Old Mar 11, 2011, 11:01 AM
xtremeRCpilot is offline
Find More Posts by xtremeRCpilot
xtremeRCpilot's Avatar
Cleveland, Ohio
Joined Sep 2006
Thats great news Skip, I will come by and see you guys!! Hope you have a few in stock when I get there!
John
xtremeRCpilot is offline Find More Posts by xtremeRCpilot
Old Mar 29, 2011, 05:29 PM
Cleveland, Ohio
Joined Sep 2006
OK Guys, the laser G10 Motor mounts are in!!! I decided to keep to the single AXI footprint but these can be drilled for any motor including the Hacker 20-34s! They came in at 3.5grams and are made out of 1.5mm G10 fiberglass!
Also though these were designed specific for the AXI/Mamo VPP system you could easily just use it for a strong front mount application!! These will be on the site but please feel free to send me a PM and I will send one to you for $5 each shipped!!
Thanks again for the interest!!
John
Please keep in mind there may be some dark edges from the laser!!
Old Mar 29, 2011, 07:09 PM
Cleveland, Ohio
Joined Sep 2006
Also if anyone is going to Toledo to the Trade Show or ETOC let me know and you can pick up there!! check it out here
http://www.freewebstore.org/XtremeFo...0_3189652.aspx
John
Old Apr 23, 2011, 09:45 AM
Cleveland, Ohio
Joined Sep 2006
Hey Folks, Just wanted to update you on the mounts, I decided that having these CNCed would be the cleanest look and you now have the option of the micro bolt kit and your choice of Hacker or AXI footprint! Here is a link for ya and let me know if you have any questions, currently http://www.skipmillermodels.com/product_p/mamo_vpp.htm is the distributor for the Mamo system and I wanted to offer a mount for ease of installation!
John
Old Apr 23, 2011, 11:23 AM
pvtzemerak is offline
Find More Posts by pvtzemerak
JR > Futaba
pvtzemerak's Avatar
Green Lane, PA
Joined Mar 2008
Pretty cool. I'll be sure to pick one up if I build a vpp aircraft. Friends request sent
--PvT
pvtzemerak is offline Find More Posts by pvtzemerak
Old Apr 23, 2011, 01:30 PM
Cleveland, Ohio
Joined Sep 2006
Awesome PvT... ! It really is alot of fun and I hope to try the Vectored system soon. Just need more practice!
John
Old May 02, 2011, 09:45 AM
matthew james is offline
Find More Posts by matthew james
matt the cat
United States, OH, Lorain
Joined Oct 2005
Go jonny go!!!!!!!
matthew james is offline Find More Posts by matthew james
Old May 02, 2011, 07:00 PM
Cleveland, Ohio
Joined Sep 2006
Originally Posted by matthew james View Post
Go jonny go!!!!!!!
Ha ha ha, Matthew I was wondering where you were at.. Call me Man!!
John
Old Sep 21, 2011, 02:28 AM
21Matthias21 is offline
Find More Posts by 21Matthias21
Joined Feb 2009
MAMO VPP with Hacker A20-34s
Hi,
here are a few pics of my new vector vpp practice plane.
I'm using the Hacker A20-34s motor on 2S with the 9" Blades
Matthias
21Matthias21 is offline Find More Posts by 21Matthias21
Old Sep 21, 2011, 08:19 AM
Cleveland, Ohio
Joined Sep 2006
WOW, that looks awesome!! I really need to try my hand at the TV, please post a vid of your masterpiece in the air
John
Old Jan 11, 2012, 08:00 AM
Joined Feb 2009
New Extra 300 Trust Vector
Hello,
Here are a few pictures of my new Extra 300 4D
The model is designed by me.
Used Components:
-AXI 2203/40 VPP
-Mamo VPP Unit 8"
-Self made Trust Vectoring Unit
-HTX500 ,E-Flight digital servos and D47 on Pitch
-Thunderpower 2S 325mAh 45C
Weight: 140g RTF
I hope I’ll have time to make a video by end of next week.
I have already built same model without VPP and it fly really really well.
Matthias
Old Jan 11, 2012, 09:00 AM
Cleveland, Ohio
Joined Sep 2006
Very nice Matthias! I see you are doing the super truss for the ailerons and elevator. Did you use the micro tubing, I want to try my hand at this it looks very tedious
Looking forward to the flight video, I was having fun with my vpp unit last weekend and want to design a tvr motor mount.
John
Old Jan 11, 2012, 09:24 AM
Joined Feb 2009
No I do not use tubes, they are standard carbon robs.
The main robs on the airfoil have 1,0mm.
On the aileron and elevator I use 1.0mm, 0.8mm and 0.5mm. It depends on the length of the rob.
I always use the thinnest one which do not flex too much.
On the outlines of the plane I use 3mmx0.13mm carbon flat bars.
When I started balding my first plane with these carbon bracings I was scared that it will add to much weight to the plane.
But It is not so much weight I thought.
My non milled version without the bracing has a wait of 130g.
This one has 140g with VPP unit and extra servo for the vector.
All that bracing makes the plane so much stiffer and more robust. It feels better in the air and
It does not damage so much if you crash.
Matthias
Old Jan 11, 2012, 04:05 PM
Max Se is offline
Find More Posts by Max Se
Joined Feb 2011
Very nice !
It looks so much to the Rj Gritter's plane. Why did you use 8"? 9" works so much better with this motor !
Why did you put an extra servo for the vector? You use it all the time or only when you use reverse pitch ?
Me, I'm scare to don't use cables for the vector servo because I think if you touch the prop on the gound, you can break the servo very easy, you have no problem with this ?
Thanks.
Max Se is offline Find More Posts by Max Se
Old Jan 11, 2012, 05:23 PM
Cleveland, Ohio
Joined Sep 2006
I use the 9" with 2 cell 325 65c lipos, this gives great reverse thrust, but if you are using 3 cell the 8" are a must!
John
Discussion Mamo Models VPP Flight 3DPat Indoor Pattern/F3P 6 Dec 08, 2010 06:57 PM
Discussion Axi 2203/40 VPP + Mamo, including video + info Shahid B Indoor Pattern/F3P 3 Nov 16, 2010 11:06 AM
Help! Mamo Models VPP Help 3DPat Indoor Pattern/F3P 6 Oct 20, 2010 09:29 PM
Discussion Mamo VPP system - is it any good ? heffalump 3D Flying 1 Jan 26, 2007 05:16 AM
