Old Feb 20, 2011, 08:48 AM
eyeinsky1 is offline
Find More Posts by eyeinsky1
eyeinsky1's Avatar
Halifax NS Canada
Joined Apr 2009
Build Log
EPP FPV plane from HK
Hi Guys
I’ve had this project on the backburner for a long time and now I've found the ideal platform. I chose the EPP FPV plane from HK. This aircraft when completed will be ocean water tight AV/AP platform with video down link on and off ship operation.
Lake Day (6 min 48 sec)
Design challenges:
-Water tight main fuselage that this platform does support with additional fabricated water tight hatches to be constructed out of fibreglass.
- Remote mounted rudder and elevator servo to be relocated to water tight fuselage.
-Removable flight surfaces that break down into their individual components; L&R wing, vertical and horizontal stab. (Modification is required here)
-Stabilized flight control system with AHR and GPS return home function.
-Water tight Camera system that records HD 1080 60fps; Go-pro hero with a small mod to enable water proof connection AV out.
-Water recovery system; D ring or loop mounted at C of G point, and fibreglass pole with hook for water retrievals.
Control system main processor component; KK Board
Wiring lay out and SW versions to be determined but had planned on using the Wii motion & nun-chuck sensors at this time for the main AHR components.
Any suggestion or advice of SW at this point would be appreciated.
Thanks Jerry
eyeinsky1 is offline Find More Posts by eyeinsky1
Old Feb 21, 2011, 08:43 PM
eyeinsky1's Avatar
Halifax NS Canada
Joined Apr 2009
Reviews
http://www.youtube.com/watch?feature...d9Rkego#at=157
Standard Aeroplane OpenAero KK control HK EPP FPV test flight was successful. Wind was low sky’s were foggy, the OpenAero sw performed excellent, we perform two test fwd and aft C of G operation.
HK EPP FPV KK OpenAero Test Flight.mov (8 min 25 sec)
Here's the latest aerial video test flight going well. The roll rate was a little high and my camera mount had a little play so the video was less than perfect but quality was good and based on the condition at this time I'm very happy. Unfortunately viewing from the ground she looked great. I've shimmed the camera mount, reduced the roll gyro rate and re-jigged the elevator control to add more throw.
HK EPP FPV KK OpenAero Aerial Video.mov (6 min 41 sec)
Old Mar 10, 2011, 05:42 PM
eyeinsky1's Avatar
Halifax NS Canada
Joined Apr 2009
Flight Control System setup
Old Mar 10, 2011, 05:48 PM
captaingeek is offline
Find More Posts by captaingeek
master of the universe
captaingeek's Avatar
USA, CA, Novato
Joined Jul 2008
very nice going. you can water proof this stuff using silicon sealent. I've done that with some of my ESC's for my water planes. good use of the mwii.
captaingeek is offline Find More Posts by captaingeek
Old Mar 10, 2011, 05:49 PM
USA, CA, Novato
Joined Jul 2008
where'd you get your arduino clone?
Old Mar 10, 2011, 05:51 PM
eyeinsky1's Avatar
Halifax NS Canada
Joined Apr 2009
http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWNX:IT
Old Mar 11, 2011, 07:02 AM
frank48 is offline
Find More Posts by frank48
Went to mow a meadow
frank48's Avatar
United Kingdom, Dur
Joined Feb 2007
Looking good
What software are you using?
Frank
frank48 is offline Find More Posts by frank48
Old Mar 14, 2011, 08:40 PM
eyeinsky1's Avatar
Halifax NS Canada
Joined Apr 2009
Jerry
I'm going to use the MWC software not sure what version yet.
Here the servo shield detailed pictures
Old Mar 22, 2011, 02:07 PM
eyeinsky1's Avatar
Halifax NS Canada
Joined Apr 2009
Here She Is Started assembly last night
Old Apr 09, 2011, 03:01 PM
eyeinsky1's Avatar
Halifax NS Canada
Joined Apr 2009
Finally got her flyable here's the first flight with stock setup. No multiwii in stalled yet.
HK EPP FPV #1 (1 min 9 sec)
Old Apr 21, 2011, 01:31 AM
FlyingMcCoy is offline
Find More Posts by FlyingMcCoy
Joined Mar 2010
Hi Jerry,
Any updates?
FlyingMcCoy is offline Find More Posts by FlyingMcCoy
Old Apr 21, 2011, 06:09 PM
eyeinsky1's Avatar
Halifax NS Canada
Joined Apr 2009
Originally Posted by FlyingMcCoy View Post
Hi Jerry,
Any updates?
Still going, test flew once looks good but working on the control system code.
Please Standby
Thanks for the interest.
Jerry
Old Aug 08, 2011, 04:31 PM
eyeinsky1's Avatar
Halifax NS Canada
Joined Apr 2009
Final got this thing back in the air, work still in process. I tried some landing gears on her, water and wheels.
I still plan to move fwd with this project. I just got a little stalled. I'm still working the standard control system but I've notice this plane had large torque roll issue. I've off set the motor still having some yaw issue though.If any of you EPP FPV guys have any other sugestion?
Thanks Jerry
Old Aug 08, 2011, 05:52 PM
frank48 is offline
frank48's Avatar
United Kingdom, Dur
Joined Feb 2007
Hi Jerry
Regarding your mwcontrol, there are some interesting developments over on the mw forum. You might be interested in this thread http://www.multiwii.com/forum/viewtopic.php?f=8&t=364
Not tried it myself yet
Hope this helps ...
/Frank
Old Aug 08, 2011, 06:21 PM
eyeinsky1's Avatar
Halifax NS Canada
Joined Apr 2009
Originally Posted by frank48 View Post
Hi Jerry
Hope this helps ...
/Frank
Thanks Frank this will speed the progress up
New Product Hobby King EPP FPV plane dblnaknak FPV Aircraft 2278 Feb 27, 2016 03:32 PM
New Product New EPP FPV HobbyKing Plane Beetle-Jet Electric Plane Talk 3 Nov 20, 2010 02:55 PM
Discussion New HK FPV plane metalfred FPV Aircraft 19 Nov 08, 2010 04:08 AM
Discussion HK Cessna 182 Micro plane EPP Telechat Micro Ready-to-Fly 6 Oct 16, 2010 10:01 AM
Discussion New EPP FPV plane catamar FPV Aircraft 9 Oct 12, 2010 05:29 PM
