Old Oct 03, 2012, 10:58 PM
fcbflyer is offline
Find More Posts by fcbflyer
Sloping the Financial Cliff
fcbflyer's Avatar
USA, CA, Santee
Joined Oct 2007
Good advice Dr.Corzo. I found out that many fillers work, but like you said, you want to get it done whith the least count of application/sanding steps. I use two, split second and glazing putty. Which 3 do you use?
fcbflyer is offline Find More Posts by fcbflyer
Old Oct 04, 2012, 08:41 AM
alvaro corzo is offline
Find More Posts by alvaro corzo
alvaro corzo's Avatar
United States, CA, San Diego
Joined Feb 2006
Herr Bruno
1- Superfil
2- Light Weight Filler 3M
3- Glazing Putty
Alvaro
alvaro corzo is offline Find More Posts by alvaro corzo
Old Oct 14, 2012, 03:04 PM
wsmorton is offline
Find More Posts by wsmorton
United States, AZ, Prescott
Joined Aug 2006
I finished painting the bottom of the wings with Duplicolor Gloss Black. After a day of drying I took a look and saw a few spots where the paint didn't flow together and left what looks like a fine mesh. These spots where not always on top of an area that I repaired, but I know I had sanded the entire wing. I cleaned the wings with a rag and a very light soapy water mix and then again with just water. I don't know what caused the spots but I'm not going redo them. I can now also see the areas that I should have applied some more filler and sanded. Next time, I'm going to use a grey primer first so I can see any low/high spots and fix them before I apply the final coat.
Scotty
wsmorton is offline Find More Posts by wsmorton
Old Oct 16, 2012, 09:00 AM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Scotty-
Did you wear gloves when handling the wings pre-painting??
Some of those spots look like they could possibly be oily finger prints...
You won't see the blems when specked out!
VR,
Target
target is offline Find More Posts by target
Old Oct 16, 2012, 09:44 AM
fcbflyer is offline
fcbflyer's Avatar
USA, CA, Santee
Joined Oct 2007
Next time tru cleaning the wings with a paint prep cleaner and then use primer.
Old Oct 16, 2012, 11:10 AM
wsmorton is offline
Joined Aug 2006
I definitely plan on taking everyone's advise for the next project like this. Some of those spots appear to be from the Icing not sticking to the paint and others are most likely my greasy paw prints. Oh well. I'm not too worried as I plan on using the black as a background for air brushing some Ghost Blue Flames.
Hopefully, the top will come out much better after I wet sand and polish it up.
Scotty
Discussion Sandable Glue? ForeverFlying The Builders Workshop 11 Jan 28, 2011 02:30 PM
Discussion FFF sandable filler Crash Trash Foamies (Scratchbuilt) 6 Sep 05, 2009 10:00 AM
best sandable primer? Bob K Foamies (Kits) 1 Oct 10, 2002 11:50 AM
Foam Safe light Sandable Primer S Anastasio Foamies (Kits) 1 Feb 02, 2002 08:40 PM
