Old Feb 20, 2011, 10:09 PM
Swaneyjoe is offline
Find More Posts by Swaneyjoe
Swaneyjoe's Avatar
Joined May 2009
Erc Micro stick transmitter Help ?
Hi Anyone that is fimilliar with the Micro Stick from E rc.
I just aquired one. It flies great. But was wondering about its Transmitter. I have no info on it, but the manual only states that it is factory bind. It does give binding instructions how to re Bind it. Does anyone know if its compatable with the DX6i or Dx5e or the just plain DSM transmitter. I can't get it to bind with any of them,except with its default transmitter in mode 2. Has anyone tried or had success binding it to any of the other Spektrum transmitters. If you did, what binding procedure did you use??
Thanks for any info.
Swaneyjoe.. Calif
Swaneyjoe is offline Find More Posts by Swaneyjoe
Old Feb 20, 2011, 11:09 PM
derk is offline
Find More Posts by derk
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
this plane uses its own software for sending information, so will not work with any other 2.4ghz systems. its not like older 72mhz where as long as channel and shift match it would work. lame but thats how it is
derk is offline Find More Posts by derk
Old Feb 21, 2011, 07:33 PM
Swaneyjoe's Avatar
Joined May 2009
Thanks Derk, For the info!
Well, I figured as much. Its default transmitter works ok, but would have been nice if I could have bound it to my other Transmitters. Good ole Courdalene ID HUH? Beatufull drive thru the Courdalene's for sure. I was born and raised in Missoula, and the drive thru Courdalene was the prettiest part of the trip to Seattle quite often.
Thanks again..
Swaneyjoe... Calif
Article Hobby Express eRC Micro Stik Ready to Fly pda4you Micro Ready-to-Fly 143 Aug 19, 2013 10:59 AM
Discussion eRC Micro Stik Field Repair :: Mercury Adhesives Won't Stick? Help!!! N925WB Micro Ready-to-Fly 4 Aug 02, 2011 03:04 PM
Wanted Flyzone/eRC brick and transmitter, Vapor brick epilot Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Jan 09, 2011 12:19 PM
Wanted WANTED.. eRC receiver/servo board for the micro Mustang or Spitfire Aero Andy Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 Oct 02, 2010 05:04 PM
Discussion Help!...problem w/ eRC micro plane... bkyrdflyr Electric Plane Talk 2 Feb 21, 2010 02:38 PM
