Canada
Joined Dec 2004
Yes I've got the HEXA distribution board.
As for connecting the ESC to the MK-USB is it down as shown at the end of this page http://www.mikrokopter.com/ucwiki/en...oftware_update Is there a reasonable way to remove the ESC from the distribution board without having to disassemble everything? (Got the HEXA used so I'm new at this). |
Here is some info on connecting the bl direct to MKusb.
When I updated my bls I had to connect the ribbon cable to the pins on the side of the mkUSB. http://www.mikrokopter.us/index.php?...42.0;topicseen |
Canada
Joined Dec 2004
So after removing the ESC from the distribution board (bit of a pain) I couldn't communicate with the ESC in mktools. Upon closer examination one of the traces on the esc has been burnt (had to be the side not visible when it was installed) so at least I have confirmation something's wrong, I'll see if I can solder a wire to bypass the burnt trace and try MKtools again.
| Thread Tools | |
| Discussion simple problem with mikrokopter BL ctrl v1.2 | endrew | Multirotor Talk | 5 | Feb 15, 2011 10:47 AM |
| Help! Does anyone know the I2C commands for programming BL-Ctrl V1.1 ? | hg1 | Coaxial Helicopters | 4 | Mar 17, 2008 09:31 AM |
| Help! Does anyone know the I2C commands for programming BL-Ctrl V1.1 ? | hg1 | UAV - Unmanned Aerial Vehicles | 0 | Mar 16, 2008 08:40 PM |
| Discussion 2 BL Motor's, 2 BL ESC's, 1 ESC hotter than the other!!?? | stuart warne | Power Systems | 8 | Nov 26, 2007 11:45 AM |
| Discussion twin bl motors/1 or 2 bl esc? | SFGuy | Power Systems | 8 | Jun 04, 2007 05:58 PM |
