Old Mar 18, 2012, 05:25 PM
xtremeRCpilot is online now
Find More Posts by xtremeRCpilot
xtremeRCpilot's Avatar
Cleveland, Ohio
Joined Sep 2006
Just received my shipment of TVRP Mounts just need to bundle them with ball links and will have them available hopefully next weekend!
www.xtremefoamies.com
John
xtremeRCpilot is online now Find More Posts by xtremeRCpilot
Old Apr 14, 2012, 12:59 PM
santiago3d92095 is online now
Find More Posts by santiago3d92095
santiago3d92095's Avatar
Joined Apr 2011
those look great!
santiago3d92095 is online now Find More Posts by santiago3d92095
Old Apr 16, 2012, 07:20 PM
Cleveland, Ohio
Joined Sep 2006
Thank you santiago3d92095! If you have any interest send me a pm and I will give you a 20% discount code!
Cheers
John
Old May 14, 2012, 02:59 AM
iandre is offline
Find More Posts by iandre
Joined Jun 2006
Is someone have an electronic file with axi mamo mount ? (pdf/dxf/...)
thanks !
iandre is offline Find More Posts by iandre
Old May 25, 2012, 02:47 AM
21Matthias21 is offline
Find More Posts by 21Matthias21
Joined Feb 2009
Hi John,
That looks really great :-)
One comment from my side, I would prefer to have the pitch servo on the right bottom site and not directly on bottom side, that means at about 4 o'clock position.
I hope my explanation is a bit understandable: rolleyes:
Reason is, with your version the whole vector unit is very long.
If you have a plane with a smaller nose you can not mount that unit.
Matthias
21Matthias21 is offline Find More Posts by 21Matthias21
Old May 25, 2012, 05:10 AM
Cleveland, Ohio
Joined Sep 2006
Thanks Matthias, I understand what you are asking and have look at the options. During the design I played with the angle of the servo in CAD and found I was only gaining about .2500 " on the bottom leg, so I just went with keeping it symmetrical to the centerline. To be honest its not that bad. you need a 1" offset from the center of motor to top of fuse and 1.25" from motor center to bottom to make it work. I will keep this in mind on future designs. I agree it could be a breaking point for some aircraft. Thank you for the input and please post your measurements. I really like your mount you made !! I just try to be different
John
Old Jul 23, 2012, 06:49 AM
ALEX HEWSON is offline
Find More Posts by ALEX HEWSON
Remember... Fly for fun!
ALEX HEWSON's Avatar
Christchurch, New Zealand
Joined Jul 2005
Anyone tried these for Mamo Unit control: http://www.soaringusa.com/MKS-DS65K-...tal-Servo.html
Great centering and power for such a small unit. Would make a very solid set-up. Hmmm thinking... I have had a Mamo unit in the drawer for over two years and never used it
ALEX HEWSON is offline Find More Posts by ALEX HEWSON
Old Jul 26, 2012, 12:41 AM
Joined Jul 2005
How do you guys get your VPP models so light? I have just built my second (first one was a flop as it came out at 185gms)
My new one is milled, servo cases lightened, leads shortened, etc and has come out at 165gms!
I am using futaba 3114 servos and a d47 on pitch. A Scorpion 2503 motor and scorpion 11A esc and a 3s 350mah pack. I fried my 6300rx so put in a lightened 6100.
Not sure how to go lighter. I may replace the servo leads and solder on 36 gauge wire direct soldered to Rx.
Any other ideas??
Old Jul 26, 2012, 01:19 AM
Andycap is offline
Find More Posts by Andycap
Inspired by the wings of an An
Andycap's Avatar
Leeds
Joined Mar 2003
Hi Alex,
Most of us use 2s batteries so thats 10g saved instantly, that brings in in line with most VPP models at 155g. Your model isnt as heavily milled as the really light VPP models I have seen either. Also Depron Aero is approx 20% lighter than regular depron
Andy
Andycap is offline Find More Posts by Andycap
Old Jul 26, 2012, 02:18 AM
Joined Jul 2005
Cheers. It is hard being here in NZ to get things like depron or anything for that matter! And local shops are very expensive due to the same reason
Old Jul 26, 2012, 02:29 AM
Joined Jul 2005
This was my last foamy i built, it was milled probably more what you are meaning. It weighed 114g with a 2s 250. But i usually used a bigger battery for more flight time
Tuesday Indoor night (5 min 8 sec)
Foamy Walk (2 min 5 sec)
http://www.youtube.com/watch?feature...&v=kc2ZSZMxWdE
Old Jul 26, 2012, 03:50 PM
Free is offline
Find More Posts by Free
"Free" in Christ! #F3P
Free's Avatar
United States, CA, SF
Joined Jan 2012
Looks good,
What plane is that???
Free
Free is offline Find More Posts by Free
Old Jul 27, 2012, 05:10 AM
Joined Jul 2005
Which one? The Raven is my design, and the VPP model is a Mobius designed by Marcus Sargent. BEST indoor foamy design I have ever flown and I have flown most of the well known indoor foamies.
http://www.sargesrc.orconhosting.net.nz/
Old Jul 30, 2012, 11:46 PM
Joined Jul 2005
I am embarrassed showing this as it is the first VPP I have ever done, but you guys should get some laughs out of it lol
Mobius VPP test flight (2 min 2 sec)
Old Jul 31, 2012, 12:35 AM
Andycap is offline
Andycap's Avatar
Leeds
Joined Mar 2003
Nothing embarrassing there Alex
Discussion Mamo Models VPP Flight 3DPat Indoor Pattern/F3P 6 Dec 08, 2010 05:57 PM
Discussion Axi 2203/40 VPP + Mamo, including video + info Shahid B Indoor Pattern/F3P 3 Nov 16, 2010 10:06 AM
Help! Mamo Models VPP Help 3DPat Indoor Pattern/F3P 6 Oct 20, 2010 08:29 PM
Discussion Mamo VPP system - is it any good ? heffalump 3D Flying 1 Jan 26, 2007 04:16 AM
