Old Jan 12, 2012, 02:10 AM
21Matthias21 is offline
Find More Posts by 21Matthias21
Joined Feb 2009
I run the 8” Blades on 2S.
From my feeling it makes not so much difference between using 8” or 9” on that motor.
I have the feeling that on 8” the motor has a better response characteristic on throttle stick.
Maybe I have to switch back to 9” Blades if I crash a few times and the weight of the plane is increasing.
I use three flight modes:
Mode1: No Vector no VPP
Mode2: Vector no VPP
Mode3: Vector and VPP
If I use the vector ore not depends on the flight maneuver.
At some rolling maneuvers and snaps I do not like the vector, because the movement of the plane looks a little bit strange.
The bracing and the ball links are a copy of RJ’s plane. But the plane it self is totally different design.
I had the idea to make my own design. On the pictures you can see Extra 300 Prototype Version 8.
It's not so easy to design a plane which is flying well at all manoeuvres at high speed and low speed.
But now this should be the final version. That version flys really really well.
Next step is to bring it into CAD :-) Cutting and milling by hand is not that what I like most ;-)
John is right. If you crash the balls are popping off the link. I use the ball links of a T-REX 250.
On my previous planes I have used one servo for vector and rudder and I damaged a lot of servos if I touched the ground too hard.
The extra servo makes the trimming easier and you can use a smaller servo on vector and rudder. That means I has only advantages and no disadvantage
If the vector is linked to the rudder you have to use a bigger servo. That means weight is nearly the same.
Matthias
21Matthias21 is offline Find More Posts by 21Matthias21
Old Jan 12, 2012, 07:40 AM
aerolite is offline
Find More Posts by aerolite
Fly lower!
aerolite's Avatar
West Texas
Joined Jan 2005
matthias,
It appears that you are using two different types of ball links, you mentioned the t-250.
Which one is which? For the VPP ball link, and the vector ball link?
thanks, aerolite
aerolite is offline Find More Posts by aerolite
Old Jan 12, 2012, 08:15 AM
hpapilot is offline
Find More Posts by hpapilot
Oly crap.. Deese ease not gud!
hpapilot's Avatar
USA, NC, Kernersville
Joined Nov 2006
Wow, nice job Matthias. That looks great!
We use the T-rex 250 ball links all around. Haven't had an issue with them, and have never had them come apart, even in crashes. The links should be too tight to let that happen. I've also used 450 links on ailerons and they work great as well, just a little heavier.
Running an extra servo on vectoring is nice, but in my experience the only real reason to do it is to make trimming and setup easier. Our airplanes are light enough that we don't mind the extra weight and we find it worth it to simplify setup and be able to run pushrods on every control. On my first two TVVPP airplanes I coupled the vectoring to the rudder servo with pull-pull lines and never had a problem or damaged the servo. It was just a little more work to keep well maintained.
That said, I don't use any smaller servos with the two-servo setup. I use the S3154's either way. If you use two smaller servos, obviously there's no penalty.
A TVVPP plane doesn't have to be any heavier than an unmilled, normally setup version of the same airplane.
hpapilot is offline Find More Posts by hpapilot
Old Jan 12, 2012, 08:16 AM
Joined Feb 2009
Hi aerolite,
I use only one type of 250 ball links. On Vector, Aileron, Rudder and Elevator
Matthias
Old Jan 12, 2012, 08:24 AM
aerolite is offline
Fly lower!
aerolite's Avatar
West Texas
Joined Jan 2005
Originally Posted by 21Matthias21 View Post
Hi aerolite,
Matthias
thanks for the quick answer. aerolite
Old Jan 12, 2012, 08:27 AM
Joined Feb 2009
Hi RJ,
with your skills on flying you have the advantage that you do not crash so often and hard into the ground like other people... and me
Matthias
Old Jan 12, 2012, 04:50 PM
hpapilot is offline
hpapilot's Avatar
Joined Nov 2006
Haha I wish I could say that, but I have crashed those TVVPP airplanes quite a few times... now I just know how to build them strong enough not to break often.
RJ
Old Feb 27, 2012, 06:35 PM
xtremeRCpilot is online now
Find More Posts by xtremeRCpilot
xtremeRCpilot's Avatar
Cleveland, Ohio
Joined Sep 2006
Hey Guys, Anyone still into flying 4D I have been having a lot of fun with it and have recently moved on to designing a TVRP mount. Just installed and flew it with an axi 2203-40 and D47 on pitch and Vector control. When available on the site it will come with all hardware including the ball links and extra carbon flat strips and kevlar to mount to your airframe, no electronics... Thanks to all for the inspiration!
John
xtremeRCpilot is online now Find More Posts by xtremeRCpilot
Old Feb 28, 2012, 03:18 PM
Max Se is offline
Find More Posts by Max Se
Joined Feb 2011
Extra 300 4D Indoor - Le Creusot 2012 - Maxime SELLEM (2 min 13 sec)
Max Se is offline Find More Posts by Max Se
Old Feb 28, 2012, 05:08 PM
Cleveland, Ohio
Joined Sep 2006
That answers my question!
Old Mar 01, 2012, 02:56 PM
Cleveland, Ohio
Joined Sep 2006
Hey Max, very nice flying! Question, when you do the reverse flat spins are you using rudder only and left or right? I need alot of practice on this!
Thanks and please post more awesome videos!
John
Old Mar 05, 2012, 10:46 AM
Max Se is offline
Joined Feb 2011
The reverse flat spin works better in the reverse sense of clockwise, so you have to put left rudder upside down or rigth rudder in positive with full trottle back, don't touch anything else.
Old Mar 05, 2012, 11:58 AM
Cleveland, Ohio
Joined Sep 2006
Cool Thanks Max, You make it look effortless, I know this didnt come easy I dunk mine in all the time but the mamo is easy to fix. I just need to find the right batteries because the ones Im using are junk after two flights including the higher priced TP 65c batts.
Jphn
Old Mar 10, 2012, 12:49 PM
Txskywriter is offline
Find More Posts by Txskywriter
Txskywriter's Avatar
Joined Feb 2007
John
Just let us know when you have them and what website.... i know a few people anxiously waiting to try this on some unusual designs.......
Txskywriter is offline Find More Posts by Txskywriter
Old Mar 10, 2012, 01:09 PM
Cleveland, Ohio
Joined Sep 2006
You can go to www.xtremefoamies.com and it will be under TVRP Mount. I only have the non thrust vectored mounts available but will have the new ones soon! Thanks for the interest!\
John
Discussion Mamo Models VPP Flight 3DPat Indoor Pattern/F3P 6 Dec 08, 2010 05:57 PM
Discussion Axi 2203/40 VPP + Mamo, including video + info Shahid B Indoor Pattern/F3P 3 Nov 16, 2010 10:06 AM
Help! Mamo Models VPP Help 3DPat Indoor Pattern/F3P 6 Oct 20, 2010 08:29 PM
Discussion Mamo VPP system - is it any good ? heffalump 3D Flying 1 Jan 26, 2007 04:16 AM
