Old Feb 19, 2011, 10:29 PM
markf007 is offline
Find More Posts by markf007
Australia, VIC, Melbourne
Joined Jan 2011
Help!
SKY-705 switch from Mode 2 to Mode 1
Hi,
A friend of mine is trying to switch his SKY-705 from mode 2 to mode 1. He has followed the manual and successfully changed over the internals of the SKY-705 unit. He has also applied Wasp V3 6ch model 1 programming to the SKY-705 unit using the 'SKY705 Remote control Set V2.1' utility.
Unfortunatly his Wasp V3 6ch CCPM heli doesn't work with the modified SKY-705. The issue being that some of the SKY705 controls in mode 1 don't seem to be matched to the receivers on the Wasp V3 Heli. ie no rudder movement.
Any thoughts what else he should try?
Regards,
Mark
markf007 is offline Find More Posts by markf007
Discussion Change from mode 2 to mode 3 - Fly Sky CT6B ifresh21 Radios 11 Apr 28, 2016 08:35 AM
Discussion Turnigy 9X Mode 1 to Mode 2 Switch XTheOwl Radios 9 Jun 04, 2014 01:46 AM
Help! Shell I do switch from mode 1 to mode 2 clicky Mini Helis 11 Jan 16, 2008 02:24 AM
Alert Switch from mode 2 to mode 1 sergiomx Fuel Plane Talk 3 Nov 24, 2005 02:15 AM
How to switch from Mode 1 to Mode 2 TX Snooptalian Micro Helis 13 Nov 13, 2005 07:00 PM
