Old Feb 21, 2011, 10:27 AM
flattermann is offline
Find More Posts by flattermann
check the crazyplanes ...
flattermann's Avatar
Germany
Joined Dec 2006
VECTOR UNITS - typology
Hi there,
as I could read in different threads, some of You are looking to build a vector unit by yourself.
I attach some photos showing different types and sizes of functionable vector units I realized, using different mechanical solutions.
Pic. unit_1 shows the 'blocked servo' solution, using 2 blocked (metalgear) servos only
No. 2 shows the 'ring-in-ring' solution (used Hard-Disk distance rings)
No. 3 shows the 'plate-in-plate' solution www.vector-technik-de, using glassfibre or carbon fibre plates.
No. 4a + b show the 'heli-swashplate' solution
No. 5 shows the 'full heli-mechanics' solution
No. 6 shows the 'gimbel solution' (like www.PremierRC.com manufactures)
No. 7 shows the 'Universal Joint' solution.
I personally prefer different gimbel solutions, because I use mostly interchangeable vector units in my different Vector Kites.
This type allows use also BL-motors of different power (800-1600grs. of thrust) - shown in the 'big_and_small' photo.
flattermann
flattermann is offline Find More Posts by flattermann
Old Feb 21, 2011, 10:35 AM
Harry D is offline
Find More Posts by Harry D
TLAR Aviation
Harry D's Avatar
Canada, AB, Edmonton
Flattermann, you are a priceless resource here! Thank you.
Harry D is offline Find More Posts by Harry D
Old Feb 21, 2011, 12:58 PM
balsa or carbon is offline
Find More Posts by balsa or carbon
Hot glue held together by foam
balsa or carbon's Avatar
United States, OR, Portland
Joined Aug 2010
Flattermann,
Thank you so much for all the helpful information. what are your recommendations for servos for the different type of vector unit solutions? Metal gear , high torque , ball bearing , all of the above?
balsa or carbon is offline Find More Posts by balsa or carbon
Old Feb 21, 2011, 01:31 PM
Germany
Joined Dec 2006
... for vector units up to 800grs. of thrust I take titanium/alloy and brass metal gear servos (not cheap, but durable) weighing around 15grs., and performing around 2kgs./cm torque.
For bigger units over 800grs. up to around 1500 grs. of thrust, I take the same quality class of metal gear servos, but 1 size bigger (around 25grs weight) , performing around 3kgs/cm.
Since I have made best experiences with high quality metal gear servos with single or double ball bearing, I take these.
And: For use in Vector Units, I prefer servos of 'normal, average' speed.
flattermann
Old Feb 21, 2011, 02:44 PM
Joined Aug 2010
Thanks again , Flattermann! Off to the hobby shop I go!
Mitchy123 is offline
Find More Posts by Mitchy123
United Kingdom, Bognor Regis
Joined Feb 2011
Flatterman,
Many thanks for your great information.
Could I please ask, the modified Gen II vector unit, is this the one you use with you 19' Delta. ?
I was wanting to do something similar later in the year, and would upgrade the servos, ESC and motor, could you recommend the motor/prop combination you are using ?
Love the Blade Msr Mini Vector :-)
regards
Dave
Mitchy123 is offline Find More Posts by Mitchy123
Old Feb 21, 2011, 09:25 PM
batusaix is offline
Find More Posts by batusaix
User Extraordinaire
Davao, Philippines
Joined Apr 2007
Oh. That's how it works.
batusaix is offline Find More Posts by batusaix
Old Feb 21, 2011, 11:04 PM
slebetman is offline
Find More Posts by slebetman
slebetman's Avatar
Malaysia, Selangor, Kajang
Joined Jun 2009
There's also one interesting one someone came up with that used elevon controls. I can't quite find the post/picture/video of it at the moment. The elevon mix allows a simpler gimbal system because it doesn't need to be symmetrical along the vertical axis.
slebetman is offline Find More Posts by slebetman
Old Feb 21, 2011, 11:18 PM
batusaix is offline
User Extraordinaire
Davao, Philippines
Joined Apr 2007
slebetman,
That pic would be helpful.
I have many plans inline for building, I'm currently in a profile pusher jet fever, they are just so simple to make & so much fun. And it uses the elevon mix you mentioned.
flattermann,
That video where you were flying in the wind with the long tail was just amazing. That is my inspiration, I would definitely want to build one.
Now, when does hobbycity plan to mass produce this gimbal thing. It's not that hard.
Old Feb 21, 2011, 11:38 PM
slebetman's Avatar
Joined Jun 2009
Originally Posted by batusaix View Post
slebetman,
Finally found it. Here it is: http://www.rcgroups.com/forums/showt...=3#post8417732
Basically something like this:
Old Feb 21, 2011, 11:54 PM
batusaix is offline
User Extraordinaire
Davao, Philippines
Joined Apr 2007
Thanks slebetman.
It actually looks more complex.
I also like how you did yours, diy effectiveness.
I don't need TV on profile jets, that's why I never bothered. I always follow the basic rule with electrics, the lighter it is, the better it flies.
Old Feb 22, 2011, 12:15 AM
Joined Aug 2010
It looks like Flattermann's solution #7 above ( universal joint solution ) would use an elevon mix . That seems to me to be a good design because you would have TWO servos pulling the weight of the motor and prop up when the input is up elevator.
Old Feb 22, 2011, 12:40 AM
batusaix is offline
User Extraordinaire
Davao, Philippines
Joined Apr 2007
Perfect.
Old Feb 22, 2011, 12:49 AM
slebetman's Avatar
Joined Jun 2009
It depends on how you set it up. If you set it up like a 't' then it works like a regular elevator/rudder control. If you set it up like an 'x' then it uses elevon control.
Here's one with regular elevator/rudder set up: http://www.rcgroups.com/forums/showthread.php?t=1376752
Funny thing about elevon/v-tail mix is that if you look at it right what it's doing is just rotating the stick 45 degrees. For a while now I've been tempted to build an elevon delta foamy and fly it with my non-computer radio by simply holding the TX at an angle and do the mix with my thumb
Old Feb 22, 2011, 12:56 AM
Joined Aug 2010
If you would like to do elevon mixing with a non-computer radio you could make an onboard mechanical mixer . http://www.rcgroups.com/forums/showthread.php?t=1385916http://www.rcgroups.com/forums/showp...17&postcount=7
Discussion Vector-thrust pusher with 3-axis gyo, anyone ever build? learn2turn Foamies (Scratchbuilt) 8 Sep 23, 2010 06:34 PM
Discussion JAS 39 360 VECTOR THRUST about to click Buy it Now. need advise airbagit13 Foamy EDFs 3 Sep 08, 2010 11:28 AM
Sold Sold Pending: Two NIB Turbo Vector kits Wattage/Hobby People w/o fan units 50% off jcstalls Aircraft - Electric - Airplanes (FS/W) 7 Oct 21, 2008 06:13 PM
Discussion Vector Vector **with maiden vid** sno Slope 82 Apr 21, 2008 09:50 AM
Wanted Vector Schuebeler VECTOR II PerfTech Aircraft - Electric - Airplanes (FS/W) 0 Jan 22, 2008 10:32 PM
