavan ones from Sig look much better than the Dubro type I've been experimenting with. The Dubro have a pretty limited deflection range - only about 25 each way. That can be increased to around 30 each way by not butting the screw head or conical washer up against the ball (which is "flattened") on top and bottom. Something like Loctite would have to be used to fix the ball to the shaft.
The Kavan types seem to have full spherical balls so should give better deflection range. I'd be interested to hear what deflection your arrangement has, when you measure it. Also anything else you may discover during your experiments.
I tried a setup using PVC plastic for the ring etc, but it seemed to be much too flexible. I've just received some 2" diameter aluminum pipe I ordered, so will try making one from aluminum.
Like you, I've never actually seen a real vector kite. This is like starting RC all over again, isn't it? But you're a kite manufacturer? You're way ahead of most of us, then!
Old Mar 04, 2011, 03:50 PM
balsa or carbon is online now
Find More Posts by balsa or carbon
Hot glue held together by foam
balsa or carbon's Avatar
United States, OR, Portland
Joined Aug 2010
Ball links
Here's another choice in ball links I came across in a magazine - made by Sullivan.
http://www.sullivanproducts.com/ContSysAccMainFrame.htm
balsa or carbon is online now Find More Posts by balsa or carbon
Old Mar 04, 2011, 06:25 PM
Joined Aug 2000
Harry, you can see range of motion in the vector thrust mechanism here.
http://www.rcgroups.com/forums/showthread.php?t=1400770
Old Mar 04, 2011, 07:34 PM
stanordave is offline
Find More Posts by stanordave
stanordave's Avatar
Joined Jan 2006
Since I'm using a larger motor now, decided to use a beefier gimbal. This one seems real sturdy. I just loosened the bolts before the picture to change out the servo arm stud for a longer one that won't hit the side, pivot bolt. Sure wish I had a milling machine or at least a decent hardware store around..
stanordave is offline Find More Posts by stanordave
Old Mar 05, 2011, 12:17 AM
Germany
Joined Dec 2006
... may be, 5mm aluminium (welding-) wire sticks (around 1m length) could help to bend gimbel rings of different diameters (for the 'ring-in-ring' gimbel construction):
You take 2 different nuts, say 36mm and 22mm, and, both, the nut and the wire, caught in the vice, then You bend the whole wire in 2 spirals around the fixed nut, say, each spiral with 3.1/2 rings.
Cut the spiral-rings with an overlap of 5mm, and file the overlap flat, so the overlaps are shaped in a half-circle.
Align the rings as necessary, and fix them at the overlap with a 2mm screws...
So, You get inner and outer rings for Your gimbel...and need no milling machine
flattermann
Old Mar 05, 2011, 03:26 PM
stanordave's Avatar
Joined Jan 2006
sounds good flattermann..
good thing I made another gimbal. The motor ripped off this AM during launch when the original broke!
Old Mar 21, 2011, 02:15 PM
stanordave's Avatar
Joined Jan 2006
Needed to get the motor higher so made another gimbal out of some strip aluminum stock and CF. Plenty of movement...don't know if the servo can provide that much throw..
Discussion Vector-thrust pusher with 3-axis gyo, anyone ever build? learn2turn Foamies (Scratchbuilt) 8 Sep 23, 2010 06:34 PM
Discussion JAS 39 360 VECTOR THRUST about to click Buy it Now. need advise airbagit13 Foamy EDFs 3 Sep 08, 2010 11:28 AM
Sold Sold Pending: Two NIB Turbo Vector kits Wattage/Hobby People w/o fan units 50% off jcstalls Aircraft - Electric - Airplanes (FS/W) 7 Oct 21, 2008 06:13 PM
Discussion Vector Vector **with maiden vid** sno Slope 82 Apr 21, 2008 09:50 AM
Wanted Vector Schuebeler VECTOR II PerfTech Aircraft - Electric - Airplanes (FS/W) 0 Jan 22, 2008 10:32 PM
